upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.62
!!Script ran on: Sat Dec 21 15:20:18 UTC 2013
!!Linux Distribution
Debian GNU/Linux 7 \n \l PRETTY_NAME="Debian GNU/Linux 7 (wheezy)" NAME="Debian GNU/Linux" ID=debian HOME_URL="http://www.debian.org/" SUPPORT_URL="http://www.debian.org/support/" BUG_REPORT_URL="http://bugs.debian.org/"
!!DMI Information
Manufacturer: Dell Inc.
Product Name: OptiPlex 755
Product Version:
Firmware Version: A04
!!Kernel Information
Kernel release: 3.2.0-4-686-pae
Operating System: GNU/Linux
Architecture: i686
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: 1.0.24
Library version: 1.0.25
Utilities version: 1.0.25
!!Loaded ALSA modules
snd_ca0106
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
0 [CA0106 ]: CA0106 - CA0106
Audigy SE [SB0570] at 0xdce0 irq 18
!!PCI Soundcards installed in the system
03:02.0 Multimedia audio controller: Creative Labs CA0106 Soundblaster
!!Advanced information - PCI Vendor/Device/Subsystem ID's
03:02.0 0401: 1102:0007
Subsystem: 1102:100a
!!Modprobe options (Sound related)
snd_pcsp: index=-2
snd_usb_audio: index=-2
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
!!Loaded sound module options
!!Module: snd_ca0106
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
subsystem : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
!!ALSA Device nodes
crw-rw---T+ 1 root audio 116, 11 Dec 21 11:40 /dev/snd/controlC0
crw-rw---T+ 1 root audio 116, 2 Dec 21 11:40 /dev/snd/midiC0D0
crw-rw---T+ 1 root audio 116, 10 Dec 21 11:40 /dev/snd/pcmC0D0c
crw-rw---T+ 1 root audio 116, 9 Dec 21 15:26 /dev/snd/pcmC0D0p
crw-rw---T+ 1 root audio 116, 8 Dec 21 11:40 /dev/snd/pcmC0D1c
crw-rw---T+ 1 root audio 116, 7 Dec 21 15:26 /dev/snd/pcmC0D1p
crw-rw---T+ 1 root audio 116, 6 Dec 21 11:40 /dev/snd/pcmC0D2c
crw-rw---T+ 1 root audio 116, 5 Dec 21 15:26 /dev/snd/pcmC0D2p
crw-rw---T+ 1 root audio 116, 4 Dec 21 11:40 /dev/snd/pcmC0D3c
crw-rw---T+ 1 root audio 116, 3 Dec 21 11:40 /dev/snd/pcmC0D3p
crw-rw---T+ 1 root audio 116, 1 Dec 21 11:40 /dev/snd/seq
crw-rw---T+ 1 root audio 116, 33 Dec 21 12:40 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Dec 21 11:40 .
drwxr-xr-x 3 root root 300 Dec 21 11:40 ..
lrwxrwxrwx 1 root root 12 Dec 21 11:40 pci-0000:03:02.0 -> ../controlC0
!!ALSA configuration files
!!User specific config file (~/.asoundrc)
pcm.!default {
type plug
slave.pcm "surround51"
slave.channels 6
route_policy duplicate
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: CA0106 [CA0106], device 0: ca0106 [CA0106]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: CA0106 [CA0106], device 1: ca0106 [CA0106]
Subdevices: 0/1
card 0: CA0106 [CA0106], device 2: ca0106 [CA0106]
Subdevices: 0/1
card 0: CA0106 [CA0106], device 3: ca0106 [CA0106]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [CA0106]
Card hw:0 'CA0106'/'Audigy SE [SB0570] at 0xdce0 irq 18'
Mixer name : 'CA0106'
Components : ''
Controls : 35
Simple ctrls : 18
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Playback channels: Mono
Limits: Playback 0 - 255
Mono: Playback 209 [82%] [-11.50dB] [on]
Simple mixer control 'Line in',0
Capabilities: cvolume penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 255
Front Left: Capture 207 [81%] [0.00dB]
Front Right: Capture 207 [81%] [0.00dB]
Simple mixer control 'Mic',0
Simple mixer control 'Phone',0
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined penum
Mono: Playback [off]
Simple mixer control 'IEC958 Center/LFE',0
Capabilities: pvolume penum
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback 207 [81%] [0.00dB]
Front Right: Playback 207 [81%] [0.00dB]
Simple mixer control 'IEC958 Front',0
Mono:
Simple mixer control 'IEC958 Rear',0
Mono:
Simple mixer control 'IEC958 Unknown',0
Mono:
Simple mixer control 'Aux',0
Simple mixer control 'Analog Center/LFE',0
Capabilities: pvolume pswitch pswitch-joined penum
Mono:
Front Left: Playback 207 [81%] [0.00dB] [on]
Front Right: Playback 207 [81%] [0.00dB] [on]
Simple mixer control 'Analog Front',0
Mono:
Simple mixer control 'Analog Rear',0
Mono:
Simple mixer control 'Analog Side',0
Mono:
Simple mixer control 'Analog Source',0
Capabilities: cenum
Items: 'Phone' 'Mic' 'Line in' 'Aux'
Item0: 'Line in'
Simple mixer control 'CAPTURE feedback',0
Mono:
Front Left: Playback 0 [0%] [-99999.99dB]
Front Right: Playback 0 [0%] [-99999.99dB]
Simple mixer control 'Digital Source',0
Capabilities: cenum
Items: 'IEC958 out' 'i2s mixer out' 'IEC958 in' 'i2s in' 'AC97 in' 'SRC out'
Item0: 'i2s in'
Simple mixer control 'Shared Mic/Line in',0
Capabilities: cenum
Items: 'Line in' 'Mic in'
Item0: 'Line in'
!!Alsactl output
--startcollapse--
state.CA0106 {
control.1 {
iface MIXER
name 'Analog Front Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Analog Rear Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.3 {
iface MIXER
name 'Analog Center/LFE Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Analog Side Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.5 {
iface MIXER
name 'IEC958 Front Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.6 {
iface MIXER
name 'IEC958 Rear Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.7 {
iface MIXER
name 'IEC958 Center/LFE Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.8 {
iface MIXER
name 'IEC958 Unknown Playback Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.9 {
iface MIXER
name 'CAPTURE feedback Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 1200
dbvalue.0 -9999999
dbvalue.1 -9999999
control.10 {
iface PCM
name 'IEC958 Playback Mask'
value ffffffff00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
comment {
access read
type IEC958
count 1
control.11 {
iface PCM
index 1
comment {
access read
type IEC958
count 1
control.12 {
iface PCM
index 2
comment {
access read
type IEC958
count 1
control.13 {
iface PCM
index 3
comment {
access read
type IEC958
count 1
control.14 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.15 {
iface MIXER
name 'Digital Source Capture Enum'
value 'i2s in'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'IEC958 out'
item.1 'i2s mixer out'
item.2 'IEC958 in'
item.3 'i2s in'
item.4 'AC97 in'
item.5 'SRC out'
control.16 {
iface MIXER
name 'Analog Source Capture Enum'
value 'Line in'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Phone
item.1 Mic
item.2 'Line in'
item.3 Aux
control.17 {
iface PCM
name 'IEC958 Playback Default'
value '0492100200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.18 {
iface PCM
index 1
comment {
access 'read write'
type IEC958
count 1
control.19 {
iface PCM
index 2
comment {
access 'read write'
type IEC958
count 1
control.20 {
iface PCM
index 3
comment {
access 'read write'
type IEC958
count 1
control.21 {
iface PCM
name 'IEC958 Playback PCM Stream'
comment {
access 'read write'
type IEC958
count 1
control.22 {
iface PCM
index 1
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface PCM
index 2
comment {
access 'read write'
type IEC958
count 1
control.24 {
iface PCM
index 3
comment {
access 'read write'
type IEC958
count 1
control.25 {
iface MIXER
name 'Phone Capture Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 2400
dbvalue.0 0
dbvalue.1 0
control.26 {
iface MIXER
name 'Mic Capture Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 2400
dbvalue.0 0
dbvalue.1 0
control.27 {
iface MIXER
name 'Line in Capture Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 2400
dbvalue.0 0
dbvalue.1 0
control.28 {
iface MIXER
name 'Aux Capture Volume'
value.0 207
value.1 207
comment {
access 'read write'
type INTEGER
count 2
range '0 - 255'
dbmin -9999999
dbmax 2400
dbvalue.0 0
dbvalue.1 0
control.29 {
iface MIXER
name 'Shared Mic/Line in Capture Switch'
value 'Line in'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Line in'
item.1 'Mic in'
control.30 {
iface MIXER
name 'Analog Front Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface MIXER
name 'Analog Rear Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.32 {
iface MIXER
name 'Analog Center/LFE Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface MIXER
name 'Analog Side Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.34 {
iface MIXER
name 'Master Playback Volume'
value 209
comment {
access 'read write'
type INTEGER
count 1
range '0 - 255'
dbmin -9999999
dbmax 0
dbvalue.0 -1150
control.35 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
--endcollapse--
!!All Loaded Modules
Module
nls_utf8
nls_cp437
vfat
fat
usb_storage
ppdev
lp
bnep
rfcomm
cpufreq_stats
cpufreq_userspace
cpufreq_conservative
cpufreq_powersave
nfsd
nfs
nfs_acl
auth_rpcgss
fscache
lockd
sunrpc
loop
i915
video
joydev
drm_kms_helper
drm
btusb
bluetooth
parport_pc
i2c_i801
i2c_algo_bit
rfkill
parport
snd_ca0106
snd_ac97_codec
dcdbas
snd_seq_midi
snd_seq_midi_event
coretemp
snd_rawmidi
psmouse
iTCO_wdt
snd_pcm
acpi_cpufreq
iTCO_vendor_support
i2c_core
mperf
snd_page_alloc
snd_seq
snd_seq_device
snd_timer
processor
button
evdev
serio_raw
pcspkr
snd
soundcore
ac97_bus
thermal_sys
ext4
crc16
jbd2
mbcache
usbhid
hid
sg
sr_mod
cdrom
sd_mod
crc_t10dif
uhci_hcd
ata_generic
ehci_hcd
ata_piix
libata
e1000e
usbcore
scsi_mod
usb_common
!!ALSA/HDA dmesg
Ustawień dźwięku to ten Rhythmbox jakichś wybitnych nie posiada, żeby tam coś kombinować. W alsamixer wszystko wydaje się być w porządku.
Co mogę powiedzieć jeszcze. W katalogu domowym jest taki plik .asoundrc
Ale on jest raczej konieczny, bo bez tego gra tylko jeden kanał. Bez tego pliku zmiany i tak nie ma - może grać tylko jeden program na raz. Nie jestem na 100% pewiem, ale wydaje mi się, że Audigy samo w sobie jest chyba jakoś biednie obsługiwane w Linuksie - z tego co poszukałem w necie, to są z tym problemy właśnie na Audigy, żeby kilka rzeczy na raz odtwarzać. Będę się musiał rozejrzeć za jakimś SB Live! najlepiej (mój 10 letni SBL! problemu nie ma żadnego - z 5 rzeczy naraz mogę grać jak potrzeba
), za małą kasę. Tylko sęk w tym, że musi być karta o niskim profilu - taka obudowa, no cóż.
