Kernel - 2.6.26-1-amd64
Karta - GeForce 7300GT
Jakie sterowniki (i skąd je wziąć) mam zainstalować?
Próbowałem:
NVIDIA-Linux-x86_64-177.80-pkg2
NVIDIA-Linux-x86_64-1.0-8756-pkg2Głownie chodzi o directx bo mi gra nie działa.
NVIDIA-Linux-x86_64-1.0-8756-pkg2Kod: Zaznacz cały
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Oct 26 13:05:49 2008
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
no precompiled interface: false
no ncurses color : false
query latest driver ver : false
OpenGL header files : true
no questions : false
silent : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
force tls : (not specified)
force compat32 tls : (not specified)
X install prefix : /usr/X11R6
OpenGL install prefix : /usr
compat32 install prefix : /emul/ia32-linux
installer install prefix: /usr
utility install prefix : /usr
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : [url]ftp://download.nvidia.com[/url]
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site ([url]ftp://download.nvidia.com[/url])? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
-> Performing CC test with CC="cc".
-> gcc-version-check failed:
The compiler used to compile the kernel (gcc 4.1) does not exactly match the
current compiler (gcc 4.3). The Linux 2.6 kernel module loader rejects kern
el modules built with a version of gcc that does not exactly match that of t
he compiler used to build the running kernel.
If you know what you are doing and want to ignore the gcc version check, sel
ect "No" to continue installation. Otherwise, select "Yes" to abort install
ation, set the CC environment variable to the name of the compiler used to c
ompile your kernel, and restart installation. Abort now? (Answer: No)
ERROR: Unable to find the kernel source tree for the currently running kernel.
Please make sure you have installed the kernel source files for your
kernel and that they are properly configured; on Red Hat Linux systems,
for example, be sure you have the 'kernel-source' RPM installed. If you
know the correct kernel source files are installed, you may specify the
kernel source path with the '--kernel-source-path' command line option.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at [url]www.nvidia.com[/url].
