lspci pokazuje:
0000:00:02.0 VGA compatible controller: Intel Corporation 82G33/G31 Express Integrated Graphics Controller (rev 02)
Wymieniłem xfree86 na xorg zgodnie z opisem
Przed instalacją Xorga może zechcesz zaktualizować bazę urządzeń PCI poprzez wykonanie polecenia update-pciids
Dopisać do /etc/apt/sources.list
deb [url]http://www.backports.org/debian/[/url] sarge-backports main
Dopisać do /etc/apt/preferences
Package: *
Pin: release a=sarge-backports
Pin-Priority: 200
Zainstalować:
apt-get update
apt-get install -t sarge-backports xserver-xorg xbase-clients xfonts-base xterm
Attempt to autodetect video hardware? - YES
X -configure
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/slpbuilder:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
X Window System Version 6.9.0 (Debian 6.9.0.dfsg.1-6~bpo.4 20060913071743 [email]nobse@backports.org[/email])
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: Linux 2.6.17-2-k7 i686 [ELF]
Current Operating System: Linux slpbuilder 2.6.25 #12 SMP Thu Aug 28 20:37:53 CEST 2008 i686
Build Date: 13 September 2006
Before reporting problems, check [url]http://wiki.X.Org[/url]
Module Loader present
OS Kernel: Linux version 2.6.25 (root@slpbuilder_new) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #12 SMP Thu Aug 28 20:37:53 CEST 2008
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 1 11:44:47 2008
(II) Open ACPI successful (/proc/acpi/event)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.0
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.so
ABI class: X.Org Video Driver, version 0.8
(--) using VT number 7
(II) PCI: 00:00:0: chip 8086,29c0 card 1458,5000 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 8086,29c2 card 1458,d000 rev 02 class 03,00,00 hdr 00
(II) PCI: 00:1a:0: chip 8086,2937 card 1458,5004 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2938 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1a:2: chip 8086,2939 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,293c card 1458,5006 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,293e card 1458,a002 rev 02 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,2940 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:3: chip 8086,2946 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:4: chip 8086,2948 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2934 card 1458,5004 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2935 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2936 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,293a card 1458,5006 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 92 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2916 card 1458,5001 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,2922 card 1458,b005 rev 02 class 01,06,01 hdr 00
(II) PCI: 00:1f:3: chip 8086,2930 card 1458,5001 rev 02 class 0c,05,00 hdr 00
(II) PCI: 02:00:0: chip 197b,2363 card 1458,b000 rev 02 class 01,06,01 hdr 80
(II) PCI: 02:00:1: chip 197b,2363 card 1458,b000 rev 02 class 01,01,85 hdr 00
(II) PCI: 03:00:0: chip 10ec,8168 card 1458,e000 rev 01 class 02,00,00 hdr 00
(II) PCI: 04:02:0: chip 9005,0080 card 9005,62a0 rev 02 class 01,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,4), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:28:0), (0,1,1), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0 0x0000a000 - 0x0000afff (0x1000) IX[B]
(II) Bus 2: bridge is at (0:28:3), (0,2,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf4100000 - 0xf41fffff (0x100000) MX[B]
(II) Bus 3: bridge is at (0:28:4), (0,3,3), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xf0000000 - 0xf1ffffff (0x2000000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 4: bridge is at (0:30:0), (0,4,4), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 4 non-prefetchable memory range:
[0] -1 0 0xf2000000 - 0xf3ffffff (0x2000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(0:2:0) Intel Corporation unknown chipset (0x29c2) rev 2, Mem @ 0xf4200000/19, 0xe0000000/28, 0xf4000000/20, I/O @ 0xe100/3
*** If unresolved symbols were reported above, they might not
*** be the reason for the server aborting.
Backtrace:
0: X(xf86SigHandler+0x88) [0x8089148]
1: [0xffffe500]
2: X [0x8080d3c]
3: X(xf86DriverlistFromCompile+0x37) [0x8080d87]
4: X(DoConfigure+0x11) [0x8074571]
5: X(InitOutput+0xf99) [0x8071749]
6: X(main+0x230) [0x80d45c0]
7: /lib/tls/libc.so.6(__libc_start_main+0xf4) [0xb7dbc974]
8: X [0x8070221]
Fatal server error:
Caught signal 11. Server aborting
Please consult the The X.Org Foundation support
at [url]http://wiki.X.Org[/url]
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
