pecl install -f ssh2Kod: Zaznacz cały
WARNING: failed to download pecl.php.net/ssh2 within preferred state "stable", will instead download version 0.10, stability "beta"
downloading ssh2-0.10.tgz ...
Starting to download ssh2-0.10.tgz (22,187 bytes)
........done: 22,187 bytes
5 source files, building
running: phpize
Configuring for:
PHP Api Version: 20041225
Zend Module Api No: 20060613
Zend Extension Api No: 220060519
/usr/bin/phpize: /tmp/pear/cache/ssh2-0.10/build/shtool: /bin/sh: bad interpreter: Brak dostępu
Cannot find autoconf. Please check your autoconf installation and the $PHP_AUTOCONF
environment variable is set correctly and then rerun this script.
ERROR: `phpize' failed
