HP dv6615ew 'Failed to allocate mem resource #6'
RGR
Post autor: RGR »
Czy ktoś z Was poradził sobie z poniższym błędem?
Sep 14 00:07:11 krgr kernel: [    0.361398] PCI: Failed to allocate mem resource #6:20000@e0000000 for 0000:01:00.0
Komputer to laptop HP dv6615ew
Wersja mojego systemu to Lenny z jądrem 2.6.26-1-686
Jeśli dobrze zrozumiałem informacje z Internetu ostatnie cyfry opisują szynę PCI i urządzenie do niej wpięte.
Zatem:
lspci -vvs 01:00.00
Wynik:
01:00.0 VGA compatible controller: nVidia Corporation GeForce 8400M GS (rev a1)
	Subsystem: Hewlett-Packard Company Device 30cc
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 16
	Region 0: Memory at c6000000 (32-bit, non-prefetchable) [size=16M]
	Region 1: Memory at d0000000 (64-bit, prefetchable) [size=256M]
	Region 3: Memory at c4000000 (64-bit, non-prefetchable) [size=32M]
	Region 5: I/O ports at 2000 [size=200]
	Capabilities: [60] Power Management version 2
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [68] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
		Address: 0000000000000000  Data: 0000
	Capabilities: [78] Express (v1) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <4us
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend+
		LnkCap:	Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Latency L0 <512ns, L1 <4us
			ClockPM- Suprise- LLActRep- BwNot-
		LnkCtl:	ASPM L0s L1 Enabled; RCB 128 bytes Disabled- Retrain- CommClk+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
	Capabilities: [100] Virtual Channel <?>
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [600] Vendor Specific Information <?>
	Kernel driver in use: nvidia
	Kernel modules: nvidia, nvidiafb
Moja grafika po zainstalowaniu sterowników z Nvidii działa znakomicie, poniższy listing chyba także nie ujawnia jakiś problemów.
Co prawda znalazłem w Internecie informację iż jest to jakiś błąd ale niestety "My English is poor" i z większymi technicznymi tekstami mam spore problemy. Natomiast przeglądając zachodnie fora nie znalazłem nigdzie rozwiązania - prawdopodobnie źle szukałem?
Może ktoś z Was natknął się na wyjaśnienie i rozwiązanie.
Jeśli w powyższym napisałem jakieś głupoty proszę o sprostowanie - polubiłem się z Linuksem stosunkowo niedawno i nadal bardzo błądzę.
majoballs
Post autor: majoballs »
Odświeżę trochę temat. Mam dokładnie tą samą sytuację, przy starcie systemu na samym początku wyświetla się komunikat
z tym, że wartości w nawiasie kwadratowym za każdym razem trochę się różnią.
lspci -vvs 01:00.00
u mnie
majoballs@majoballs-laptop:~$ lspci -vvs 01:00.00
01:00.0 VGA compatible controller: nVidia Corporation GeForce 8400M GS (rev a1) (prog-if 00 [VGA controller])
        Subsystem: QUANTA Computer Inc Device 0763
        Latency: 0
        Region 0: Memory at ce000000 (32-bit, non-prefetchable) [size=16M]
        Region 3: Memory at cc000000 (64-bit, non-prefetchable) [size=32M]
        Capabilities: <access denied>
        Kernel modules: nvidiafb, nvidia
Grafika działa poprawnie. Sterowniki instalowałem te z repozytoriów (ale to chyba nie ma znaczenia).
Mój komputer to laptop Aristo Prestige 1810
