Mam pewien problem i nie wiem w czym.
Moze zaczne ze kiedys mialem serwer na jajku 2.4 w openwallem smigalo pieknie az do rozwalnia plyty, wsadzilem do nowego komputera ten dysk z tym jajem i lipa (wiem co zrobic w tym przypadku). Teraz moja mala dygresja. Nowa plyta jest na X2 i kontroler do dyskow jest VIA (jakis nowy) jajo 2.4 nie ma obslugi tego chipsetu. Jak wkompilowalem VIA z 2.4 to podczas uruchamiania pojawilo mi sie tysiace bledow odnosnie getty i w koncu mi rozwalil filesystem. Poradzono mi jajo 2.6 i rzeczywiscie na 2.6 dziala.
To jest na tej plycie
00:00.0 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.5 PIC: VIA Technologies, Inc. K8M890CE I/O APIC Interrupt Controller
00:00.7 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI bridge [K8T800/K8T890 South]
00:02.0 PCI bridge: VIA Technologies, Inc. K8T890 PCI to PCI Bridge Controller
00:03.0 PCI bridge: VIA Technologies, Inc. K8T890 PCI to PCI Bridge Controller
00:0f.0 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 07)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237A PCI to ISA Bridge
00:11.7 Host bridge: VIA Technologies, Inc. VT8251 Ultra VLINK Controller
00:13.0 PCI bridge: VIA Technologies, Inc. VT8237A Host Bridge
00:13.1 PCI bridge: VIA Technologies, Inc. VT8237A PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: VIA Technologies, Inc. Unknown device 3230 (rev 11)
05:05.0 Ethernet controller: Intel Corporation 82557/8/9 [Ethernet Pro 100] (rev 08)
Jednak to mi nie wystarczalo, chcialem troche bezpieczniejsze jajo w sensie uzycia grsec. Sciaglem tar gz odpowiedni do ostatniego grsec. Zpatchowalem, zaczalem kompilacje, masakra ile tam jest opcji (przerazilem sie troche), ja chce do 2.4 ale niestety musze w tym. Ok skompilowalem. Wpis do lilo i reboot. Myslalem ze ok, a tu nagle problem bo nie ma lanu, w jadrze jest wkompilowany intel na stale ale wywalal jakis dziwny blad, po 3 resecie nagle lan ruszyl, w czym problem byl? Moze ktos mi odpowie, niestety nie wiem jaki byl blad bo fizycznie nie widzialem co tam wyswietlalo.
Drugi problem, komputer iny na amd 1700+, dwa lany relatek 8139, w jaju wkompilowany realtek, start sysa i jednego relatek nie ma(lub dwoch), w czym problem?
wyswietla mi taki blad
eth0: ERROR while getting interface flags: No such device
SIOCSIFNETMASK: No such device
Failed to dring up eth0
karty: realtek i via rhine II
O co mu chodzi?
Czy jak kompilujemy jadro to musi tam byc zaznaczone cos odnosnie PHY?
Czy aby jadro obsluzylo np. dwie lub wiecej kart lan to musi byc jakas opcja wlaczona do tego (w 2.4 nie bylo tego i smigalo a tu jakies problemy sa)?
Wkompilowalem w jajo iptables, a jak wywolam skrypt gdzie mam regulki pojawiaja mi sie bledy odnosnie iptables
iptables v1.3.6: can't initialize iptables table 'nat' tablica nie istnieje (czy uzyc insmod)
Zaczynam nie lubiec jaja 2.6
Moze mi ktos w tym ponoc?
