tunelowanie po
Gordon1x
tunelowanie połączeń - skrypt w Pythonie i błąd okresowy
Post autor: Gordon1x »
Podczas działania skryptu co pewien okres pojawia się błąd:
Unhandled exception in thread started by
Traceback (most recent call last):
  File "./tunnel.py", line 46, in Recv
    self.CloseTunnel()
  File "./tunnel.py", line 24, in CloseTunnel
    self.plugins.sock.shutdown(1)
  File "<string>", line 1, in shutdown
socket.error: (107, 'Transport endpoint is not connected')
Kod całego skryptu:
#!/usr/bin/python
from thread import start_new_thread
from socket import *
LEN_RECV = 262144
in_addr = '0.0.0.0'
in_port = 80
out_addr = '127.0.0.1'
out_port = 81
drukuj = 'nie'
class new_plug_in:
 def __init__(self):
  self.sock = 0
  self.send_to = 1
  self.plugins = []
  self.description = ''
 def CloseTunnel(self):
  self.plugins[self.send_to].sock.shutdown(1)
  self.plugins[self.send_to].sock.close()
 def Send(self, data):
  try:
   self.sock.send(data)
  except:
   self.CloseTunnel()
 def Recv(self):
  while(1):
   try:
    data = self.sock.recv(LEN_RECV)
    if(len(data) == 0):
     self.CloseTunnel()
     return
    if(drukuj == 'tak'):
     print self.description
     print HexDump(data)
     return
    self.plugins[self.send_to].Send(data)
   except:
    self.CloseTunnel()
    return
 def Run(self):
  if(len(self.plugins) == 0):
   self.plugins.append(self)
   try:
    s = socket(AF_INET, SOCK_STREAM)
    s.connect((out_addr, out_port))
   except:
    s.close()
    self.sock.close()
    return
   tunnel_out = new_plug_in()
   tunnel_out.sock = s
   tunnel_out.send_to = 0
   self.plugins.append(tunnel_out)
   self.description = '[CLIENT]'
   tunnel_out.description = '[SERVER]'
   tunnel_out.plugins = self.plugins
   tunnel_out.Run()
  start_new_thread(self.Recv, ())
def HexDump(data):
 a = -1
 out = '-' * 59 + '\n'
 out += '0x00000000: '
 for i in range(0, len(data)):
  a += 1
  if(a == 16):
   out += '\n0x%08x: ' % (i)
   a = 0
  out += '%02x ' % (ord(data[i]))
 out += '\n' + ('-' * 59)
 return out
def AcceptConnect(cl, addr):
  print "Connection accepted from: %s" % (addr[0])
  return
 tunnel_in = new_plug_in()
 tunnel_in.sock = cl
 tunnel_in.Run()
def InitServer(bind_addr, bind_port):
 s.bind((bind_addr, bind_port))
 print "Listen on %s:%d..." % (bind_addr, bind_port)
 s.listen(1)
 while(1):
  cl, addr = s.accept()
  start_new_thread(AcceptConnect, (cl, addr,))
 s.close()
InitServer(in_addr, in_port)
Nie bardzo wiem jak rozwiązać ten problem więc proszę o pomoc.
