/var/log/boot
Thu Aug 14 09:03:17 2008: .
Thu Aug 14 09:03:17 2008: Setting parameters of disc: (none).
Thu Aug 14 09:03:17 2008: Setting the system clock.
Thu Aug 14 09:03:17 2008: Activating swap...done.
Thu Aug 14 09:03:17 2008: Checking root file system...fsck 1.41.0 (10-Jul-2008)
Thu Aug 14 09:03:17 2008: /dev/hdc3: clean, 133611/366480 files, 1021552/1463923 blocks
Thu Aug 14 09:03:17 2008: done.
Thu Aug 14 09:03:17 2008: Cleaning up ifupdown....
Thu Aug 14 09:03:17 2008: Loading kernel modules...done.
Thu Aug 14 09:03:17 2008: Checking file systems...fsck 1.41.0 (10-Jul-2008)
Thu Aug 14 09:03:17 2008: /dev/hdc4: clean, 15456/257024 files, 784931/1026151 blocks
Thu Aug 14 09:03:17 2008: Setting kernel variables (/etc/sysctl.conf)...done.
Thu Aug 14 09:03:17 2008: Mounting local filesystems...done.
Thu Aug 14 09:03:17 2008: Activating swapfile swap...done.
Thu Aug 14 09:03:18 2008: Setting up networking....
Thu Aug 14 09:03:18 2008: Configuring network interfaces...done.
Thu Aug 14 09:03:18 2008: Starting portmap daemon....
Thu Aug 14 09:03:18 2008: Starting NFS common utilities: statd.
Thu Aug 14 09:03:19 2008: Setting sensors limits.
Thu Aug 14 09:03:19 2008: Setting console screen modes and fonts.
Thu Aug 14 09:03:19 2008: ^[]R^[[9;30]^[[14;30]Setting up ALSA...done.
Thu Aug 14 09:03:19 2008: INIT: Entering runlevel: 2
Thu Aug 14 09:03:20 2008: Starting enhanced syslogd: rsyslogd.
Thu Aug 14 09:03:20 2008: Loading ACPI modules....
Thu Aug 14 09:03:20 2008: Starting ACPI services....
Thu Aug 14 09:03:20 2008: Starting system message bus: dbus.
Thu Aug 14 09:03:20 2008: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Thu Aug 14 09:03:21 2008: Starting Common Unix Printing System: cupsd.
Thu Aug 14 09:03:22 2008: Starting DirMngr: dirmngr.
Thu Aug 14 09:03:22 2008: Starting MTA: exim4.
Thu Aug 14 09:03:23 2008: Starting LAN Information Server: lisa.
Thu Aug 14 09:03:23 2008: Starting NFS common utilities: statd.
Thu Aug 14 09:03:23 2008: Starting internet superserver: inetd.
Thu Aug 14 09:03:23 2008: saned disabled; edit /etc/default/saned
Thu Aug 14 09:03:23 2008: Starting file alteration monitor: FAM.
Thu Aug 14 09:03:23 2008: Starting Hardware abstraction layer: hald.
Thu Aug 14 09:03:28 2008: Starting deferred execution scheduler: atd.
Thu Aug 14 09:03:28 2008: Starting periodic command scheduler: crond.
Thu Aug 14 09:03:28 2008: Starting MLDonkey: mlnet configuration file prevent mlnet to be started (use force-start).
Thu Aug 14 09:03:29 2008: Starting K Display Manager: kdm.
I jeszcze jedno. Czemu jest większy transfer podczas kopiowania z partycji ext3 na ntfs i odwrotnie niż na partycje ext3 do ext3.
Zamieszczam jeszcze log z /var/log/messages
[ Dodano: 2008-08-17, 12:56 ]
Dzisiaj było znowu spr. dysku
boot
Sun Aug 17 12:49:52 2008: .
Sun Aug 17 12:49:52 2008: Setting parameters of disc: (none).
Sun Aug 17 12:49:52 2008: Setting the system clock.
Sun Aug 17 12:49:52 2008: Activating swap...done.
Sun Aug 17 12:49:52 2008: Checking root file system...fsck 1.41.0 (10-Jul-2008)
Sun Aug 17 12:49:52 2008: /dev/hdc3 has been mounted 23 times without being checked, check forced.
Sun Aug 17 12:49:52 2008: \002/dev/hdc3: 133999/366480 files (1.3% non-contiguous), 1039970/1463923 blocks
Sun Aug 17 12:49:53 2008: done.
Sun Aug 17 12:49:53 2008: Setting the system clock.
Sun Aug 17 12:49:53 2008: Cleaning up ifupdown....
Sun Aug 17 12:49:53 2008: Loading kernel modules...done.
Sun Aug 17 12:49:53 2008: Checking file systems...fsck 1.41.0 (10-Jul-2008)
Sun Aug 17 12:49:53 2008: /dev/hdc4: clean, 15768/257024 files, 893663/1026151 blocks
Sun Aug 17 12:49:53 2008: Setting kernel variables (/etc/sysctl.conf)...done.
Sun Aug 17 12:49:53 2008: Mounting local filesystems...done.
Sun Aug 17 12:49:54 2008: Activating swapfile swap...done.
Sun Aug 17 12:49:54 2008: Setting up networking....
Sun Aug 17 12:49:54 2008: Configuring network interfaces...done.
Sun Aug 17 12:49:54 2008: Starting portmap daemon....
Sun Aug 17 12:49:54 2008: Starting NFS common utilities: statd.
Sun Aug 17 12:49:55 2008: Setting sensors limits.
Sun Aug 17 12:49:55 2008: Setting console screen modes and fonts.
Sun Aug 17 12:49:55 2008: ^[]R^[[9;30]^[[14;30]Setting up ALSA...done.
Sun Aug 17 12:49:56 2008: INIT: Entering runlevel: 2
Sun Aug 17 12:49:56 2008: Starting enhanced syslogd: rsyslogd.
Sun Aug 17 12:49:56 2008: Loading ACPI modules....
Sun Aug 17 12:49:56 2008: Starting ACPI services....
Sun Aug 17 12:49:57 2008: Starting system message bus: dbus.
Sun Aug 17 12:49:57 2008: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Sun Aug 17 12:49:57 2008: Starting Common Unix Printing System: cupsd.
Sun Aug 17 12:49:58 2008: Starting DirMngr: dirmngr.
Sun Aug 17 12:49:58 2008: Starting MTA: exim4.
Sun Aug 17 12:49:58 2008: Starting LAN Information Server: lisa.
Sun Aug 17 12:49:58 2008: Starting NFS common utilities: statd.
Sun Aug 17 12:49:58 2008: Starting internet superserver: inetd.
Sun Aug 17 12:49:59 2008: saned disabled; edit /etc/default/saned
Sun Aug 17 12:49:59 2008: Starting file alteration monitor: FAM.
Sun Aug 17 12:49:59 2008: Starting Hardware abstraction layer: hald.
Sun Aug 17 12:50:05 2008: Starting deferred execution scheduler: atd.
Sun Aug 17 12:50:05 2008: Starting periodic command scheduler: crond.
Sun Aug 17 12:50:05 2008: Starting MLDonkey: mlnet configuration file prevent mlnet to be started (use force-start).
Sun Aug 17 12:50:05 2008: Starting K Display Manager: kdm.
Sun Aug 17 12:50:06 2008:
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-provided physical RAM map:
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 0000000000100000 - 000000002fef0000 (usable)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 000000002fef0000 - 000000002fef3000 (ACPI NVS)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 000000002fef3000 - 000000002ff00000 (ACPI data)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Aug 17 12:49:56 debian kernel: [ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
Aug 17 12:49:56 debian kernel: [ 0.000000] 766MB LOWMEM available.
Aug 17 12:49:56 debian kernel: [ 0.000000] found SMP MP-table at [c00f5d00] 000f5d00
Aug 17 12:49:56 debian kernel: [ 0.000000] Zone PFN ranges:
Aug 17 12:49:56 debian kernel: [ 0.000000] DMA 0 -> 4096
Aug 17 12:49:56 debian kernel: [ 0.000000] Normal 4096 -> 196336
Aug 17 12:49:56 debian kernel: [ 0.000000] Movable zone start PFN for each node
Aug 17 12:49:56 debian kernel: [ 0.000000] early_node_map[1] active PFN ranges
Aug 17 12:49:56 debian kernel: [ 0.000000] 0: 0 -> 196336
Aug 17 12:49:56 debian kernel: [ 0.000000] DMI 2.2 present.
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: RSDP 000F77A0, 0014 (r0 KT600 )
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: RSDT 2FEF3000, 002C (r1 KT600 AWRDACPI 42302E31 AWRD 0)
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: FACP 2FEF3040, 0074 (r1 KT600 AWRDACPI 42302E31 AWRD 0)
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: DSDT 2FEF30C0, 4B2F (r1 KT600 AWRDACPI 1000 MSFT 100000E)
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: FACS 2FEF0000, 0040
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: APIC 2FEF7C00, 005A (r1 KT600 AWRDACPI 42302E31 AWRD 0)
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: PM-Timer IO Port: 0x4008
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Aug 17 12:49:56 debian kernel: [ 0.000000] IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Aug 17 12:49:56 debian kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 dfl dfl)
Aug 17 12:49:56 debian kernel: [ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
Aug 17 12:49:56 debian kernel: [ 0.000000] Using ACPI (MADT) for SMP configuration information
Aug 17 12:49:56 debian kernel: [ 0.000000] Allocating PCI resources starting at 30000000 (gap: 2ff00000:ced00000)
Aug 17 12:49:56 debian kernel: [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
Aug 17 12:49:56 debian kernel: [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
Aug 17 12:49:56 debian kernel: [ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
Aug 17 12:49:56 debian kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 194802
Aug 17 12:49:56 debian kernel: [ 0.000000] Kernel command line: root=/dev/hdc3 ro quiet
Aug 17 12:49:56 debian kernel: [ 0.000000] Enabling fast FPU save and restore... done.
Aug 17 12:49:56 debian kernel: [ 0.000000] Enabling unmasked SIMD FPU exception support... done.
Aug 17 12:49:56 debian kernel: [ 0.000000] Initializing CPU#0
Aug 17 12:49:56 debian kernel: [ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
Aug 17 12:49:56 debian kernel: [ 0.000000] Detected 1683.715 MHz processor.
Aug 17 12:49:56 debian kernel: [ 0.004000] Console: colour VGA+ 80x25
Aug 17 12:49:56 debian kernel: [ 0.004000] console [tty0] enabled
Aug 17 12:49:56 debian kernel: [ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Aug 17 12:49:56 debian kernel: [ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 17 12:49:56 debian kernel: [ 0.004000] Memory: 767896k/785344k available (1693k kernel code, 16780k reserved, 746k data, 320k init, 0k highmem)
Aug 17 12:49:56 debian kernel: [ 0.004000] virtual kernel memory layout:
Aug 17 12:49:56 debian kernel: [ 0.004000] fixmap : 0xfffb3000 - 0xfffff000 ( 304 kB)
Aug 17 12:49:56 debian kernel: [ 0.004000] vmalloc : 0xf0800000 - 0xfffb1000 ( 247 MB)
Aug 17 12:49:56 debian kernel: [ 0.004000] lowmem : 0xc0000000 - 0xefef0000 ( 766 MB)
Aug 17 12:49:56 debian kernel: [ 0.004000] .init : 0xc0364000 - 0xc03b4000 ( 320 kB)
Aug 17 12:49:56 debian kernel: [ 0.004000] .data : 0xc02a74a3 - 0xc0362000 ( 746 kB)
Aug 17 12:49:56 debian kernel: [ 0.004000] .text : 0xc0100000 - 0xc02a74a3 (1693 kB)
Aug 17 12:49:56 debian kernel: [ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
Aug 17 12:49:56 debian kernel: [ 0.084112] Calibrating delay using timer specific routine.. 3371.61 BogoMIPS (lpj=6743234)
Aug 17 12:49:56 debian kernel: [ 0.084154] Security Framework initialized
Aug 17 12:49:56 debian kernel: [ 0.084162] SELinux: Disabled at boot.
Aug 17 12:49:56 debian kernel: [ 0.084167] Capability LSM initialized
Aug 17 12:49:56 debian kernel: [ 0.084182] Mount-cache hash table entries: 512
Aug 17 12:49:56 debian kernel: [ 0.084345] Initializing cgroup subsys ns
Aug 17 12:49:56 debian kernel: [ 0.084351] Initializing cgroup subsys cpuacct
Aug 17 12:49:56 debian kernel: [ 0.084354] Initializing cgroup subsys devices
Aug 17 12:49:56 debian kernel: [ 0.084374] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
Aug 17 12:49:56 debian kernel: [ 0.084377] CPU: L2 Cache: 256K (64 bytes/line)
Aug 17 12:49:56 debian kernel: [ 0.084391] CPU: AMD Sempron(tm) 2400+ stepping 01
Aug 17 12:49:56 debian kernel: [ 0.084398] Checking 'hlt' instruction... OK.
Aug 17 12:49:56 debian kernel: [ 0.101680] Freeing SMP alternatives: 0k freed
Aug 17 12:49:56 debian kernel: [ 0.101688] ACPI: Core revision 20080321
Aug 17 12:49:56 debian kernel: [ 0.116007] ENABLING IO-APIC IRQs
Aug 17 12:49:56 debian kernel: [ 0.116007] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Aug 17 12:49:56 debian kernel: [ 0.156009] net_namespace: 652 bytes
Aug 17 12:49:56 debian kernel: [ 0.156009] Booting paravirtualized kernel on bare hardware
Aug 17 12:49:56 debian kernel: [ 0.156009] NET: Registered protocol family 16
Aug 17 12:49:56 debian kernel: [ 0.156009] EISA bus registered
Aug 17 12:49:56 debian kernel: [ 0.156009] ACPI: bus type pci registered
Aug 17 12:49:56 debian kernel: [ 0.163441] PCI: PCI BIOS revision 2.10 entry at 0xfaf50, last bus=1
Aug 17 12:49:56 debian kernel: [ 0.163444] PCI: Using configuration type 1 for base access
Aug 17 12:49:56 debian kernel: [ 0.163458] Setting up standard PCI resources
Aug 17 12:49:56 debian kernel: [ 0.171219] ACPI: Interpreter enabled
Aug 17 12:49:56 debian kernel: [ 0.171227] ACPI: (supports S0 S1 S4 S5)
Aug 17 12:49:56 debian kernel: [ 0.171251] ACPI: Using IOAPIC for interrupt routing
Aug 17 12:49:56 debian kernel: [ 0.178123] ACPI: PCI Root Bridge [PCI0] (0000:00)
Aug 17 12:49:56 debian kernel: [ 0.206469] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12)
Aug 17 12:49:56 debian kernel: [ 0.206685] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 *11 12)
Aug 17 12:49:56 debian kernel: [ 0.206901] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12) *5
Aug 17 12:49:56 debian kernel: [ 0.207123] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 6 7 10 11 12)
Aug 17 12:49:56 debian kernel: [ 0.207313] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Aug 17 12:49:56 debian kernel: [ 0.207491] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Aug 17 12:49:56 debian kernel: [ 0.207666] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Aug 17 12:49:56 debian kernel: [ 0.207842] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Aug 17 12:49:56 debian kernel: [ 0.208131] ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *11
Aug 17 12:49:56 debian kernel: [ 0.208349] ACPI: PCI Interrupt Link [ALKB] (IRQs *21)
Aug 17 12:49:56 debian kernel: [ 0.208565] ACPI: PCI Interrupt Link [ALKC] (IRQs *22)
Aug 17 12:49:56 debian kernel: [ 0.208823] ACPI: PCI Interrupt Link [ALKD] (IRQs *23)
Aug 17 12:49:56 debian kernel: [ 0.209175] ACPI: Power Resource [PFAN] (on)
Aug 17 12:49:56 debian kernel: [ 0.209265] Linux Plug and Play Support v0.97 (c) Adam Belay
Aug 17 12:49:56 debian kernel: [ 0.209308] pnp: PnP ACPI init
Aug 17 12:49:56 debian kernel: [ 0.209318] ACPI: bus type pnp registered
Aug 17 12:49:56 debian kernel: [ 0.213657] pnp: PnP ACPI: found 13 devices
Aug 17 12:49:56 debian kernel: [ 0.213661] ACPI: ACPI bus type pnp unregistered
Aug 17 12:49:56 debian kernel: [ 0.213666] PnPBIOS: Disabled by ACPI PNP
Aug 17 12:49:56 debian kernel: [ 0.214009] PCI: Using ACPI for IRQ routing
Aug 17 12:49:56 debian kernel: [ 0.214261] ACPI: RTC can wake from S4
Aug 17 12:49:56 debian kernel: [ 0.214295] system 00:00: iomem range 0xcd000-0xcffff has been reserved
Aug 17 12:49:56 debian kernel: [ 0.214299] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214303] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214307] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214311] system 00:00: iomem range 0x2fef0000-0x2fefffff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214315] system 00:00: iomem range 0xffff0000-0xffffffff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214319] system 00:00: iomem range 0x0-0x9ffff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214322] system 00:00: iomem range 0x100000-0x2feeffff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214326] system 00:00: iomem range 0xfec00000-0xfec00fff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214330] system 00:00: iomem range 0xfee00000-0xfee00fff could not be reserved
Aug 17 12:49:56 debian kernel: [ 0.214334] system 00:00: iomem range 0xfff80000-0xfffeffff has been reserved
Aug 17 12:49:56 debian kernel: [ 0.214343] system 00:02: ioport range 0x4000-0x407f has been reserved
Aug 17 12:49:56 debian kernel: [ 0.214347] system 00:02: ioport range 0x5000-0x500f has been reserved
Aug 17 12:49:56 debian kernel: [ 0.214359] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
Aug 17 12:49:56 debian kernel: [ 0.214362] system 00:03: ioport range 0x294-0x297 has been reserved
Aug 17 12:49:56 debian kernel: [ 0.244866] PCI: Bridge: 0000:00:01.0
Aug 17 12:49:56 debian kernel: [ 0.244869] IO window: a000-afff
Aug 17 12:49:56 debian kernel: [ 0.244874] MEM window: 0xe8000000-0xe80fffff
Aug 17 12:49:56 debian kernel: [ 0.244879] PREFETCH window: 0x00000000d0000000-0x00000000dfffffff
Aug 17 12:49:56 debian kernel: [ 0.244919] NET: Registered protocol family 2
Aug 17 12:49:56 debian kernel: [ 0.245017] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug 17 12:49:56 debian kernel: [ 0.245438] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Aug 17 12:49:56 debian kernel: [ 0.247350] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
Aug 17 12:49:56 debian kernel: [ 0.247893] TCP: Hash tables configured (established 131072 bind 65536)
Aug 17 12:49:56 debian kernel: [ 0.247896] TCP reno registered
Aug 17 12:49:56 debian kernel: [ 0.248039] NET: Registered protocol family 1
Aug 17 12:49:56 debian kernel: [ 0.248197] checking if image is initramfs... it is
Aug 17 12:49:56 debian kernel: [ 0.896477] Freeing initrd memory: 6660k freed
Aug 17 12:49:56 debian kernel: [ 0.897342] audit: initializing netlink socket (disabled)
Aug 17 12:49:56 debian kernel: [ 0.897363] type=2000 audit(1218977318.896:1): initialized
Aug 17 12:49:56 debian kernel: [ 0.897503] Total HugeTLB memory allocated, 0
Aug 17 12:49:56 debian kernel: [ 0.897576] VFS: Disk quotas dquot_6.5.1
Aug 17 12:49:56 debian kernel: [ 0.897614] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 17 12:49:56 debian kernel: [ 0.897659] msgmni has been set to 1513
Aug 17 12:49:56 debian kernel: [ 0.897782] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Aug 17 12:49:56 debian kernel: [ 0.897787] io scheduler noop registered
Aug 17 12:49:56 debian kernel: [ 0.897790] io scheduler anticipatory registered
Aug 17 12:49:56 debian kernel: [ 0.897792] io scheduler deadline registered
Aug 17 12:49:56 debian kernel: [ 0.897801] io scheduler cfq registered (default)
Aug 17 12:49:56 debian kernel: [ 0.897814] PCI: VIA PCI bridge detected.Disabling DAC.
Aug 17 12:49:56 debian kernel: [ 0.897884] pci 0000:00:11.0: Bypassing VIA 8237 APIC De-Assert Message
Aug 17 12:49:56 debian kernel: [ 0.898345] isapnp: Scanning for PnP cards...
Aug 17 12:49:56 debian kernel: [ 1.252314] isapnp: No Plug & Play device found
Aug 17 12:49:56 debian kernel: [ 1.255454] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Aug 17 12:49:56 debian kernel: [ 1.255588] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Aug 17 12:49:56 debian kernel: [ 1.256093] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Aug 17 12:49:56 debian kernel: [ 1.257890] brd: module loaded
Aug 17 12:49:56 debian kernel: [ 1.258023] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Aug 17 12:49:56 debian kernel: [ 1.258441] serio: i8042 KBD port at 0x60,0x64 irq 1
Aug 17 12:49:56 debian kernel: [ 1.258448] serio: i8042 AUX port at 0x60,0x64 irq 12
Aug 17 12:49:56 debian kernel: [ 1.258635] mice: PS/2 mouse device common for all mice
Aug 17 12:49:56 debian kernel: [ 1.258801] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
Aug 17 12:49:56 debian kernel: [ 1.258835] rtc0: alarms up to one year, y3k
Aug 17 12:49:56 debian kernel: [ 1.258967] EISA: Probing bus 0 at eisa.0
Aug 17 12:49:56 debian kernel: [ 1.258988] Cannot allocate resource for EISA slot 4
Aug 17 12:49:56 debian kernel: [ 1.258991] Cannot allocate resource for EISA slot 5
Aug 17 12:49:56 debian kernel: [ 1.259005] EISA: Detected 0 cards.
Aug 17 12:49:56 debian kernel: [ 1.259009] cpuidle: using governor ladder
Aug 17 12:49:56 debian kernel: [ 1.259011] cpuidle: using governor menu
Aug 17 12:49:56 debian kernel: [ 1.259018] No iBFT detected.
Aug 17 12:49:56 debian kernel: [ 1.259597] TCP cubic registered
Aug 17 12:49:56 debian kernel: [ 1.259601] NET: Registered protocol family 17
Aug 17 12:49:56 debian kernel: [ 1.259611] Using IPI Shortcut mode
Aug 17 12:49:56 debian kernel: [ 1.259762] registered taskstats version 1
Aug 17 12:49:56 debian kernel: [ 1.259962] rtc_cmos 00:05: setting system clock to 2008-08-17 12:48:40 UTC (1218977320)
Aug 17 12:49:56 debian kernel: [ 1.260424] Freeing unused kernel memory: 320k freed
Aug 17 12:49:56 debian kernel: [ 1.283617] input: AT Translated Set 2 keyboard as /class/input/input0
Aug 17 12:49:56 debian kernel: [ 1.377945] ACPI: PNP0C0B:00 is registered as cooling_device0
Aug 17 12:49:56 debian kernel: [ 1.377954] ACPI: Fan [FAN] (on)
Aug 17 12:49:56 debian kernel: [ 1.384798] ACPI: CPU0 (power states: C1[C1] C2[C2])
Aug 17 12:49:56 debian kernel: [ 1.384859] ACPI: ACPI0007:00 is registered as cooling_device1
Aug 17 12:49:56 debian kernel: [ 1.387998] ACPI: LNXTHERM:01 is registered as thermal_zone0
Aug 17 12:49:56 debian kernel: [ 1.389127] ACPI: Thermal Zone [THRM] (41 C)
Aug 17 12:49:56 debian kernel: [ 2.146768] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
Aug 17 12:49:56 debian kernel: [ 2.165973] 8139too Fast Ethernet driver 0.9.28
Aug 17 12:49:56 debian kernel: [ 2.166026] ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 18
Aug 17 12:49:56 debian kernel: [ 2.166621] eth0: RealTek RTL8139 at 0xb000, 00:0a:cd:11:14:e5, IRQ 18
Aug 17 12:49:56 debian kernel: [ 2.179261] No dock devices found.
Aug 17 12:49:56 debian kernel: [ 2.208357] SCSI subsystem initialized
Aug 17 12:49:56 debian kernel: [ 2.284124] usbcore: registered new interface driver usbfs
Aug 17 12:49:56 debian kernel: [ 2.284166] usbcore: registered new interface driver hub
Aug 17 12:49:56 debian kernel: [ 2.284232] usbcore: registered new device driver usb
Aug 17 12:49:56 debian kernel: [ 2.285625] USB Universal Host Controller Interface driver v3.0
Aug 17 12:49:56 debian kernel: [ 2.286022] ACPI: PCI Interrupt Link [ALKB] enabled at IRQ 21
Aug 17 12:49:56 debian kernel: [ 2.286033] ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
Aug 17 12:49:56 debian kernel: [ 2.286048] uhci_hcd 0000:00:10.0: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.286216] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
Aug 17 12:49:56 debian kernel: [ 2.286254] uhci_hcd 0000:00:10.0: irq 21, io base 0x0000d000
Aug 17 12:49:56 debian kernel: [ 2.286371] usb usb1: configuration #1 chosen from 1 choice
Aug 17 12:49:56 debian kernel: [ 2.286407] hub 1-0:1.0: USB hub found
Aug 17 12:49:56 debian kernel: [ 2.286420] hub 1-0:1.0: 2 ports detected
Aug 17 12:49:56 debian kernel: [ 2.367321] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
Aug 17 12:49:56 debian kernel: [ 2.367329] via-rhine: Broken BIOS detected, avoid_D3 enabled.
Aug 17 12:49:56 debian kernel: [ 2.388186] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
Aug 17 12:49:56 debian kernel: [ 2.388191] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 17 12:49:56 debian kernel: [ 2.388195] usb usb1: Product: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.388198] usb usb1: Manufacturer: Linux 2.6.26-1-486 uhci_hcd
Aug 17 12:49:56 debian kernel: [ 2.388200] usb usb1: SerialNumber: 0000:00:10.0
Aug 17 12:49:56 debian kernel: [ 2.388296] ACPI: PCI Interrupt 0000:00:10.1[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
Aug 17 12:49:56 debian kernel: [ 2.388313] uhci_hcd 0000:00:10.1: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.388345] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
Aug 17 12:49:56 debian kernel: [ 2.388371] uhci_hcd 0000:00:10.1: irq 21, io base 0x0000d400
Aug 17 12:49:56 debian kernel: [ 2.388484] usb usb2: configuration #1 chosen from 1 choice
Aug 17 12:49:56 debian kernel: [ 2.388520] hub 2-0:1.0: USB hub found
Aug 17 12:49:56 debian kernel: [ 2.388534] hub 2-0:1.0: 2 ports detected
Aug 17 12:49:56 debian kernel: [ 2.493043] Floppy drive(s): fd0 is 1.44M
Aug 17 12:49:56 debian kernel: [ 2.494109] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Aug 17 12:49:56 debian kernel: [ 2.494113] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 17 12:49:56 debian kernel: [ 2.494117] usb usb2: Product: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.494120] usb usb2: Manufacturer: Linux 2.6.26-1-486 uhci_hcd
Aug 17 12:49:56 debian kernel: [ 2.494122] usb usb2: SerialNumber: 0000:00:10.1
Aug 17 12:49:56 debian kernel: [ 2.494198] ACPI: PCI Interrupt 0000:00:10.2[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
Aug 17 12:49:56 debian kernel: [ 2.494212] uhci_hcd 0000:00:10.2: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.494245] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
Aug 17 12:49:56 debian kernel: [ 2.494270] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
Aug 17 12:49:56 debian kernel: [ 2.494373] usb usb3: configuration #1 chosen from 1 choice
Aug 17 12:49:56 debian kernel: [ 2.494409] hub 3-0:1.0: USB hub found
Aug 17 12:49:56 debian kernel: [ 2.494419] hub 3-0:1.0: 2 ports detected
Aug 17 12:49:56 debian kernel: [ 2.511902] FDC 0 is a post-1991 82077
Aug 17 12:49:56 debian kernel: [ 2.580004] Marking TSC unstable due to: TSC halts in idle.
Aug 17 12:49:56 debian kernel: [ 2.596634] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Aug 17 12:49:56 debian kernel: [ 2.596639] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 17 12:49:56 debian kernel: [ 2.596642] usb usb3: Product: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.596645] usb usb3: Manufacturer: Linux 2.6.26-1-486 uhci_hcd
Aug 17 12:49:56 debian kernel: [ 2.596647] usb usb3: SerialNumber: 0000:00:10.2
Aug 17 12:49:56 debian kernel: [ 2.596723] ACPI: PCI Interrupt 0000:00:10.3[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
Aug 17 12:49:56 debian kernel: [ 2.596738] uhci_hcd 0000:00:10.3: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.596772] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
Aug 17 12:49:56 debian kernel: [ 2.596798] uhci_hcd 0000:00:10.3: irq 21, io base 0x0000dc00
Aug 17 12:49:56 debian kernel: [ 2.596909] usb usb4: configuration #1 chosen from 1 choice
Aug 17 12:49:56 debian kernel: [ 2.596947] hub 4-0:1.0: USB hub found
Aug 17 12:49:56 debian kernel: [ 2.596961] hub 4-0:1.0: 2 ports detected
Aug 17 12:49:56 debian kernel: [ 2.700410] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Aug 17 12:49:56 debian kernel: [ 2.700415] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 17 12:49:56 debian kernel: [ 2.700419] usb usb4: Product: UHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 2.700421] usb usb4: Manufacturer: Linux 2.6.26-1-486 uhci_hcd
Aug 17 12:49:56 debian kernel: [ 2.700424] usb usb4: SerialNumber: 0000:00:10.3
Aug 17 12:49:56 debian kernel: [ 2.700876] ACPI: PCI Interrupt Link [ALKA] BIOS reported IRQ 11, using IRQ 20
Aug 17 12:49:56 debian kernel: [ 2.700880] ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
Aug 17 12:49:56 debian kernel: [ 2.700889] ACPI: PCI Interrupt 0000:00:0f.0[B] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 20
Aug 17 12:49:56 debian kernel: [ 2.700958] sata_via 0000:00:0f.0: routed to hard irq line 11
Aug 17 12:49:56 debian kernel: [ 2.701055] scsi0 : sata_via
Aug 17 12:49:56 debian kernel: [ 2.701161] scsi1 : sata_via
Aug 17 12:49:56 debian kernel: [ 2.701200] ata1: SATA max UDMA/133 cmd 0xb400 ctl 0xb800 bmdma 0xc400 irq 20
Aug 17 12:49:56 debian kernel: [ 2.701203] ata2: SATA max UDMA/133 cmd 0xbc00 ctl 0xc000 bmdma 0xc408 irq 20
Aug 17 12:49:56 debian kernel: [ 2.904027] ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
Aug 17 12:49:56 debian kernel: [ 3.108029] ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
Aug 17 12:49:56 debian kernel: [ 3.109370] ACPI: PCI Interrupt 0000:00:10.4[C] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 21
Aug 17 12:49:56 debian kernel: [ 3.109397] ehci_hcd 0000:00:10.4: EHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 3.109457] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
Aug 17 12:49:56 debian kernel: [ 3.109510] ehci_hcd 0000:00:10.4: irq 21, io mem 0xe8102000
Aug 17 12:49:56 debian kernel: [ 3.120074] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Aug 17 12:49:56 debian kernel: [ 3.120199] usb usb5: configuration #1 chosen from 1 choice
Aug 17 12:49:56 debian kernel: [ 3.120242] hub 5-0:1.0: USB hub found
Aug 17 12:49:56 debian kernel: [ 3.120258] hub 5-0:1.0: 8 ports detected
Aug 17 12:49:56 debian kernel: [ 3.224202] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
Aug 17 12:49:56 debian kernel: [ 3.224208] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 17 12:49:56 debian kernel: [ 3.224212] usb usb5: Product: EHCI Host Controller
Aug 17 12:49:56 debian kernel: [ 3.224215] usb usb5: Manufacturer: Linux 2.6.26-1-486 ehci_hcd
Aug 17 12:49:56 debian kernel: [ 3.224217] usb usb5: SerialNumber: 0000:00:10.4
Aug 17 12:49:56 debian kernel: [ 3.231369] Uniform Multi-Platform E-IDE driver
Aug 17 12:49:56 debian kernel: [ 3.231377] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Aug 17 12:49:56 debian kernel: [ 3.232576] ACPI: PCI Interrupt Link [ALKD] enabled at IRQ 23
Aug 17 12:49:56 debian kernel: [ 3.232588] ACPI: PCI Interrupt 0000:00:12.0[A] -> Link [ALKD] -> GSI 23 (level, low) -> IRQ 23
Aug 17 12:49:56 debian kernel: [ 3.236842] eth1: VIA Rhine II at 0x1e400, 00:50:8d:66:09:65, IRQ 23.
Aug 17 12:49:56 debian kernel: [ 3.237547] eth1: MII PHY found at address 1, status 0x7849 advertising 05e1 Link 0000.
Aug 17 12:49:56 debian kernel: [ 3.238737] VP_IDE: IDE controller (0x1106:0x0571 rev 0x06) at PCI slot 0000:00:0f.1
Aug 17 12:49:56 debian kernel: [ 3.238772] ACPI: PCI Interrupt 0000:00:0f.1[A] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 20
Aug 17 12:49:56 debian kernel: [ 3.238787] VP_IDE: not 100% native mode: will probe irqs later
Aug 17 12:49:56 debian kernel: [ 3.238803] VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
Aug 17 12:49:56 debian kernel: [ 3.238815] ide0: BM-DMA at 0xcc00-0xcc07
Aug 17 12:49:56 debian kernel: [ 3.238824] ide1: BM-DMA at 0xcc08-0xcc0f
Aug 17 12:49:56 debian kernel: [ 4.220112] hdc: ST380215A, ATA DISK drive
Aug 17 12:49:56 debian kernel: [ 4.668110] hdd: TSSTcorpCD/DVDW SH-S182D, ATAPI CD/DVD-ROM drive
Aug 17 12:49:56 debian kernel: [ 4.724274] hdc: UDMA/100 mode selected
Aug 17 12:49:56 debian kernel: [ 4.724751] hdd: UDMA/33 mode selected
Aug 17 12:49:56 debian kernel: [ 4.725209] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Aug 17 12:49:56 debian kernel: [ 4.725232] ide1 at 0x170-0x177,0x376 on irq 15
Aug 17 12:49:56 debian kernel: [ 4.761503] hdc: max request size: 512KiB
Aug 17 12:49:56 debian kernel: [ 4.808230] hdc: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=16383/255/63
Aug 17 12:49:56 debian kernel: [ 4.832688] hdc: cache flushes supported
Aug 17 12:49:56 debian kernel: [ 4.832688] hdc: hdc1 hdc2 < hdc5 hdc6 > hdc3 hdc4
Aug 17 12:49:56 debian kernel: [ 4.887455] hdd: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
Aug 17 12:49:56 debian kernel: [ 4.887466] Uniform CD-ROM driver Revision: 3.20
Aug 17 12:49:56 debian kernel: [ 5.570959] PM: Starting manual resume from disk
Aug 17 12:49:56 debian kernel: [ 5.641320] kjournald starting. Commit interval 5 seconds
Aug 17 12:49:56 debian kernel: [ 5.641320] EXT3-fs: mounted filesystem with ordered data mode.
Aug 17 12:49:56 debian kernel: [ 7.412607] udevd version 125 started
Aug 17 12:49:56 debian kernel: [ 8.826889] Linux agpgart interface v0.103
Aug 17 12:49:56 debian kernel: [ 8.871506] agpgart: Detected VIA KT400/KT400A/KT600 chipset
Aug 17 12:49:56 debian kernel: [ 8.879196] agpgart: AGP aperture is 128M @ 0xe0000000
Aug 17 12:49:56 debian kernel: [ 8.893264] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Aug 17 12:49:56 debian kernel: [ 8.899230] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Aug 17 12:49:56 debian kernel: [ 9.029794] Linux video capture interface: v2.00
Aug 17 12:49:56 debian kernel: [ 9.085473] saa7130/34: v4l2 driver version 0.2.14 loaded
Aug 17 12:49:56 debian kernel: [ 9.085536] ACPI: PCI Interrupt 0000:00:0c.0[A] -> GSI 19 (level, low) -> IRQ 19
Aug 17 12:49:56 debian kernel: [ 9.085547] saa7133[0]: found at 0000:00:0c.0, rev: 208, irq: 19, latency: 32, mmio: 0xe8101000
Aug 17 12:49:56 debian kernel: [ 9.085556] saa7133[0]: subsystem: 1461:f31f, board: Avermedia AVerTV GO 007 FM [card=57,autodetected]
Aug 17 12:49:56 debian kernel: [ 9.085569] saa7133[0]: board init: gpio is 807f8
Aug 17 12:49:56 debian kernel: [ 9.085675] input: saa7134 IR (Avermedia AVerTV GO as /class/input/input1
Aug 17 12:49:56 debian kernel: [ 9.390481] input: Power Button (FF) as /class/input/input2
Aug 17 12:49:56 debian kernel: [ 9.419160] ACPI: Power Button (FF) [PWRF]
Aug 17 12:49:56 debian kernel: [ 9.419254] input: Power Button (CM) as /class/input/input3
Aug 17 12:49:56 debian kernel: [ 9.452106] ACPI: Power Button (CM) [PWRB]
Aug 17 12:49:56 debian kernel: [ 9.452201] input: Sleep Button (CM) as /class/input/input4
Aug 17 12:49:56 debian kernel: [ 9.480752] ACPI: Sleep Button (CM) [SLPB]
Aug 17 12:49:56 debian kernel: [ 9.563978] saa7133[0]: i2c eeprom 00: 61 14 1f f3 ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.563990] saa7133[0]: i2c eeprom 10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564019] saa7133[0]: i2c eeprom 20: ff d2 fe ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564028] saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564036] saa7133[0]: i2c eeprom 40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564044] saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564053] saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564061] saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564069] saa7133[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564077] saa7133[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564086] saa7133[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564094] saa7133[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564102] saa7133[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564111] saa7133[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564119] saa7133[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.564127] saa7133[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Aug 17 12:49:56 debian kernel: [ 9.884155] tuner' 0-004b: chip found @ 0x96 (saa7133[0])
Aug 17 12:49:56 debian kernel: [ 9.964044] tda829x 0-004b: setting tuner address to 61
Aug 17 12:49:56 debian kernel: [ 10.060029] tda829x 0-004b: type set to tda8290+75
Aug 17 12:49:56 debian kernel: [ 10.593882] input: PC Speaker as /class/input/input5
Aug 17 12:49:56 debian kernel: [ 11.380728] input: ImExPS/2 Generic Explorer Mouse as /class/input/input6
Aug 17 12:49:56 debian kernel: [ 11.411138] parport_pc 00:0a: reported by Plug and Play ACPI
Aug 17 12:49:56 debian kernel: [ 11.411233] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
Aug 17 12:49:56 debian kernel: [ 14.312323] saa7133[0]: registered device video0 [v4l2]
Aug 17 12:49:56 debian kernel: [ 14.312351] saa7133[0]: registered device vbi0
Aug 17 12:49:56 debian kernel: [ 14.312375] saa7133[0]: registered device radio0
Aug 17 12:49:56 debian kernel: [ 14.378140] ACPI: PCI Interrupt Link [ALKC] enabled at IRQ 22
Aug 17 12:49:56 debian kernel: [ 14.378151] ACPI: PCI Interrupt 0000:00:11.5[C] -> Link [ALKC] -> GSI 22 (level, low) -> IRQ 22
Aug 17 12:49:56 debian kernel: [ 15.972477] Adding 289128k swap on /dev/hdc6. Priority:-1 extents:1 across:289128k
Aug 17 12:49:56 debian kernel: [ 74.292303] EXT3 FS on hdc3, internal journal
Aug 17 12:49:56 debian kernel: [ 74.522422] loop: module loaded
Aug 17 12:49:56 debian kernel: [ 74.849580] kjournald starting. Commit interval 5 seconds
Aug 17 12:49:56 debian kernel: [ 74.849631] EXT3 FS on hdc4, internal journal
Aug 17 12:49:56 debian kernel: [ 74.849631] EXT3-fs: mounted filesystem with ordered data mode.
Aug 17 12:49:56 debian kernel: [ 74.916921] fuse init (API version 7.9)
Aug 17 12:49:56 debian kernel: [ 76.665933] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug 17 12:49:56 debian rsyslogd: [origin software="rsyslogd" swVersion="3.18.2" x-pid="2451" x-info="http://www.rsyslog.com"] restart
Aug 17 12:49:57 debian kernel: [ 78.757943] NET: Registered protocol family 10
Aug 17 12:49:57 debian kernel: [ 78.758550] lo: Disabled Privacy Extensions
Aug 17 12:49:57 debian kernel: [ 78.844083] lp0: using parport0 (interrupt-driven).
Aug 17 12:49:57 debian kernel: [ 78.863193] ppdev: user-space parallel port driver
Aug 17 12:50:06 debian kernel: [ 88.311126] [drm] Initialized drm 1.1.0 20060810
Aug 17 12:50:06 debian kernel: [ 88.324878] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Aug 17 12:50:06 debian kernel: [ 88.324982] [drm] Initialized radeon 1.29.0 20080528 on minor 0
Aug 17 12:50:08 debian kernel: [ 89.884604] agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
Aug 17 12:50:08 debian kernel: [ 89.884632] agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
Aug 17 12:50:08 debian kernel: [ 89.884686] agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
Aug 17 12:50:08 debian kernel: [ 90.342264] [drm] Setting GART location based on new memory map
Aug 17 12:50:08 debian kernel: [ 90.342264] [drm] Loading R200 Microcode
Aug 17 12:50:08 debian kernel: [ 90.342264] [drm] writeback test succeeded in 1 usecs
