braki w xorg
nowy
braki w xorg
Post autor: nowy »
Witam problem polega na tym że mam chyba skopany xorg
# xorg.conf (X.Org X Window System server configuration file)
# package.
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Option "UseFBDev" "true"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
System po instalacji sie nie uruchamia, tj wyświetla się na monitorze napis "SYGNA£ WYJ¦CIOWY POZA ZASIÊGIEM"
próbowałem dpkg-reconfigure xserver-xorg ale to nic nie dało, nie wiem co dalej robic
borlus
Post autor: borlus »
Wygeneruj nowego xorg-a:
X -configure
Zerknij do działu Desktop na tematy przyklejone.
nowy
Post autor: nowy »
wszystko działało dobrze do czasu kiedy zainstalowałem sterowniki do karty graficznej i compiz-fusion, X nie chce wstać
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-3)
Current Operating System: Linux dhcppc1 2.6.25-2-486 #1 Fri Jul 18 17:03:35 UTC 2008 i686
Build Date: 02 August 2008 11:27:26PM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Aug 14 13:06:52 2008
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
(**) RgbPath set to "/etc/X11/rgb"
(**) ModulePath set to "/usr/lib/xorg/modules"
(II) Loader magic: 0x81e3ca0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(--) using VT number 7
(II) PCI: 00:00:0: chip 10de,00e1 card 0000,0000 rev a1 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 10de,00e0 card 1458,0c11 rev a2 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,00e4 card 1458,0c11 rev a1 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,00e7 card 1458,5004 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,00e7 card 1458,5004 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:2: chip 10de,00e8 card 1458,5004 rev a2 class 0c,03,20 hdr 80
(II) PCI: 00:06:0: chip 10de,00ea card 1458,a002 rev a1 class 04,01,00 hdr 00
(II) PCI: 00:08:0: chip 10de,00e5 card 1458,5002 rev a2 class 01,01,8a hdr 00
(II) PCI: 00:0a:0: chip 10de,00e3 card 1458,b002 rev a2 class 01,01,85 hdr 00
(II) PCI: 00:0b:0: chip 10de,00e2 card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:0e:0: chip 10de,00ed card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,00f1 card 10de,027d rev a2 class 03,00,00 hdr 00
(II) PCI: 02:09:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:11:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf2000000 - 0xf4ffffff (0x3000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX
(II) Bus 2: bridge is at (0:14:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX
[1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX
[2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX
[3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf5000000 - 0xf5ffffff (0x1000000) MX
(--) PCI:*(1:0:0) nVidia Corporation NV43 [GeForce 6600 GT] rev 162, Mem @ 0xf2000000/24, 0xe0000000/28, 0xf3000000/24
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xf0000000 from 0xf1ffffff to 0xefffffff
(II) Active PCI resource ranges:
[0] -1 0 0xf5000000 - 0xf50000ff (0x100) MX[B]
[1] -1 0 0xf6001000 - 0xf6001fff (0x1000) MX[B]
[2] -1 0 0xf6005000 - 0xf60050ff (0x100) MX[B]
[3] -1 0 0xf6004000 - 0xf6004fff (0x1000) MX[B]
[4] -1 0 0xf6003000 - 0xf6003fff (0x1000) MX[B]
[5] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[6] -1 0 0xf3000000 - 0xf3ffffff (0x1000000) MX[B](B)
[7] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[8] -1 0 0xf2000000 - 0xf2ffffff (0x1000000) MX[B](B)
[9] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[10] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[11] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[12] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[13] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[14] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[15] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[16] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[17] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[18] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[19] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[20] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[21] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xf5000000 - 0xf50000ff (0x100) MX[B]
[5] -1 0 0xf6001000 - 0xf6001fff (0x1000) MX[B]
[6] -1 0 0xf6005000 - 0xf60050ff (0x100) MX[B]
[7] -1 0 0xf6004000 - 0xf6004fff (0x1000) MX[B]
[8] -1 0 0xf6003000 - 0xf6003fff (0x1000) MX[B]
[9] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[10] -1 0 0xf3000000 - 0xf3ffffff (0x1000000) MX[B](B)
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[12] -1 0 0xf2000000 - 0xf2ffffff (0x1000000) MX[B](B)
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[16] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[17] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[18] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[19] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[20] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[21] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[22] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[23] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[24] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[25] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[26] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[27] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded by default.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 173.14.09 Thu Jun 5 00:07:40 PDT 2008
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "xtrap"
(II) Loading /usr/lib/xorg/modules/extensions//libxtrap.so
(II) Module xtrap: vendor="X.Org Foundation"
(II) Loading extension DEC-XTRAP
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.4.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules/drivers//nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 2.1.10
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
compiled for 1.4.0.90, module version = 1.3.0
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 1.4.0.90, module version = 1.3.1
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
GeForce Go 6150, GeForce Go 6100, GeForce 8800 GTX, GeForce 8800 GTS,
GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
GeForce 8600 GT, GeForce 8600 GT, GeForce 8400 GS, GeForce 9500M GS,
GeForce 8600M GT, GeForce 9650M GS, GeForce 8700M GT, Quadro FX 370,
Quadro NVS 320M, Quadro FX 570M, Quadro FX 1600M, Quadro FX 570,
Quadro FX 1700, GeForce 8400 SE, GeForce 8500 GT, GeForce 8400 GS,
GeForce 8300 GS, GeForce 8400 GS, GeForce 8600M GS, GeForce 8400M GT,
GeForce 8400M GS, GeForce 8400M G, Quadro NVS 140M, Quadro NVS 130M,
Quadro NVS 135M, Quadro FX 360M, GeForce 9300M G, Quadro NVS 290,
GeForce GTX 280, GeForce GTX 260, GeForce 8800 GTS 512,
GeForce 8800 GT, GeForce 9800 GX2, GeForce 8800 GS,
GeForce 8800M GTS, GeForce 8800M GTX, GeForce 8800 GS,
GeForce 9600 GSO, GeForce 8800 GT, GeForce 9800 GTX, Quadro FX 3700,
Quadro FX 3600M, GeForce 9600 GT, GeForce 9600M GT, GeForce 9600M GS,
GeForce 9600M GT, GeForce 9500M G, GeForce 8400 GS, GeForce 9300M GS,
GeForce 9200M GS, GeForce 9300M GS
(II) Primary Device is: PCI 01:00:0
(--) Chipset GeForce 6600 GT found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[19] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[20] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[21] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[22] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[23] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[24] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[25] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[26] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[27] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[28] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[29] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[30] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[31] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[32] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) NV(0): Initializing int10
(WW) NV(0): Bad V_BIOS checksum
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Chipset: "GeForce 6600 GT"
(==) NV(0): Depth 24, (==) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 0.1.0
(==) NV(0): Using HW cursor
(--) NV(0): Linear framebuffer at 0xE0000000
(--) NV(0): MMIO registers at 0xF2000000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module "i2c" already built-in
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) NV(0): I2C bus "DDC" initialized.
(II) NV(0): Probing for analog device on output A...
(--) NV(0): ...found one
(II) NV(0): Probing for analog device on output B...
(II) NV(0): Probing for EDID on I2C bus A...
(II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) NV(0): I2C device "DDC:ddc2" removed.
(II) NV(0): ... none found
(II) NV(0): Probing for EDID on I2C bus B...
(--) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: AIC Model: 6f4 Serial#: 694
(II) NV(0): Year: 2005 Week: 37
(II) NV(0): EDID Version: 1.3
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) NV(0): Sync: Separate Composite SyncOnGreen
(II) NV(0): Max H-Image Size [cm]: horiz.: 34 vert.: 27
(II) NV(0): Gamma: 2.20
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): First detailed timing is preferred mode
(II) NV(0): redX: 0.640 redY: 0.349 greenX: 0.284 greenY: 0.617
(II) NV(0): blueX: 0.142 blueY: 0.067 whiteX: 0.313 whiteY: 0.329
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@67Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@56Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 832x624@75Hz
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): 1280x1024@75Hz
(II) NV(0): 1152x870@75Hz
(II) NV(0): Manufacturer's mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) NV(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
(II) NV(0): #2: hsize: 1280 vsize 1024 refresh: 76 vid: 36993
(II) NV(0): #3: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) NV(0): #4: hsize: 1024 vsize 768 refresh: 60 vid: 16481
(II) NV(0): Supported additional Video Mode:
(II) NV(0): clock: 108.0 MHz Image Size: 338 x 270 mm
(II) NV(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) NV(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) NV(0): Monitor name: A-17
(II) NV(0): Ranges: V min: 55 V max: 77 Hz, H min: 24 H max: 82 kHz, PixClock max 140 MHz
(II) NV(0): Serial No: 53700694
(II) NV(0): EDID (in hex):
(II) NV(0): 00ffffffffffff000523f406b6020000
(II) NV(0): 250f01030e221b78eadc55a359489e24
(II) NV(0): 1150543fef80818081408190714f6140
(II) NV(0): 010101010101302a009851002a403070
(II) NV(0): 1300520e1100001e000000fc00412d31
(II) NV(0): 370a2020202020202020000000fd0037
(II) NV(0): 4d18520e000a202020202020000000ff
(II) NV(0): 0035333730303639340a2020202000ba
(--) NV(0): CRTC 0 appears to have a CRT attached
(II) NV(0): Using CRT on CRTC 0
(II) NV(0): EDID vendor "AIC", prod id 1780
(II) NV(0): Using hsync ranges from config file
(II) NV(0): Using vrefresh ranges from config file
(II) NV(0): Printing DDC gathered Modelines:
(II) NV(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) NV(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
(II) NV(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(II) NV(0): Modeline "640x480"x0.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) NV(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) NV(0): Modeline "1024x768"x0.0 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
(II) NV(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) NV(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) NV(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) NV(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) NV(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) NV(0): Modeline "1280x1024"x59.9 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync (63.7 kHz)
(II) NV(0): Modeline "1280x960"x59.9 101.25 1280 1360 1488 1696 960 963 967 996 -hsync +vsync (59.7 kHz)
(II) NV(0): Modeline "1280x1024"x76.0 140.75 1280 1368 1504 1728 1024 1027 1034 1072 -hsync +vsync (81.5 kHz)
(II) NV(0): Modeline "1152x864"x74.8 104.00 1152 1224 1344 1536 864 867 871 905 -hsync +vsync (67.7 kHz)
(II) NV(0): Modeline "1024x768"x59.9 63.50 1024 1072 1176 1328 768 771 775 798 -hsync +vsync (47.8 kHz)
(--) NV(0): VideoRAM: 131072 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): Monitor0: Using hsync range of 24.00-82.00 kHz
(II) NV(0): Monitor0: Using vrefresh range of 55.00-77.00 Hz
(II) NV(0): Monitor0: Using maximum pixel clock of 140.00 MHz
(II) NV(0): Estimated virtual size for aspect ratio 1.2593 is 1280x1024
(II) NV(0): Clock range: 12.00 to 400.00 MHz
(II) NV(0): Not using default mode "640x350" (vrefresh out of range)
(II) NV(0): Not using default mode "320x175" (vrefresh out of range)
(II) NV(0): Not using default mode "640x400" (vrefresh out of range)
(II) NV(0): Not using default mode "320x200" (vrefresh out of range)
(II) NV(0): Not using default mode "720x400" (vrefresh out of range)
(II) NV(0): Not using default mode "360x200" (vrefresh out of range)
(II) NV(0): Not using default mode "640x480" (vrefresh out of range)
(II) NV(0): Not using default mode "320x240" (vrefresh out of range)
(II) NV(0): Not using default mode "800x600" (vrefresh out of range)
(II) NV(0): Not using default mode "400x300" (vrefresh out of range)
(II) NV(0): Not using default mode "1024x768" (vrefresh out of range)
(II) NV(0): Not using default mode "512x384" (vrefresh out of range)
(II) NV(0): Not using default mode "1280x960" (hsync out of range)
(II) NV(0): Not using default mode "640x480" (hsync out of range)
(II) NV(0): Not using default mode "1280x1024" (hsync out of range)
(II) NV(0): Not using default mode "640x512" (hsync out of range)
(II) NV(0): Not using default mode "1600x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "800x600" (hsync out of range)
(II) NV(0): Not using default mode "1792x1344" (width too large for virtual size)
(II) NV(0): Not using default mode "896x672" (hsync out of range)
(II) NV(0): Not using default mode "1856x1392" (width too large for virtual size)
(II) NV(0): Not using default mode "928x696" (hsync out of range)
(II) NV(0): Not using default mode "1920x1440" (width too large for virtual size)
(II) NV(0): Not using default mode "960x720" (hsync out of range)
(II) NV(0): Not using default mode "1152x864" (vrefresh out of range)
(II) NV(0): Not using default mode "576x432" (vrefresh out of range)
(II) NV(0): Not using default mode "1400x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "700x525" (hsync out of range)
(II) NV(0): Not using default mode "1440x900" (width too large for virtual size)
(II) NV(0): Not using default mode "1600x1024" (width too large for virtual size)
(II) NV(0): Not using default mode "1680x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "1920x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "960x600" (hsync out of range)
(II) NV(0): Not using default mode "2048x1536" (width too large for virtual size)
(II) NV(0): Not using default mode "1024x768" (hsync out of range)
(II) NV(0): Not using driver mode "1280x1024" (mode clock too high)
(--) NV(0): Virtual size is 1280x1024 (pitch 1280)
(**) NV(0): *Driver mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(**) NV(0): *Driver mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(**) NV(0): *Driver mode "1280x1024": 109.0 MHz, 63.7 kHz, 59.9 Hz
(**) NV(0): *Default mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz
(**) NV(0): *Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz
(**) NV(0): *Driver mode "1280x960": 101.2 MHz, 59.7 kHz, 59.9 Hz
(**) NV(0): *Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "1280x800": 83.5 MHz, 49.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x800"x60.0 83.46 1280 1344 1480 1680 800 801 804 828 (49.7 kHz)
(**) NV(0): *Driver mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
(II) NV(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(**) NV(0): *Driver mode "1152x864": 104.0 MHz, 67.7 kHz, 74.8 Hz
(**) NV(0): *Default mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
(**) NV(0): *Default mode "1280x768": 80.1 MHz, 47.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x768"x60.0 80.14 1280 1344 1480 1680 768 769 772 795 (47.7 kHz)
(**) NV(0): *Default mode "1152x768": 65.0 MHz, 44.2 kHz, 54.8 Hz
(II) NV(0): Modeline "1152x768"x54.8 65.00 1152 1178 1314 1472 768 771 777 806 +hsync +vsync (44.2 kHz)
(**) NV(0): *Driver mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(II) NV(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
(**) NV(0): *Driver mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) NV(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(**) NV(0): *Driver mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) NV(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(**) NV(0): *Driver mode "1024x768": 63.5 MHz, 47.8 kHz, 59.9 Hz
(**) NV(0): *Default mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NV(0): *Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NV(0): *Default mode "960x600": 96.6 MHz, 74.5 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "960x600"x60.0 96.58 960 1024 1128 1296 600 600 602 621 doublescan (74.5 kHz)
(**) NV(0): *Driver mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(II) NV(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(**) NV(0): *Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NV(0): *Driver mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(II) NV(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(**) NV(0): *Driver mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) NV(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(**) NV(0): *Driver mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(**) NV(0): *Driver mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(**) NV(0): *Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NV(0): *Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NV(0): *Default mode "800x600": 87.8 MHz, 81.2 kHz, 65.0 Hz (D)
(II) NV(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz)
(**) NV(0): *Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NV(0): *Default mode "800x600": 81.0 MHz, 75.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz)
(**) NV(0): *Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NV(0): *Default mode "840x525": 73.6 MHz, 65.2 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "840x525"x60.1 73.57 840 892 984 1128 525 525 527 543 doublescan (65.2 kHz)
(**) NV(0): *Default mode "700x525": 77.9 MHz, 81.5 kHz, 74.8 Hz (D)
(II) NV(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz)
(**) NV(0): *Default mode "700x525": 75.5 MHz, 77.0 kHz, 70.0 Hz (D)
(II) NV(0): Modeline "700x525"x70.0 75.50 700 732 828 980 525 525 527 550 doublescan +hsync +vsync (77.0 kHz)
(**) NV(0): *Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz)
(**) NV(0): *Default mode "640x512": 67.5 MHz, 80.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz)
(**) NV(0): *Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz)
(**) NV(0): *Default mode "720x450": 54.4 MHz, 56.9 kHz, 60.2 Hz (D)
(II) NV(0): Modeline "720x450"x60.2 54.42 720 736 940 956 450 459 463 473 doublescan +hsync +vsync (56.9 kHz)
(**) NV(0): *Driver mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) NV(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(**) NV(0): *Driver mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
(**) NV(0): *Driver mode "640x480": 30.2 MHz, 35.0 kHz, 66.7 Hz
(II) NV(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(**) NV(0): *Driver mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) NV(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(**) NV(0): *Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NV(0): *Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(**) NV(0): *Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz
(II) NV(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(**) NV(0): *Default mode "640x400": 41.7 MHz, 49.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x400"x60.0 41.73 640 672 740 840 400 400 402 414 doublescan (49.7 kHz)
(**) NV(0): *Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz)
(**) NV(0): *Default mode "640x384": 40.1 MHz, 47.7 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "640x384"x60.1 40.07 640 672 740 840 384 384 386 397 doublescan (47.7 kHz)
(**) NV(0): *Default mode "576x384": 32.5 MHz, 44.2 kHz, 54.8 Hz (D)
(II) NV(0): Modeline "576x384"x54.8 32.50 576 589 657 736 384 385 388 403 doublescan +hsync +vsync (44.2 kHz)
(**) NV(0): *Default mode "512x384": 39.4 MHz, 60.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(II) NV(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz)
(**) NV(0): *Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz)
(**) NV(0): *Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(II) NV(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz)
(**) NV(0): *Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(II) NV(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz)
(**) NV(0): *Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) NV(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz)
(**) NV(0): *Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) NV(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz)
(**) NV(0): *Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) NV(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz)
(**) NV(0): *Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz)
(**) NV(0): *Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(II) NV(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz)
(**) NV(0): *Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz)
(**) NV(0): Display dimensions: (340, 270) mm
(**) NV(0): DPI set to (95, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.2.0
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xf3000000 - 0xf3ffffff (0x1000000) MX[B]
[1] 0 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
[2] 0 0 0xf2000000 - 0xf2ffffff (0x1000000) MX[B]
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xf5000000 - 0xf50000ff (0x100) MX[B]
[8] -1 0 0xf6001000 - 0xf6001fff (0x1000) MX[B]
[9] -1 0 0xf6005000 - 0xf60050ff (0x100) MX[B]
[10] -1 0 0xf6004000 - 0xf6004fff (0x1000) MX[B]
[11] -1 0 0xf6003000 - 0xf6003fff (0x1000) MX[B]
[12] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[13] -1 0 0xf3000000 - 0xf3ffffff (0x1000000) MX[B](B)
[14] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[15] -1 0 0xf2000000 - 0xf2ffffff (0x1000000) MX[B](B)
[16] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[17] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[18] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[22] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[23] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[24] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[25] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[26] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[27] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[28] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[29] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[30] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[31] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[32] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[33] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[34] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[35] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(==) NV(0): Write-combining range (0xe0000000,0x8000000)
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
(**) Option "dpms"
(**) NV(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
(EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
(**) Option "Protocol" "auto"
(**) Mouse0: Device: "/dev/input/mice"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: always reports core events
(**) Option "Device" "/dev/input/mice"
(==) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5 6 7"
(**) Mouse0: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Mouse0: Buttons: 11
(**) Mouse0: Sensitivity: 1
(**) Option "CoreKeyboard"
(**) Keyboard0: always reports core events
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Keyboard0: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(II) evaluating device (Mouse0)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) evaluating device (Keyboard0)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(--) Mouse0: PnP-detected protocol: "ExplorerPS/2"
(II) Mouse0: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list!
[config/hal] couldn't initialise context: (null) ((null))
FreeFontPath: FPE "/usr/share/fonts/X11/misc" refcount is 2, should be 1; fixing.
coś nie tak z czcionką? :-?
