root:/home/darek# apt-get install kdeplasma-addons
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libttf2
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
akonadi-server bsd-mailx exim4 exim4-base exim4-config exim4-daemon-light kdepimlibs-data kdepimlibs5
kdeplasma-addons-data kdeplasma-addons-libs4 libakonadiprivate0 libakonadiprivate1 libdbd-mysql-perl libdbi-perl
libgpgme11 libhtml-template-perl libnet-daemon-perl libplrpc-perl libpth20 libsasl2-modules libterm-readkey-perl
mailx mysql-client-5.0 mysql-server mysql-server-5.0
Suggested packages:
mail-reader eximon4 exim4-doc-html exim4-doc-info libmail-spf-query-perl swaks dbishell gpgsm libipc-sharedcache-perl
libcompress-zlib-perl libsasl2-modules-otp libsasl2-modules-ldap libsasl2-modules-sql libsasl2-modules-gssapi-mit
libsasl2-modules-gssapi-heimdal tinyca
The following NEW packages will be installed:
kdeplasma-addons kdeplasma-addons-data kdeplasma-addons-libs4 libakonadiprivate0 libakonadiprivate1 libdbd-mysql-perl
libdbi-perl libgpgme11 libhtml-template-perl libnet-daemon-perl libplrpc-perl libpth20 libsasl2-modules
libterm-readkey-perl mailx mysql-client-5.0 mysql-server mysql-server-5.0
0 upgraded, 26 newly installed, 0 to remove and 47 not upgraded.
Need to get 45,5MB/45,7MB of archives.
After this operation, 130MB of additional disk space will be used.
Do you want to continue [Y/n]?Mam zainstalowane kde 4.1 z repo experimentala
