Mam drobny problem, mianowicie, dzisiaj wróciłem z tygodniowego wyjazdu, podczas wyjazdu łączyłem się ze swoim komputerem przez VNC, jednak przy włączonym compizie strasznie wolno chodziło, więc wyłączyłem. Teraz kiedy uruchamiam wywala wszystkie efekty i standardowo ucina paski stanu. Tak czy siak, wcześniej chodziło bez problemu.
nicon@route66:~$ fusion-icon
* Detected Session: kde
* Searching for installed applications...
* No GLX_EXT_texture_from_pixmap with direct rendering context
... nor with indirect rendering, this isn't going to work!
* Using the GTK Interface
* KWin is already running
* Setting option Loose Binding to True
* Setting option Indirect Rendering to True
* Setting window manager to Compiz
... executing: compiz.real --replace --sm-disable --ignore-desktop-hints ccp --loose-binding --indirect-rendering
compiz.real (core) - Fatal: No GLXFBConfig for default depth, this isn't going to work.
compiz.real (core) - Error: Failed to manage screen: 0
compiz.real (core) - Fatal: No manageable screens found on display :0
* Setting option Loose Binding to False
... executing: compiz.real --replace --sm-disable --ignore-desktop-hints ccp --indirect-rendering
* Setting window manager to KWinKod: Zaznacz cały
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder63) Mon May 19 00:33:37 PDT 2008
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 110.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
Option "TripleBuffer" "true"
Option "no GLXFBConfig for depth 32"
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "DisableGLXRootClipping" "true"
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
