Conky - kompilacja ze źróde
ModY_WzM
Conky - kompilacja ze źródeł
Post autor: ModY_WzM »
Mam problem z skompilowaniem źródeł conky, mam zainstalowane wszystkie potrzebne biblioteki. Wstawiam wynik polecenia ./configure
mody@mody:~/Desktop/conky-1.4.3$ ./configure
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking for correct ltmain.sh version... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.17.2... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for ld used by GCC... /usr/bin/ld
checking for shared library run path origin... ./config.rpath: ./config.rpath: No such file or directory
done
checking for iconv... yes
checking for iconv declaration...
         extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for XOpenDisplay in -lX11... yes
checking for XdbeQueryExtension in -lXext... yes
checking for XDamageQueryExtension in -lXdamage... no
configure: error: Could not find XDamageQueryExtension in -lXdamage
Kaka'
Post autor: Kaka' »
Strzelam:
aptitude install libxdamage-dev libxdamage1 libxdamage1-dbg
PS: nie polecam tego sposobu instalacji conky. Zajrzyj tutaj: http://debian.linux.pl/viewtopic.php?p=6370#6370
ModY_WzM
Teraz pojawił się taki błąd przy kompilacji
Making all in src
make[1]: Entering directory `/home/mody/Desktop/conky/src'
make  all-am
make[2]: Entering directory `/home/mody/Desktop/conky/src'
/bin/sh ../libtool --tag=CC --mode=link gcc  -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include    -I/usr/X11R6/include -I/usr/include/freetype2 -I/usr/X11R6/include   -Wall -W -lpthread -lm -lglib-2.0     -L/usr/X11R6/lib  -lSM -lICE -o conky    common.o conky.o  fs.o hddtemp.o linux.o top.o mail.o mixer.o mpd.o libmpdclient.o libtcp-portmon.o remotec.o remoted.o timed_thread.o x11.o   -lrt -lX11  -lglib-2.0     -L/usr/X11R6/lib -lXext -lXdamage -L/usr/X11R6/lib -lXft -lfreetype -lz -lXrender -lX11 -lfontconfig
gcc -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/X11R6/include -I/usr/include/freetype2 -I/usr/X11R6/include -Wall -W -o conky common.o conky.o fs.o hddtemp.o linux.o top.o mail.o mixer.o mpd.o libmpdclient.o libtcp-portmon.o remotec.o remoted.o timed_thread.o x11.o  -lpthread -lm -L/usr/X11R6/lib -lSM -lICE -lrt /usr/lib/libglib-2.0.so -lXext -lXdamage /usr/lib/libXft.so /usr/lib/libfreetype.so -lz /usr/lib/libXrender.so -lX11 -lfontconfig
conky.o(.text+0x10acd): In function `main_loop':
: undefined reference to `XFixesCreateRegionFromWindow'
conky.o(.text+0x10aee): In function `main_loop':
conky.o(.text+0x11136): In function `main_loop':
: undefined reference to `XFixesSetRegion'
conky.o(.text+0x11158): In function `main_loop':
: undefined reference to `XFixesUnionRegion'
conky.o(.text+0x111a4): In function `main_loop':
conky.o(.text+0x11376): In function `main_loop':
: undefined reference to `XFixesDestroyRegion'
conky.o(.text+0x1138a): In function `main_loop':
collect2: ld returned 1 exit status
make[2]: *** [conky] Błąd 1
make[2]: Leaving directory `/home/mody/Desktop/conky/src'
make[1]: *** [all] Błąd 2
make[1]: Leaving directory `/home/mody/Desktop/conky/src'
make: *** [all-recursive] Błąd 1
