aticonfig --initial
Moj xorg wyglada nastepujaco:
# xorg.conf (X.Org X Window System server configuration file)
# package.
Section "ServerLayout"
Identifier "aticonfig-Layout[all]"
Screen 0 "aticonfig-Screen[0]" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "Configured Video Device"
Option "UseFBDev" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Druga sprawa: postanowilem troche zmienic swoj pulpit i zachcialo mi sie pobawic comiz-fusion no i mam takie pytanie" czy compiz fusion bedzie dzialal na tych sterach co mam (fglrx) czy konieczna jest przesiadka na stery otwarte, ktore obsluguja xgl, gdzies wygooglalem ze mozna zainstallowac xgl do tych sterow ktore mam - chodzi mi o pakiet xserver-xgl. Czy bedzie to dzialalo bo jak narazie przy probie odpalenie compiza mam cos takiego
Checking for Xgl: not present.
No whitelisted driver found
aborting and using fallback: /usr/bin/metacity
no /usr/bin/metacity found, exiting
pomozcie bo juz nie wytrzymam z ta grafika.
3 sprawa jest taka. Gdy probuje zmienic ustawienia Xorga i klepiac
dpkg-reconfigure xserver-xorg
Ratunku.
