dpkg-reconfigure xserver-xorgKod: Zaznacz cały
Xorg.0.logKod: Zaznacz cały
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
więc następnie dalej:
(WW) I810: No matching Device section for instance (BusID PCI:0:2:1) found
(--) Chipset 945GM foundKod: Zaznacz cały
(WW) I810(0): Bad V_BIOS checksumKod: Zaznacz cały
(WW) I810(0): config file hsync range 28-72kHz not within DDC hsync ranges.
(WW) I810(0): config file vrefresh range 43-60Hz not within DDC vrefresh ranges.Kod: Zaznacz cały
(WW) AIGLX: 3D driver claims to not support visual 0x23
(WW) AIGLX: 3D driver claims to not support visual 0x24
(WW) AIGLX: 3D driver claims to not support visual 0x25
(WW) AIGLX: 3D driver claims to not support visual 0x26
(WW) AIGLX: 3D driver claims to not support visual 0x27
(WW) AIGLX: 3D driver claims to not support visual 0x28
(WW) AIGLX: 3D driver claims to not support visual 0x29
(WW) AIGLX: 3D driver claims to not support visual 0x2a
(WW) AIGLX: 3D driver claims to not support visual 0x2b
(WW) AIGLX: 3D driver claims to not support visual 0x2c
(WW) AIGLX: 3D driver claims to not support visual 0x2d
(WW) AIGLX: 3D driver claims to not support visual 0x2dKod: Zaznacz cały
(WW) I810(0): Successfully set original devices
(WW) I810(0): Setting the original video mode instead of restoring
the saved stateKod: Zaznacz cały
(WW) I810(0): Extended BIOS function 0x5f05 failed.Kod: Zaznacz cały
(WW) Synaptics Touchpad can't grab event device, errno=1022Może to trochę długie, ale no potrzebuję pełnej akceleracji do różnych fajnych rzeczy więc pomóżcie Waszą wiedzą i doświadczeniem :-)
