Dysponuję Debianem Lenny. Podczas konfiguracji vmware mam takie błędy:
# vmware-config.pl
Making sure services for VMware Server are stopped.
Stopping VMware services:
Virtual machine monitor done
Configuring fallback GTK+ 2.4 libraries.
In which directory do you want to install the mime type icons?
[/usr/share/icons]
What directory contains your desktop menu entry files? These files have a
.desktop file extension. [/usr/share/applications]
In which directory do you want to install the application's icon?
[/usr/share/pixmaps]
/usr/share/applications/vmware-server.desktop: warning: value "vmware-server.png" for key "Icon" in group "Desktop Entry" is an icon name with an extension, but there should be no extension as described in the Icon Theme Specification if the value is not an absolute path
/usr/share/applications/vmware-console-uri-handler.desktop: warning: value "vmware-server.png" for key "Icon" in group "Desktop Entry" is an icon name with an extension, but there should be no extension as described in the Icon Theme Specification if the value is not an absolute path
Trying to find a suitable vmmon module for your running kernel.
None of the pre-built vmmon modules for VMware Server is suitable for your
running kernel. Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]
Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.24-1-686/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Building for VMware Server 1.0.0.
Using 2.6.x kernel build system.
make: Wejście do katalogu `/tmp/vmware-config0/vmmon-only'
make -C /lib/modules/2.6.24-1-686/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Wejście do katalogu `/usr/src/linux-headers-2.6.24-1-686'
CC [M] /tmp/vmware-config0/vmmon-only/linux/driver.o
CC [M] /tmp/vmware-config0/vmmon-only/linux/driverLog.o
CC [M] /tmp/vmware-config0/vmmon-only/linux/hostif.o
CC [M] /tmp/vmware-config0/vmmon-only/common/comport.o
CC [M] /tmp/vmware-config0/vmmon-only/common/cpuid.o
In file included from include/asm/bitops.h:2,
from /tmp/vmware-config0/vmmon-only/./include/vcpuset.h:74,
from /tmp/vmware-config0/vmmon-only/./include/modulecall.h:23,
from /tmp/vmware-config0/vmmon-only/common/vmx86.h:19,
from /tmp/vmware-config0/vmmon-only/common/hostif.h:18,
from /tmp/vmware-config0/vmmon-only/common/cpuid.c:15:
include/asm/bitops_32.h:9:2: error: #error only <linux/bitops.h> can be included directly
make[2]: *** [/tmp/vmware-config0/vmmon-only/common/cpuid.o] Błąd 1
make[1]: *** [_module_/tmp/vmware-config0/vmmon-only] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/linux-headers-2.6.24-1-686'
make: *** [vmmon.ko] Błąd 2
make: Opuszczenie katalogu `/tmp/vmware-config0/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.PS Posługiwałem się tym: http://www.howtoforge.com/debian_etch_v ... rver_howto
