davidoski pisze:frankie pisze:debian nie startuje i zawisa tuż po starcie.
Hmm, bardzo ciekawe. Napisz lepiej jak to wygląda dokładnie bo to powyżej nie ma przecież sensu.
Zatem wygląda to tak]
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
[/code]
expert acpi=ht
Zatrzymuje się na wierszu:
PCI: Enabling device 0000:05:07.0 (0104 -> 0107)
May 20 02:00:17 localhost kernel: NET: Registered protocol family 2
W mandrivie w pliku messages ten fragment wygląda tak (nie przejmujcie się datą):
May 20 02:00:17 localhost kernel: PCI: Bridge: 0000:00:10.0
May 20 02:00:17 localhost kernel: IO window: disabled.
May 20 02:00:17 localhost kernel: MEM window: b3200000-b32fffff
May 20 02:00:17 localhost kernel: PREFETCH window: disabled.
May 20 02:00:17 localhost kernel: PCI: Enabling device 0000:05:07.0 (0104 -> 0107)
May 20 02:00:17 localhost kernel: Time: acpi_pm clocksource has been installed.
expert acpi=off
Rozkrzacza się na:
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Odpowiedni zapis w messages Mandrivy:
May 20 02:00:17 localhost kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
May 20 02:00:17 localhost kernel: io scheduler noop registered
May 20 02:00:17 localhost kernel: io scheduler anticipatory registered
May 20 02:00:17 localhost kernel: io scheduler deadline registered
May 20 02:00:17 localhost kernel: io scheduler cfq registered (default)
May 20 02:00:17 localhost kernel: assign_interrupt_mode Found MSI capability
May 20 02:00:17 localhost kernel: vesafb: framebuffer at 0xc0000000, mapped to 0xffffc20000f80000, using 6144k, total 32768k
May 20 02:00:17 localhost kernel: vesafb: mode is 1024x768x16, linelength=2048, pages=1
May 20 02:00:17 localhost kernel: vesafb: scrolling: redraw
May 20 02:00:17 localhost kernel: vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
