ok, zainstalowalem z instalki - wersja:
#define RELEASE_VERSION "0.9.4"
caly kod z kompilacji i instalacji wyglada tak:
chameleon:~# lspci
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01)
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 [IDE] (rev 01)
00:03.0 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.1 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.3 USB Controller: Silicon Integrated Systems [SiS] USB 2.0 Controller
00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03)
00:06.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:07.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:0d.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller
01:00.0 VGA compatible controller: ATI Technologies Inc Mobility Radeon X2300
02:00.0 Ethernet controller: Atheros Communications, Inc. AR242x 802.11abg Wireless PCI Express Adapter (rev 01)
chameleon:~# rmmod ath_pci
chameleon:~# rmmod ndiswrapper
ERROR: Module ndiswrapper does not exist in /proc/modules
chameleon:~# depmod -ea
chameleon:~# cd /var/tmp/madwifi_instalka
chameleon:/var/tmp/madwifi_instalka# make
Checking requirements... ok.
Checking kernel configuration... ok.
make -C /lib/modules/2.6.24-1-486/build SUBDIRS=/var/tmp/madwifi_instalka modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.24-1-486'
CC [M] /var/tmp/madwifi_instalka/ath/if_ath.o
CC [M] /var/tmp/madwifi_instalka/ath/if_ath_pci.o
LD [M] /var/tmp/madwifi_instalka/ath/ath_pci.o
CC [M] /var/tmp/madwifi_instalka/ath_hal/ah_os.o
HOSTCC /var/tmp/madwifi_instalka/ath_hal/uudecode
UUDECODE /var/tmp/madwifi_instalka/ath_hal/i386-elf.hal.o
LD [M] /var/tmp/madwifi_instalka/ath_hal/ath_hal.o
CC [M] /var/tmp/madwifi_instalka/ath_rate/amrr/amrr.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/amrr/ath_rate_amrr.o
CC [M] /var/tmp/madwifi_instalka/ath_rate/minstrel/minstrel.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/minstrel/ath_rate_minstrel.o
CC [M] /var/tmp/madwifi_instalka/ath_rate/onoe/onoe.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/onoe/ath_rate_onoe.o
CC [M] /var/tmp/madwifi_instalka/ath_rate/sample/sample.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/sample/ath_rate_sample.o
CC [M] /var/tmp/madwifi_instalka/net80211/if_media.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_beacon.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_crypto.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_crypto_none.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_input.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_node.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_output.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_power.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_proto.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_scan.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_wireless.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_linux.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_monitor.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_rate.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_acl.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_crypto_ccmp.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_scan_ap.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_scan_sta.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_crypto_tkip.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_crypto_wep.o
CC [M] /var/tmp/madwifi_instalka/net80211/ieee80211_xauth.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_wep.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_tkip.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_ccmp.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_acl.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_xauth.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_scan_sta.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_scan_ap.o
Building modules, stage 2.
MODPOST 14 modules
CC /var/tmp/madwifi_instalka/ath/ath_pci.mod.o
LD [M] /var/tmp/madwifi_instalka/ath/ath_pci.ko
CC /var/tmp/madwifi_instalka/ath_hal/ath_hal.mod.o
LD [M] /var/tmp/madwifi_instalka/ath_hal/ath_hal.ko
CC /var/tmp/madwifi_instalka/ath_rate/amrr/ath_rate_amrr.mod.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/amrr/ath_rate_amrr.ko
CC /var/tmp/madwifi_instalka/ath_rate/minstrel/ath_rate_minstrel.mod.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/minstrel/ath_rate_minstrel.ko
CC /var/tmp/madwifi_instalka/ath_rate/onoe/ath_rate_onoe.mod.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/onoe/ath_rate_onoe.ko
CC /var/tmp/madwifi_instalka/ath_rate/sample/ath_rate_sample.mod.o
LD [M] /var/tmp/madwifi_instalka/ath_rate/sample/ath_rate_sample.ko
CC /var/tmp/madwifi_instalka/net80211/wlan.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan.ko
CC /var/tmp/madwifi_instalka/net80211/wlan_acl.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_acl.ko
CC /var/tmp/madwifi_instalka/net80211/wlan_ccmp.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_ccmp.ko
CC /var/tmp/madwifi_instalka/net80211/wlan_scan_ap.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_scan_ap.ko
CC /var/tmp/madwifi_instalka/net80211/wlan_scan_sta.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_scan_sta.ko
CC /var/tmp/madwifi_instalka/net80211/wlan_tkip.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_tkip.ko
CC /var/tmp/madwifi_instalka/net80211/wlan_wep.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_wep.ko
CC /var/tmp/madwifi_instalka/net80211/wlan_xauth.mod.o
LD [M] /var/tmp/madwifi_instalka/net80211/wlan_xauth.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.24-1-486'
make -C ./tools all || exit 1
make[1]: Entering directory `/var/tmp/madwifi_instalka/tools'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/var/tmp/madwifi_instalka/tools'
chameleon:/var/tmp/madwifi_instalka# make install
sh scripts/find-madwifi-modules.sh 2.6.24-1-486
WARNING:
It seems that there are modules left from previous MadWifi installations.
If you are unistalling the MadWifi modules please press "r" to remove them.
If you are installing new MadWifi modules, you should consider removing those
already installed, or else you may experience problems during operation.
Remove old modules?
[l]ist, [r]emove, [i]gnore or e[x]it (l,r,i,[x]) ?
r
for i in ath/ ath_hal/ ath_rate/ net80211/; do \
make -C $i install || exit 1; \
done
make[1]: Entering directory `/var/tmp/madwifi_instalka/ath'
test -d //lib/modules/2.6.24-1-486/net || mkdir -p //lib/modules/2.6.24-1-486/net
install ath_pci.ko //lib/modules/2.6.24-1-486/net
make[1]: Leaving directory `/var/tmp/madwifi_instalka/ath'
make[1]: Entering directory `/var/tmp/madwifi_instalka/ath_hal'
install ath_hal.ko //lib/modules/2.6.24-1-486/net
make[1]: Leaving directory `/var/tmp/madwifi_instalka/ath_hal'
make[1]: Entering directory `/var/tmp/madwifi_instalka/ath_rate'
for i in amrr/ onoe/ sample/ minstrel/; do \
done
make[2]: Entering directory `/var/tmp/madwifi_instalka/ath_rate/amrr'
install ath_rate_amrr.ko //lib/modules/2.6.24-1-486/net
make[2]: Leaving directory `/var/tmp/madwifi_instalka/ath_rate/amrr'
make[2]: Entering directory `/var/tmp/madwifi_instalka/ath_rate/onoe'
install ath_rate_onoe.ko //lib/modules/2.6.24-1-486/net
make[2]: Leaving directory `/var/tmp/madwifi_instalka/ath_rate/onoe'
make[2]: Entering directory `/var/tmp/madwifi_instalka/ath_rate/sample'
install ath_rate_sample.ko //lib/modules/2.6.24-1-486/net
make[2]: Leaving directory `/var/tmp/madwifi_instalka/ath_rate/sample'
make[2]: Entering directory `/var/tmp/madwifi_instalka/ath_rate/minstrel'
cp ath_rate_minstrel.ko //lib/modules/2.6.24-1-486/net
make[2]: Leaving directory `/var/tmp/madwifi_instalka/ath_rate/minstrel'
make[1]: Leaving directory `/var/tmp/madwifi_instalka/ath_rate'
make[1]: Entering directory `/var/tmp/madwifi_instalka/net80211'
for i in wlan.o wlan_wep.o wlan_tkip.o wlan_ccmp.o wlan_acl.o wlan_xauth.o wlan_scan_sta.o wlan_scan_ap.o; do \
f=`basename $i .o`; \
install $f.ko //lib/modules/2.6.24-1-486/net; \
done
make[1]: Leaving directory `/var/tmp/madwifi_instalka/net80211'
(export KMODPATH=/lib/modules/2.6.24-1-486/net; /sbin/depmod -ae 2.6.24-1-486)
make -C ./tools install || exit 1
install -d /usr/local/bin
for i in athstats 80211stats athkey athchans athctrl athdebug 80211debug wlanconfig ath_info; do \
install $i /usr/local/bin/$i; \
strip /usr/local/bin/$i; \
done
install -d /usr/local/man/man8
install -m 0644 man/*.8 /usr/local/man/man8
WARNING:
Remove old modules?
i
done
done
done
done
chameleon:/var/tmp/madwifi_instalka# modprobe ath_pci
chameleon:/var/tmp/madwifi_instalka# modinfo ath_pci
filename: /lib/modules/2.6.24-1-486/net/ath_pci.ko
license: Dual BSD/GPL
version: 0.9.4
description: Support for Atheros 802.11 wireless LAN cards.
author: Errno Consulting, Sam Leffler
srcversion: 95EC89B6884FCEE1B4EED63
alias: pci:v0000168Cd00009013sv*sd*bc*sc*i*
alias: pci:v0000168Cd0000001Dsv*sd*bc*sc*i*
alias: pci:v0000168Cd0000001Csv*sd*bc*sc*i*
alias: pci:v0000168Cd0000001Bsv*sd*bc*sc*i*
alias: pci:v0000168Cd0000001Asv*sd*bc*sc*i*
alias: pci:v0000168Cd00000019sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000018sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000017sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000016sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000015sv*sd*bc*sc*i*
alias: pci:v0000168Cd0000101Asv*sd*bc*sc*i*
alias: pci:v0000168Cd00001014sv*sd*bc*sc*i*
alias: pci:v000010B7d00000013sv*sd*bc*sc*i*
alias: pci:v0000A727d00000013sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000013sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000012sv*sd*bc*sc*i*
alias: pci:v0000168Cd00000007sv*sd*bc*sc*i*
depends: ath_hal,wlan
vermagic: 2.6.24-1-486 mod_unload 486
parm: countrycode:Override default country code (int)
parm: outdoor:Enable/disable outdoor use (int)
parm: xchanmode:Enable/disable extended channel mode (int)
parm: rfkill:Enable/disable RFKILL capability (int)
parm: autocreate:Create ath device in [sta|ap|wds|adhoc|ahdemo|monitor] mode. defaults to sta, use 'none' to disable (charp)
parm: ratectl:Rate control algorithm [amrr|minstrel|onoe|sample], defaults to 'sample' (charp)
parm: ath_debug:Load-time debug output enable (int)
chameleon:/var/tmp/madwifi_instalka# lspci
chameleon:/var/tmp/madwifi_instalka# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
chameleon:/var/tmp/madwifi_instalka# wlanconfig ath0 create wlandev wifi0 wlanmode ap
wlanconfig: ioctl: No such device
po prostu nie wiem co dalej.
nie rozumiem, dlaczego nie mam ath0 lub wifi0
dodam, ze na starszym jadrze tez nie moge tego zainstalowac madwifi ani ath5k wiec jade na windowsowych.
czy ktokolwiek wogole wie co zrobic dalej? wiem, ze problem jest moze nietypowy, ale wierze, ze sa tutaj specjalisci. gdyby bylo inaczej, to poszukalbym na forum dody-elektrody
[ Dodano: 2008-05-17, 20:47 ]
sterownik chyba poprawnie zainstalowany bo:
chameleon:# lspci
[ Dodano: 2008-05-17, 20:55 ]
sterowniki zainstalowalem, ale nie moge postawic interfejsu.
przy starcie widze cos takiego:
ath0: ERROR while gettin interface flags: No such device
wersja sterownika 0.9.4 a moja karta:
chameleon:~# lspci
chameleon:~#
czy ktos wie jak ten interfejs wlan0 albo ath0 postawic? jak bylo a jak jest widac w skrinszotach powyzej.
prosze o pomoc.
