chyba że macie jakąś lepszą alternatywe...?
Podczas kompilacji xmlrpc-c-1.11.00 wyskakuje błąd?
cd /usr/src
wget [url]http://dfn.dl.sourceforge.net/sourceforge/xmlrpc-c/xmlrpc-c-1.11.00.tgz[/url]
tar xvf xmlrpc-c-1.11.00.tgz
cd xmlrpc-c-1.11.00
./configure
checking whether make sets $(MAKE)... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for wininet-config... no
configure: You don't appear to have Wininet installed (no working wininet-config in your command search path), so we will not build the Wininet client XML transport
checking whether to build Wininet client XML transport module... no
checking for curl-config... yes
checking whether to build Curl client XML transport module... yes
checking for libwww-config... no
configure: You don't appear to have Libwww installed (no working libwww-config in your command search path), so we will not build the Libwww client XML transport
checking whether to build Libwww client XML transport module... no
checking whether to build Abyss server module... yes
checking whether to build CGI server module... yes
checking whether to build C++ wrappers and tools... yes
checking for gcc... gcc
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for socket... yes
checking for egrep... grep -E
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking wchar.h usability... yes
checking wchar.h presence... yes
checking for wchar.h... yes
checking sys/filio.h usability... no
checking sys/filio.h presence... no
checking for sys/filio.h... no
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking for size_t... yes
checking whether va_list is an array... no
checking whether compiler has __attribute__... yes
checking for vsnprintf... yes
checking for wcsncmp... yes
checking for setgroups... yes
checking for asprintf... yes
checking for setenv... yes
checking for pselect... yes
checking whether to use Abyss pthread function... yes
checking for curl-xmlrpc-config... no
checking for curl-config... /usr/bin/curl-config
checking for curl library directory... /usr/lib
checking whether to use SSL with libwww... no
checking whether to build the libxml2 backend... no
checking for ranlib... ranlib
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking for object suffix... o
checking for executable suffix... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.lo... yes
checking if gcc supports -fno-rtti -fno-exceptions ... no
checking if gcc static flag -static works... -static
checking whether the linker (/usr/bin/ld) supports shared libraries... yes
checking command to parse /usr/bin/nm -B output... ok
checking how to hardcode library paths into programs... immediate
checking for /usr/bin/ld option to reload object files... -r
checking dynamic linker characteristics... Linux ld.so
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for objdir... .libs
creating libtool
configure: creating ./config.status
config.status: creating Makefile.srcdir
config.status: creating Makefile.config
config.status: creating xmlrpc_config.h
config.status: creating xmlrpc_amconfig.h
config.status: xmlrpc_amconfig.h is unchanged
config.status: executing default-1 commands
# ./configure
creating libtool
config.status: executing default-1 commandsi błąd make
.......gcc -c -I/home/mirasek1980/libiqxmlrpc-0.8.7/xmlrpc-c-1.11.00 -I/home/mirasek1980/libiqxmlrpc-0.8.7/xmlrpc-c-1.11.00/include -I//home/mirasek1980/libiqxmlrpc-0.8.7/xmlrpc-c-1.11.00/include -I//home/mirasek1980/libiqxmlrpc-0.8.7/xmlrpc-c-1.11.00/lib/util/include -DNDEBUG -Wall -Wundef -Wimplicit -W -Winline -Wundef -Wmissing-declarations -Wstrict-prototypes -Wmissing-prototypes -fno-common -g -O3 xmlrpc_curl_transport.c -fPIC -DPIC -o .libs/xmlrpc_curl_transport.lo
xmlrpc_curl_transport.c:560:69: error: macro "curl_easy_setopt" requires 3 arguments, but only 2 given
xmlrpc_curl_transport.c: In function 'setupCurlSession':
xmlrpc_curl_transport.c:560: warning: statement with no effect
xmlrpc_curl_transport.c: In function 'setInterrupt':
xmlrpc_curl_transport.c:1733: warning: pointer targets in assignment differ in signedness
xmlrpc_curl_transport.c: In function 'finishAsynch':
xmlrpc_curl_transport.c:1998: warning: pointer targets in passing argument 5 of 'curlMulti_finish' differ in signedness
xmlrpc_curl_transport.c: In function 'call':
xmlrpc_curl_transport.c:2055: warning: pointer targets in passing argument 4 of 'performRpc' differ in signedness
make[2]: *** [xmlrpc_curl_transport.lo] Błąd 1
make[2]: Opuszczenie katalogu `libiqxmlrpc-0.8.7/xmlrpc-c-1.11.00/lib/curl_transport'
make[1]: *** [curl_transport/all] Błąd 2
make[1]: Opuszczenie katalogu `libiqxmlrpc-0.8.7/xmlrpc-c-1.11.00/lib'
make: *** [lib/all] Błąd 2
apt nie znajduje apt-file search xmlrpc_curl_transport.c
ps. a tak na marginesie jeśli ktoś instalował wtorrenta niech sie podzieli wrażeniami... i sorki za mega posta.
