wpa_supplicant -i eth2 -Dwext -c/etc/wpa_supplicant.confKod: Zaznacz cały
wpa_supplicant -i wlan0 -Dndiswrapper -c/etc/wpa_supplicant.confnie dziala. wyrzuca komunikat
Association request to the driver failed
Authentication with 00:00:00:00:00:00 timed out.
CTRL-EVENT-TERMINATING - signal 2 received
Failed to disable WPA in the driverKod: Zaznacz cały
wpa_supplicant -i wlan0 -Dwext -c/etc/wpa_supplicant.confKod: Zaznacz cały
Trying to associate with 00:19:e0:12:83:b1 (SSID='ORLA' freq=2442
MHz)
Associated with 00:19:e0:12:83:b1
WPA: Key negotiation completed with 00:19:e0:12:83:b1 [PTK=TKIP
GTK=TKIP]
CTRL-EVENT-CONNECTED - Connection to 00:19:e0:12:83:b1 completed
(auth) [id=0 id_str=]
GTK=TKIP]
(reauth) [id=0 id_str=]
