Jak w temacie mam problem odtworzenia jakiegokolwiek rozszerzenia pliku filmowego pod Linuksem. Kodeki w32codesc mam bo:
debian:/home/miles# apt-get install w32codecs
Budowanie drzewa zależności
Reading state information... Gotowe
w32codecs jest już w najnowszej wersji.
0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 360 nieaktualizowanych.
debian:/home/miles#
Mplayer nieoczekiwanie zakończyl prace. Kod wyjścia =1
/usr/bin/mplayer -noquiet -nofs -sub-fuzziness 1 -identify -slave -vo xv, -zoom -nokeepaspect -framedrop -input conf=/usr/share/smplayer/input.conf -stop-xscreensaver -wid 27262988 -monitorpixelaspect 1 -subfont-autoscale 1 -subfont-text-scale 5 -subcp ISO-8859-1 -subpos 100 -contrast 0 -brightness 0 -hue 0 -saturation 0 -nocache -osdlevel 0 -vf-add screenshot -channels 2 -af scaletempo /mnt/win2/FILMY NEW/XXY (2007) [SubPL] RmvB/XXY (2007) DVDRip XviD.rmvb
MPlayer dev-SVN-r25315
CPU: AMD Sempron(tm) 2200+ (Family: 6, Model: 8, Stepping: 1)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Terminal type `unknown' is not defined.
Playing /mnt/win2/FILMY NEW/XXY (2007) [SubPL] RmvB/XXY (2007) DVDRip XviD.rmvb.
REAL file format detected.
Stream description: Audio Stream
Stream mimetype: audio/x-pn-realaudio
ID_AUDIO_ID=0
[real] Audio stream found, -aid 0
Stream description: Video Stream
Stream mimetype: video/x-pn-realvideo
ID_VIDEO_ID=1
[real] Video stream found, -vid 1
Stream mimetype: logical-fileinfo
VIDEO: [RV40] 640x360 24bpp 29.000 fps 0.0 kbps ( 0.0 kbyte/s)
Clip info:
comment:
ID_CLIP_INFO_NAME0=comment
ID_CLIP_INFO_VALUE0=
ID_CLIP_INFO_N=1
SUB: Detected subtitle file format: microdvd
SUB: Read 463 subtitles.
ID_FILE_SUB_ID=0
ID_FILE_SUB_FILENAME=/mnt/win2/FILMY NEW/XXY (2007) [SubPL] RmvB/XXY (2007) DVDRip XviD.txt
SUB: Added subtitle file (1): /mnt/win2/FILMY NEW/XXY (2007) [SubPL] RmvB/XXY (2007) DVDRip XviD.txt
ID_FILENAME=/mnt/win2/FILMY NEW/XXY (2007) [SubPL] RmvB/XXY (2007) DVDRip XviD.rmvb
ID_DEMUXER=real
ID_VIDEO_FORMAT=RV40
ID_VIDEO_BITRATE=0
ID_VIDEO_WIDTH=640
ID_VIDEO_HEIGHT=360
ID_VIDEO_FPS=29.000
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=cook
ID_AUDIO_BITRATE=0
ID_AUDIO_RATE=44100
ID_AUDIO_NCH=2
ID_LENGTH=5210.00
xscreensaver_disable: Could not find XScreenSaver window.
Opening video filter: [screenshot]
MPlayer interrupted by signal 11 in module: init_video_filters
ID_SIGNAL=11
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.Pozdrawiam
Artur
Albo wie może ktoś jak to inaczej odtworzyć tylko zęby była możliwość wczytania napisów
