Downloading from microsoft.com:
13% mfc42.cab!! Wystąpił błąd podczas ściągania. Proszę uruchom IEs4Linux ponownie. Uszkodzony plik: mfc42.cabKod: Zaznacz cały
** (ies4linux-gtk.py:31006): WARNING **: Invalid borders specified for theme pixmap:
/home/charlie/.themes/BlueSpace_II/gtk-2.0/shadows/frame1.png,
borders don't fit within the imageKod: Zaznacz cały
charlie@charlie-desktop:~$ /home/charlie/Backup/Skrypty/ies4linux-2.99.0.1/ies4linux
** (ies4linux-gtk.py:32063): WARNING **: Invalid borders specified for theme pixmap:
/home/charlie/Backup/Skrypty/ies4linux-2.99.0.1/ui/pygtk/ies4linux-gtk.py:399: GtkWarning: Invalid text buffer iterator: either the iterator is uninitialized, or the characters/pixbufs/widgets in the buffer have been modified since the iterator was created.
You must use marks, character numbers, or line numbers to preserve a position across buffer modifications.
You can apply tags and insert marks without invalidating your iterators,
but any mutation that affects 'indexable' buffer contents (contents that can be referred to by character offset)
will invalidate all outstanding iterators
gtk.main()
ui/pygtk/python-gtk.sh: line 6: 32063 Segmentation fault (core dumped) python "$IES4LINUX"/ui/pygtk/ies4linux-gtk.py
charlie@charlie-desktop:~$ .
