menteith
Posty: 41 Rejestracja: 16 października 2006, 02:21
Post
autor: menteith » 01 kwietnia 2008, 22:26
Witam!
Gdy nie mam podlaczonej myszki do portu USB, a dokladniej odbiornika ktory sie z nia komunikuje, X sie nie laduja i moga pracowac tylko w konsoli. Po jej podpieciu mozliwe jest zaladowanie X i praca w trybie graficznym. Co nalezy zrobic aby moc pracowac w srodowisku graficznym bez myszki (mam laptopa z touchpadem). Moj xorg:
# package.
Section "Files"
# path to defoma fonts
FontPath "/usr/share/fonts/X11/100dpi:unscaled"
FontPath "/usr/share/fonts/X11/75dpi:unscaled"
FontPath "/usr/local/share/fonts"
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "type1"
Load "vbe"
Load "dbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
#Identifier "Logitech"
Driver "evdev"
Option "CorePointer"
Option "Name" "Logitech USB Receiver" #this should be the name of the device which I made bold here.
Option "ZAxisMapping" "4 5"
Option "Resolution" "800"
Option "Buttons" "9"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
EndSection
Section "Device"
Identifier "Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
Driver "i810"
BusID "PCI:0:2:0"
Option "XAANoOffscreenPixmaps" "true"
Option "AllowGLXWithComposite" "true"
Option "RenderAccel" "true"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x800"
EndSubSection
Depth 4
Modes "1280x800"
EndSubSection
Depth 8
Modes "1280x800"
EndSubSection
Depth 15
Modes "1280x800"
EndSubSection
Depth 16
Modes "1280x800"
EndSubSection
Depth 24
Modes "1280x800"
EndSubSection
Option "TripleBuffer" "true"
Option "no GLXFBConfig for depth 32"
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "DisableGLXRootClipping" "true"
Option "AddARGBGLXVisuals" "true"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
#InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
Option "AIGLX" "on"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
Posty: 6469 Rejestracja: 09 sierpnia 2007, 21:41
Post
autor: Yampress » 02 kwietnia 2008, 08:57
zrób kopie tego pliku , następnie usuń wpis (albo lepiej zahaszuj)
Driver "evdev"
EndSection
menteith
Post
autor: menteith » 02 kwietnia 2008, 11:28
Ale wtedy strace konfiguracje myszki
Post
autor: Yampress » 02 kwietnia 2008, 12:32
menteith pisze: Ale wtedy strace konfiguracje myszki
zrób kopie pliku albo zahaszuj konfiguracje myszki. chyba nie czytasz uwaznie
Bodzio
Posty: 599 Rejestracja: 26 grudnia 2007, 18:35
Post
autor: Bodzio » 02 kwietnia 2008, 14:27
Jak przyjdę do domu to zapodam mojego configa. X-y naLaptopie z działającym touchpadem MUSZ¡ się odpalić bez mysiora. Nie ma zmiłuj.
Zwróciłem jeszcze uwagę na ten wpis
menteith pisze: Option "Resolution" "800"
to powstało domyślnie podczas instalacji systemu, czy instalowałeś specjalne drivery dla myszy ?
menteith
Post
autor: menteith » 02 kwietnia 2008, 14:43
Te wszystkie wpisy zostaly dodane przeze mnie - umozliwiaja korzystanie z wszystkich przyciskow myszki.
Bodzio napisał/a:
Tak, rekonfiguracja xorga bez podlaczonej myszki i uzyskanie w ten sposob nowego xorg.conf, rzeczywiscie umozliwia odpalenie x.
Yampress pisze: menteith pisze: Ale wtedy strace konfiguracje myszki
Czytam. Zahaszowanie konfiguracji myszki pozbawi mnie mozliwosci korzystania z dodatkowych przyciskow. ;-)
Bodzio
Post
autor: Bodzio » 02 kwietnia 2008, 18:24
Driver "mouse"
Option "Protocol" "ExplorerPS/2"
EndSection
Driver "synaptics"
EndSection
takie są moje ustawienia
a takie Twoje
Driver "evdev"
EndSection
- widzę różnicę w Driver -> mouse i evdev
- nie masz funkcji "Device"
- nie masz funkcji
Poeksperymentuj ze zmianami.
Zgadzam się że masz mysz wielofunkcyjną, ale te małe różnice w konfiguracji mają wpływ na odpalenie xserwera
menteith
Post
autor: menteith » 02 kwietnia 2008, 18:31
A moglbys wkleic swojego xorga? Opcja Drievr jest odpowiedzialna za obslyge dodatkowych przyciskow, funkcja jest zbedna, a OPtion Protocol, taki jak u Ciebie, zapewne nie bedzie dzialal u mnie - mam mysz USB, a Ty chyba PS/2.
Bodzio
Post
autor: Bodzio » 02 kwietnia 2008, 18:56
całego xorga ? - proszę
Section "Files"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Driver "synaptics"
EndSection
Section "Device"
Identifier "nVidia Corporation MCP51 PCI-X GeForce Go 6100"
Driver "nvidia"
BusID "PCI:0:5:0"
EndSection
Section "Monitor"
Option "DPMS"
HorizSync 28-64
VertRefresh 43-60
EndSection
Section "Screen"
Device "nVidia Corporation MCP51 PCI-X GeForce Go 6100"
DefaultDepth 24
Modes "1280x1024" "1280x960" "1280x854" "1280x800"
EndSubSection
EndSection
EndSection
mysz mam na USB oczywiście
Zwróć uwagę, że w /dev/input/by-id/USB-Logitech-mouse... ble..ble jest linkowane do /dev/input/event1 i do mouse0
tu działa jądro
menteith
Post
autor: menteith » 02 kwietnia 2008, 19:12
Dzieki, jeszcze poeksperymentuje :-)
