Virtualhost +SSL i SquirrelMail
redelek
Post autor: redelek »
Czytam różne manual ( np. http://debian.linux.pl/viewtopic.php?t= ... hlight=ssl ) i nie mogę dojść co jest nie tak.
Config
NameVirtualHost *:80
NameVirtualHost *:443
<VirtualHost 83.142.41.140:80>
        ServerAdmin webmaster@localhost
        DocumentRoot /var/www/clickad
        <Directory /var/www/clickad>
                Options FollowSymLinks
                AllowOverride None
        </Directory>
                Options Indexes FollowSymLinks MultiViews
                AllowOverride None
                Order allow,deny
                allow from all
        </Directory>
        ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
        <Directory "/usr/lib/cgi-bin">
                AllowOverride None
                Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
                Order allow,deny
                Allow from all
        </Directory>
        ErrorLog /var/log/apache2/error.log
        LogLevel warn
        CustomLog /var/log/apache2/access.log combined
        ServerSignature On
    Alias /doc/ "/usr/share/doc/"
    <Directory "/usr/share/doc/">
        Options Indexes MultiViews FollowSymLinks
        AllowOverride None
        Order deny,allow
        Deny from all
        Allow from 127.0.0.0/255.0.0.0 ::1/128
    </Directory>
</VirtualHost>
<VirtualHost 83.142.41.140:443>
    Alias /mail "/usr/share/squirrelmail/"
        <Directory "/usr/share/squirrelmail/">
            AllowOverride None
            Order allow,deny
            allow from all
        </Directory>
</VirtualHost>
w pliki /etc/apache2.conf wpisałem
SSLEngine on
SSLCertificateFile /etc/apache2/apache.pem
Jak uruchamiam serwer to mam taki błąd
#/etc/init.d/apache2 start
Starting web server (apache2)...[Mon Mar 31 11:32:41 2008] [warn] NameVirtualHost *:443 has no VirtualHosts
[Mon Mar 31 11:32:41 2008] [warn] NameVirtualHost *:80 has no VirtualHosts
failed!
Co robię źle chodzi mi o puszczenie SquirrelMail po ssl ?
Redelek
to nie w tym pliku
vhosty umieszczasz w
 /etc/apache2/sites-available/default
wg tego
                AllowOverride None
        </Directory>
                AllowOverride None
                Order allow,deny
                allow from all
        </Directory>
                AllowOverride None
                Order allow,deny
                Allow from all
        </Directory>
        LogLevel warn
        ServerSignature On
        AllowOverride None
        Order deny,allow
        Deny from all
    </Directory>
</VirtualHost>
       SSLEngine on
                AllowOverride None
        </Directory>
                AllowOverride None
                Order allow,deny
                allow from all
        </Directory>
                AllowOverride None
                Order allow,deny
                Allow from all
        </Directory>
        LogLevel warn
        ServerSignature On
        AllowOverride None
        Order deny,allow
        Deny from all
    </Directory>
</VirtualHost>
porty na jakim nasłuchuje 80, 443 w
 /etc/apache2/ports.conf
musisz jeszcze dodać dektrywy ServerName do wyżej wymienionych vhostów oraz
musisz zmienić ścieżke DokumentRoot na katalog squirrelmail
redelek
Yampress pisze:to nie w tym pliku
Ale ja zrobiłem sobie swój pliczek zamiast default . I w nim to zrobiłem.
Poprawiłem troszkę tak jak pokazałeś i nadal mam błąd
#/etc/init.d/apache2 restart
Forcing reload of web server (apache2)...[Mon Mar 31 12:20:49 2008] [warn] NameVirtualHost *:443 has no VirtualHosts
[Mon Mar 31 12:20:49 2008] [warn] NameVirtualHost *:80 has no VirtualHosts
 waiting [Mon Mar 31 12:20:51 2008] [warn] NameVirtualHost *:443 has no VirtualHosts
[Mon Mar 31 12:20:51 2008] [warn] NameVirtualHost *:80 has no VirtualHosts
a w logach serwera tak
[Mon Mar 31 12:20:52 2008] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Mon Mar 31 12:20:52 2008] [warn] RSA server certificate CommonName (CN) `adcall.pl' does NOT match server name!?
[Mon Mar 31 12:20:52 2008] [notice] Apache configured -- resuming normal operations
NameVirtualHost  83.142.41.140:80
NameVirtualHost  83.142.41.140:443
redelek
Yampress pisze:
Oki poszedł ładnie się restartuje. W logach mam coś takiego?
[Mon Mar 31 13:07:06 2008] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
Certyfikat generuję sam dla siebie, bez podpisu w innej firmie?
redelek pisze:Certyfikat generuję sam dla siebie, bez podpisu w innej firmie?
możesz sam go sobie podpisać sam przez siebie :P
redelek
Yampress pisze:
Bardzo dziękuję za pomoc i wskazówki.
Stawiam punkt . DZIÊKI
Arcanus
Post autor: Arcanus »
No to pytanie dodatkowe jak teraz zrobić żeby ssl sie automatycznie włączało sie automatycznie czyli zmaiast http odrazu wskakiwało https w oknie z adresem squirrelMail.
Arcanus pisze:No to pytanie dodatkowe jak teraz zrobić żeby ssl sie automatycznie włączało sie automatycznie czyli zmaiast http odrazu wskakiwało https w oknie z adresem squirrelMail.
zainteresuj się dyrektywą
Redirect
poza tym tworzysz 2 vhosty jak wyżej. w tym vhoście gdzie łączysz się na porcie 80 umieszczasz ta dyrektywe
idzik
Post autor: idzik »
Proponuje zainstalować do Wiewiórki odpowiedni plugin SECURE LOGIN . Powodzenia.
