alsa brak dźwi
wojtekryba
alsa brak dźwięku
Post autor: wojtekryba »
Witam!
Po instalacji Debiana w wersji Lenny (w Etch to samo) nie mam dźwięku.
alsaconf w ogóle nie wykrywa karty
lspci daje wynik:
00:00.0 Host bridge: nVidia Corporation Unknown device 07c3 (rev a2)
00:00.1 RAM memory: nVidia Corporation Unknown device 07cb (rev a2)
00:01.0 RAM memory: nVidia Corporation Unknown device 07cd (rev a1)
00:01.1 RAM memory: nVidia Corporation Unknown device 07ce (rev a1)
00:01.2 RAM memory: nVidia Corporation Unknown device 07cf (rev a1)
00:01.3 RAM memory: nVidia Corporation Unknown device 07d0 (rev a1)
00:01.4 RAM memory: nVidia Corporation Unknown device 07d1 (rev a1)
00:01.5 RAM memory: nVidia Corporation Unknown device 07d2 (rev a1)
00:01.6 RAM memory: nVidia Corporation Unknown device 07d3 (rev a1)
00:02.0 RAM memory: nVidia Corporation Unknown device 07d6 (rev a1)
00:03.0 ISA bridge: nVidia Corporation Unknown device 07d7 (rev a2)
00:03.1 SMBus: nVidia Corporation Unknown device 07d8 (rev a1)
00:03.2 RAM memory: nVidia Corporation Unknown device 07d9 (rev a1)
00:03.4 RAM memory: nVidia Corporation Unknown device 07c8 (rev a1)
00:04.0 USB Controller: nVidia Corporation Unknown device 07fe (rev a1)
00:04.1 USB Controller: nVidia Corporation Unknown device 056a (rev a1)
00:08.0 IDE interface: nVidia Corporation Unknown device 056c (rev a1)
00:09.0 Audio device: nVidia Corporation Unknown device 07fc (rev a1)
00:0a.0 PCI bridge: nVidia Corporation Unknown device 056d (rev a1)
00:0b.0 PCI bridge: nVidia Corporation Unknown device 056e (rev a1)
00:0c.0 PCI bridge: nVidia Corporation Unknown device 056f (rev a1)
00:0d.0 PCI bridge: nVidia Corporation Unknown device 056f (rev a1)
00:0e.0 IDE interface: nVidia Corporation Unknown device 07f0 (rev a2)
00:0f.0 Ethernet controller: nVidia Corporation Unknown device 07dc (rev a2)
00:10.0 VGA compatible controller: nVidia Corporation Unknown device 07e3 (rev a2)
01:05.0 Ethernet controller: D-Link System Inc RTL8139 Ethernet (rev 10)
modinfo soundcore:
filename:       /lib/modules/2.6.22-3-686/kernel/sound/soundcore.ko
alias:          char-major-14-*
license:        GPL
author:         Alan Cox
description:    Core sound module
depends:
vermagic:       2.6.22-3-686 SMP mod_unload 686
Próbowałem wszystkiego co znalazłem na ten temat
Moja karta dźwiękowa według strony alsy to Intel HDA driver a jest to na chipsecie nforce 610i
Pozdrawiam i z góry dziękuje za wszelką pomoc
P.S. Na Ubuntu 7.10 miałem ten sam problem, lecz na 8.04 już nie
3ndriu
Post autor: 3ndriu »
Zainstaluj alsa-base.
aptitude install alsa-base
Jeżeli działa alsamixer, to znaczy, że masz alsa-utils. Zobacz też ten temat: http://debian.linux.pl/viewtopic.php?t=494
wojtekryba
alsa-base i alsa-utils mam zaistalowane
wpisując alsamixer w terminalu otrzymuje
alsamixer: function snd_ctl_open failed for default: No such file or directory
Z tego poradnika również próbowałem skonfigurować ale nie dałem rady
Podłącz się do internetu i wydaj w terminalu/konsoli (jako root lub sudo) polecenie:
update-pciids
następnie wklej jeszcze raz wynik polecenia
lspci
wojtekryba
lspci po updacie
00:00.1 RAM memory: nVidia Corporation nForce 630i memory controller (rev a2)
00:01.0 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.1 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.2 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.3 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.4 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.5 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.6 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:02.0 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:04.0 USB Controller: nVidia Corporation GeForce 7100/nForce 630i (rev a1)
00:04.1 USB Controller: nVidia Corporation GeForce 7100/nForce 630i (rev a1)
00:09.0 Audio device: nVidia Corporation MCP73 High Definition Audio (rev a1)
00:0f.0 Ethernet controller: nVidia Corporation MCP73 Ethernet (rev a2)
00:10.0 VGA compatible controller: nVidia Corporation GeForce 7050/nForce 610i (rev a2)
karta dźwiękowa pisze:00:09.0 Audio device: nVidia Corporation MCP73 High Definition Audio (rev a1)
Odinstaluj poprzednio instalowane wszystkie elementy odnoszące się do alsy.
Poszukaj opisu do swojej karty dźwiękowej (instalacja sterowników).
Poszukaj, pobierz i zainstaluj odpowiedni obecnie, sterownik do twojej karty dźwiękowej.
Być może sprawę rozwiąże najnowszy kernel. Więcej Cię nie naprowadzę --- nie mam takiej karty.
localh0st
Post autor: localh0st »
su
alsaconf
Wybierz swoją kartę, niech sterownik zbuduje potrzebne rzeczy do niego. Powinna działać.
wojtekryba
alsaconf wywala mi:
No supported PnP or PCI card found.
Panowie przejrzyjcie cały temat --- zaczyna się tworzyć zamknięte koło, wracacie do punktu wyjścia.
Została ustalona nazwa karty i jej typ. Teraz należy odinstalować wszystko co jest zbędne. Poszukać na stronie alsy odpowiedniego sterownika (źrodeł), przygotować system do kompilacji odpowiednich modułów itd.
Kolejne polecenia bez wcześniejszej poprawnej instalacji właściwego zestawu oprogramowania będą zwracać takie i podobne błędy.
wojtekryba
Problem udało się rozwiązać
Skompilowałem alsę do nowa i działa!
Wszystkim dziękuje za pomoc
P.S. Temat można zamknąć
