Co pewien czas mój debian na chwilę jak gdyby traci kontakt z rzeczywistością tzn nie działa klawiatura, myszka ogólnie system nie odpowiada, po kilku sekundach sytuacja wraca do normy a po wpisaniu dmesg konsola wypluwa :
Linux version 2.6.18-6-686 (Debian 2.6.18.dfsg.1-18etch1) (waldi@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Sun Feb 10 22:11:31 UTC 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000005ffc0000 (usable)
BIOS-e820: 000000005ffc0000 - 000000005ffcf000 (ACPI data)
BIOS-e820: 000000005ffcf000 - 0000000060000000 (ACPI NVS)
BIOS-e820: 00000000fed14000 - 00000000fed1a000 (reserved)
BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
BIOS-e820: 00000000ffb80000 - 0000000100000000 (reserved)
639MB HIGHMEM available.
896MB LOWMEM available.
found SMP MP-table at 000ff780
On node 0 totalpages: 393152
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 225280 pages, LIFO batch:31
HighMem zone: 163776 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 ACPIAM ) @ 0x000f6990
ACPI: RSDT (v001 A M I OEMRSDT 0x10000512 MSFT 0x00000097) @ 0x5ffc0000
ACPI: FADT (v002 A M I OEMFACP 0x10000512 MSFT 0x00000097) @ 0x5ffc0200
ACPI: MADT (v001 A M I OEMAPIC 0x10000512 MSFT 0x00000097) @ 0x5ffc0390
ACPI: MCFG (v001 A M I OEMMCFG 0x10000512 MSFT 0x00000097) @ 0x5ffc03f0
ACPI: OEMB (v001 A M I AMI_OEM 0x10000512 MSFT 0x00000097) @ 0x5ffcf040
ACPI: DSDT (v001 0AAAA 0AAAA000 0x00000000 INTL 0x02002026) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 6:13 APIC version 20
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 70000000 (gap: 60000000:9ed14000)
Detected 1496.372 MHz processor.
Built 1 zonelists. Total pages: 393152
Kernel command line: auto BOOT_IMAGE=LinuxOLD ro root=306
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1549932k/1572608k available (1541k kernel code, 21616k reserved, 580k data, 196k init, 655104k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 2995.30 BogoMIPS (lpj=5990613)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: afe9fbff 00100000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: afe9fbff 00100000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 1024K
CPU: After all inits, caps: afe9fbff 00100000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 12k freed
ACPI: Core revision 20060707
CPU0: Intel(R) Celeron(R) M processor 1.50GHz stepping 08
Total of 1 processors activated (2995.30 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs... it is
Freeing initrd memory: 5839k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: BIOS Bug: MCFG area at e0000000 is not E820-reserved
PCI: Not using MMCONFIG.
PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=3
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
PCI quirk: region 0480-04bf claimed by ICH6 GPIO
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Boot video device is 0000:03:00.0
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
ACPI: Embedded Controller [EC0] (gpe 28) interrupt mode.
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *11 12)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 12) *11
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 6 7 12)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 *6 7 12)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 12)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 12)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 12)
ACPI: Power Resource [GFAN] (off)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 13 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:0a: ioport range 0xa00-0xa0f has been reserved
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: faa00000-feafffff
PREFETCH window: bfe00000-dfefffff
PCI: Bus 2, cardbus bridge: 0000:01:01.0
IO window: 0000d000-0000d0ff
IO window: 0000d400-0000d4ff
PREFETCH window: 70000000-71ffffff
MEM window: 74000000-75ffffff
PCI: Bridge: 0000:00:1e.0
IO window: d000-dfff
MEM window: fa900000-fa9fffff
PREFETCH window: 70000000-72ffffff
ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:01.0 to 64
PCI: Setting latency timer of device 0000:00:1e.0 to 64
ACPI: PCI Interrupt 0000:01:01.0[A] -> GSI 17 (level, low) -> IRQ 177
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1206109117.116:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:01.cie00]
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Transitioning device [FN00] to D3
ACPI: Fan [FN00] (off)
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Processor [CPU1] (supports 8 throttling states)
ACPI: Thermal Zone [THRM] (51 C)
Time: acpi_pm clocksource has been installed.
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 201, io base 0x0000e480
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.1 -> GSI 19 (level, low) -> IRQ 209
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 209, io base 0x0000e800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ieee1394: Initialized config rom entry `ip1394'
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 217, io base 0x0000e880
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1d.3 to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.3: irq 169, io base 0x0000ec00
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usb 1-1: new low speed USB device using uhci_hcd and address 2
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 20 (level, low) -> IRQ 225
skge 1.6 addr 0xfa9f0000 irq 225 chip Yukon-Lite rev 9
skge eth0: addr 00:15:f2:47:84:da
ACPI: PCI Interrupt 0000:01:01.1 -> GSI 18 (level, low) -> IRQ 217
ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[217] MMIO=[fa9f7000-fa9f77ff] Max Packet=[2048] IR/IT contexts=[4/4]
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 201, io mem 0xfebffc00
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
usb 1-1: device descriptor read/all, error -71
udev: renamed network interface eth0 to eth1
ICH6: IDE controller at PCI slot 0000:00:1f.1
ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 217
ICH6: chipset revision 4
ICH6: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hdaMA, hdb
MA
ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdcio, hdd
io
Probing IDE interface ide0...
hda: HTS541060G9AT00, ATA DISK drive
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00e018000343916a]
hdb: TSSTcorpCD/DVDW SN-S082D, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
usb 5-4: new high speed USB device using ehci_hcd and address 3
usb 5-4: configuration #1 chosen from 1 choice
SCSI subsystem initialized
Initializing USB Mass Storage driver...
hda: max request size: 512KiB
hda: 117210240 sectors (60011 MB) w/7539KiB Cache, CHS=16383/255/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 hda7 >
scsi0 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 3
usb-storage: waiting for device to settle before scanning
hdb: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
usb 1-1: new low speed USB device using uhci_hcd and address 4
usb 1-1: configuration #1 chosen from 1 choice
usb 4-1: new full speed USB device using uhci_hcd and address 2
usb 4-1: configuration #1 chosen from 1 choice
usbcore: registered new driver hiddev
input: Logitech USB-PS/2 Optical Mouse as /class/input/input1
input: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.0-1
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Attempting manual resume
ReiserFS: hda6: found reiserfs format "3.6" with standard journal
ReiserFS: hda6: using ordered data mode
ReiserFS: hda6: journal params: device hda6, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda6: checking transaction log (hda6)
ReiserFS: hda6: Using r5 hash to sort names
Vendor: Corsair Model: Flash Voyager Rev: 1100
Type: Direct-Access ANSI SCSI revision: 00
usb-storage: device scan complete
eth1394: eth0: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
SCSI device sda: 15728640 512-byte hdwr sectors (8053 MB)
ts: Compaq touchscreen protocol output
sda: Write Protect is off
sda: Mode Sense: 43 00 00 00
sda: assuming drive cache: write through
sda: sda1
sd 0:0:0:0: Attached scsi removable disk sda
Linux agpgart interface v0.101 (c) Dave Jones
ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1b.0 to 64
nvidia: module license 'NVIDIA' taints kernel.
ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:03:00.0 to 64
NVRM: loading NVIDIA UNIX x86 Kernel Module 169.12 Thu Feb 14 17:53:07 PST 2008
intel_rng: FWH not detected
Yenta: CardBus bridge found at 0000:01:01.0 [1043:1177]
sdhci: Secure Digital Host Controller Interface driver, 0.12
sdhci: Copyright(c) Pierre Ossman
input: PC Speaker as /class/input/input2
pnp: Device 00:07 disabled.
parport_pc: probe of 00:07 failed with error -22
Yenta: ISA IRQ mask 0x04b8, PCI irq 177
Socket status: 30000006
pcmcia: parent PCI bridge I/O window: 0xd000 - 0xdfff
cs: IO port probe 0xd000-0xdfff: clean.
pcmcia: parent PCI bridge Memory window: 0xfa900000 - 0xfa9fffff
pcmcia: parent PCI bridge Memory window: 0x70000000 - 0x72ffffff
sdhci: SDHCI controller found at 0000:01:01.2 [1180:0822] (rev 17)
ACPI: PCI Interrupt 0000:01:01.2[C] -> GSI 19 (level, low) -> IRQ 209
mmc0: SDHCI at 0xfa9f7800 irq 209 DMA
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
ACPI: PCI Interrupt 0000:01:03.0[A] -> GSI 22 (level, low) -> IRQ 233
rt61 1.1.0 Beta 2 CVS http://rt2x00.serialmonkey.com
RT61: Vendor = 0x1814, Product = 0x0302
Bluetooth: HCI USB driver ver 2.9
usbcore: registered new driver hci_usb
Synaptics Touchpad, model: 1, fw: 6.1, id: 0xa3a0b3, caps: 0xa04713/0x10008
input: SynPS/2 Synaptics TouchPad as /class/input/input3
cs: IO port probe 0x100-0x3af: excluding 0x170-0x177 0x370-0x37f
cs: IO port probe 0x3e0-0x4ff: excluding 0x400-0x41f 0x4d0-0x4d7
cs: IO port probe 0x820-0x8ff: clean.
cs: IO port probe 0xc00-0xcf7: clean.
cs: IO port probe 0xa00-0xaff: clean.
Adding 779112k swap on /dev/hda7. Priority:-1 extents:1 across:779112k
loop: loaded (max 8 devices)
ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
ieee1394: sbp2: Try serialize_io=0 for better performance
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
NTFS driver 2.1.27 [Flags: R/W MODULE].
NTFS volume version 3.1.
ACPI: Battery Slot [BAT0] (battery present)
ACPI: AC Adapter [AC0] (on-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID]
ACPI: Sleep Button (CM) [SLPB]
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
skge eth1: enabling interface
ADDRCONF(NETDEV_UP): eth1: link is not ready
skge eth1: disabling interface
RT61: RfIcType= 3
ra0: no IPv6 routers present
RT61: RfIcType= 3
usb 5-4: USB disconnect, address 3
usb 5-4: new high speed USB device using ehci_hcd and address 5
scsi1 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 5
sda: sda1
sd 1:0:0:0: Attached scsi removable disk sda
hdb: tray open
end_request: I/O error, dev hdb, sector 0
Buffer I/O error on device hdb, logical block 0
Buffer I/O error on device hdb, logical block 1
Buffer I/O error on device hdb, logical block 2
Buffer I/O error on device hdb, logical block 3
Buffer I/O error on device hdb, logical block 4
Buffer I/O error on device hdb, logical block 5
Buffer I/O error on device hdb, logical block 6
Buffer I/O error on device hdb, logical block 7
hdb: tray open
hdb: tray open
end_request: I/O error, dev hdb, sector 4
hdb: tray open
hdb: tray open
hdb: tray open
hdb: tray open
hdb: tray open
printk: 10 messages suppressed.
hdb: tray open
hdb: tray open
hdb: tray open
hdb: status timeout: status=0xd0 { Busy }
ide: failed opcode was: unknown
hdb: DMA disabled
hdb: ATAPI reset complete
Szczególnie dziwne są ostatnie kilka linijek loga nie wiem dlaczego pojawiają się te błędy
