Zainstalowałem compiza wg tego schematu to był podany no i nie działa on, a raczej emerald. Nie wyświetla on title bara, a uruchomienie terminala pokazuje biały prostokącik o wymiarach normalnego terminala.
Poprzestawiałem pousuwałem, pozmieniałem na różne sposoby i nic :] Jakiś pomysł?
Widziałem, że modne jest podawanie wpisu:
november@debian:~ $ compiz --replace
/usr/bin/compiz.real (video) - Warn: No 8 bit GLX pixmap format, disabling YV12 image format
/usr/bin/compiz.real (core) - Warn: No GLXFBConfig for depth 32
/usr/bin/compiz.real (core) - Info: Couldn't bind redirected window 0x2e00148 to texture
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder26) Thu Dec 13 18:55:42 PST 2007
# xorg.conf (xorg X Window System server configuration file)
# package.
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen" 0 0
InputDevice "Synaptics Touchpad"
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "false"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
HorizSync 28.0 - 64.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "nVidia Corporation GeForce 8600M GT"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation GeForce 8600M GT"
Monitor "Generic Monitor"
DefaultDepth 16
SubSection "Display"
Depth 16
Modes "1280x1280"
EndSubSection
# Option "TripleBuffer" "true"
# Option "no GLXFBConfig for depth 32"
# Option "AddARGBVisuals" "True"
# Option "AddARGBGLXVisuals" "True"
# Option "DisableGLXRootClipping" "true"
EndSection
Section "Extensions"
# Option "Composite" "Enable"
EndSectionEDiT
po restarcie kompa nie mam panelu z akceoriami/miejscami/preferncjami etc
EDiT #2
po usunięciu compiza dalej nie mam tych pasków, co więcej pod rootem też ich nie ma. Reinstall metacity nic nie dał, jaki program jest odpowiedzialny za ów paski?
BTW bez metacity Xy miażdżą ^^
