mistrz@ubuntu:~$ sudo aptitude install wireless-tools module-assistant
Budowanie drzewa zależności
Reading state information... Gotowe
Reading extended state information
Initializing package states... Gotowe
Building tag database... Gotowe
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B of archives. After unpacking 0B will be used.
Writing extended state information... Gotowe
mistrz@ubuntu:~$ sudo m-a
Starting the Dialog UI...
Updated infos about 85 packages
Getting source for kernel version: 2.6.22-14-generic
Kernel headers available in /usr/src/linux-headers-2.6.22-14-generic
Creating symlink...
apt-get install build-essential
build-essential jest już w najnowszej wersji.
0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
Done!
Press Return to continue...
mistrz@ubuntu:~$ tar -zxvf rt2400-cvs-daily.tar.gz
rt2400-cvs-2008030913/
rt2400-cvs-2008030913/FAQ
rt2400-cvs-2008030913/Utility/
rt2400-cvs-2008030913/Utility/CVS/
rt2400-cvs-2008030913/Utility/CVS/Root
rt2400-cvs-2008030913/Utility/CVS/Repository
rt2400-cvs-2008030913/Utility/CVS/Entries.Log
rt2400-cvs-2008030913/Utility/ico/
rt2400-cvs-2008030913/Utility/ico/CVS/
rt2400-cvs-2008030913/Utility/ico/CVS/Root
rt2400-cvs-2008030913/Utility/ico/CVS/Repository
rt2400-cvs-2008030913/Utility/ico/CVS/Entries
rt2400-cvs-2008030913/THANKS
rt2400-cvs-2008030913/CHANGELOG
rt2400-cvs-2008030913/CVS/
rt2400-cvs-2008030913/CVS/Root
rt2400-cvs-2008030913/CVS/Repository
rt2400-cvs-2008030913/CVS/Entries.Log
rt2400-cvs-2008030913/LICENSE
rt2400-cvs-2008030913/Module/
rt2400-cvs-2008030913/Module/auth.c
rt2400-cvs-2008030913/Module/rt2x00debug.h
rt2400-cvs-2008030913/Module/ifcfg-ra0
rt2400-cvs-2008030913/Module/rtmp_main.c
rt2400-cvs-2008030913/Module/rt_config.h
rt2400-cvs-2008030913/Module/assoc.c
rt2400-cvs-2008030913/Module/CVS/
rt2400-cvs-2008030913/Module/CVS/Root
rt2400-cvs-2008030913/Module/CVS/Repository
rt2400-cvs-2008030913/Module/CVS/Entries.Log
rt2400-cvs-2008030913/Module/docs/
rt2400-cvs-2008030913/Module/docs/HOWTO-Gentoo
rt2400-cvs-2008030913/Module/docs/CVS/
rt2400-cvs-2008030913/Module/docs/CVS/Root
rt2400-cvs-2008030913/Module/docs/CVS/Repository
rt2400-cvs-2008030913/Module/docs/CVS/Entries
rt2400-cvs-2008030913/Module/docs/HOWTO-Mandrake10
rt2400-cvs-2008030913/Module/docs/HOWTO-Suse9
rt2400-cvs-2008030913/Module/docs/HOWTO-Debian
rt2400-cvs-2008030913/Module/docs/iwconfig_usage.txt
rt2400-cvs-2008030913/Module/sync.c
rt2400-cvs-2008030913/Module/rtmp_data.c
rt2400-cvs-2008030913/Module/rtmp_info.c
rt2400-cvs-2008030913/Module/mlme.h
rt2400-cvs-2008030913/Module/connect.c
rt2400-cvs-2008030913/Module/auth_rsp.c
rt2400-cvs-2008030913/Module/oid.h
rt2400-cvs-2008030913/Module/rtmp_init.c
rt2400-cvs-2008030913/Module/TESTING
rt2400-cvs-2008030913/Module/INSTALL
rt2400-cvs-2008030913/Module/rtmp.h
rt2400-cvs-2008030913/Module/mlme.c
rt2400-cvs-2008030913/Module/rt2460.h
rt2400-cvs-2008030913/Module/eeprom.c
rt2400-cvs-2008030913/Module/rtmp_wep.c
rt2400-cvs-2008030913/Module/rtmp_def.h
rt2400-cvs-2008030913/Module/Makefile
rt2400-cvs-2008030913/Module/rt2x00debug.c
rt2400-cvs-2008030913/Module/sanity.c
mistrz@ubuntu:~$ cd rt2400-cvs-2008030913/Module/
mistrz@ubuntu:~/rt2400-cvs-2008030913/Module$ sudo make
make[1]: Entering directory `/usr/src/linux-headers-2.6.22-14-generic'
  Building modules, stage 2.
  MODPOST 1 modules
make[1]: Leaving directory `/usr/src/linux-headers-2.6.22-14-generic'
mistrz@ubuntu:~/rt2400-cvs-2008030913/Module$ sudo make install
if ! [ -f rt2400.ko ]; then \
        make module; \
        fi
echo "2.6 module install"
2.6 module install
make -C /lib/modules/2.6.22-14-generic/build SUBDIRS=/home/mistrz/rt2400-cvs-2008030913/Module  modules_install
  INSTALL /home/mistrz/rt2400-cvs-2008030913/Module/rt2400.ko
  DEPMOD  2.6.22-14-generic
/sbin/depmod -a
*** Update /etc/modprobe.d/ralink alias for ra0
mistrz@ubuntu:~/rt2400-cvs-2008030913/Module$ modprobe rt2400
mistrz@ubuntu:~/rt2400-cvs-2008030913/Module$ ifconfig ra0 up
ra0: ERROR while getting interface flags: No such device
mistrz@ubuntu:~$ sudo /etc/init.d/networking restart
[sudo] password for mistrz:
 * Reconfiguring network interfaces...                                          eval: 1: Syntax error: "(" unexpected
run-parts: /etc/network/if-pre-up.d/wireless-tools exited with return code 2
SIOCSIFADDR: No such device
SIOCSIFNETMASK: No such device
Failed to bring up ra0.
        [ OK ]
mistrz@ubuntu:~$
Czym więc jest to ra0? Gdzie tkwi błąd?
Z góry dziękuję za pomoc
