to samo odnosnie javy.
flashplayer-mozilla
sun-java6-jre
sun-java6-plugin
sun-java6-plugin
aptitude install sun-java6-plugin
Budowanie drzewa zależności
Reading state information... Gotowe
Odczyt opisów zadań... Gotowe
Budowanie bazy etykiet... Gotowe
Następujące NOWE pakiety zostaną zainstalowane:
gcc-3.3-base{a} gsfonts-x11{a} libstdc++5{a} odbcinst1debian1{a} sun-java6-bin{a} sun-java6-jre{a} sun-java6-plugin unixodbc{a}
#Lenny
deb [url]http://ftp.pl.debian.org/debian/[/url] lenny main non-free contrib
deb-src [url]http://ftp.pl.debian.org/debian/[/url] lenny main non-free contrib
deb [url]http://security.debian.org/[/url] lenny/updates main contrib non-free
deb-src [url]http://security.debian.org/[/url] lenny/updates main contrib non-free
#Multimedia
deb [url]http://www.debian-multimedia.org[/url] lenny main
deb-src [url]http://www.debian-multimedia.org[/url] lenny main
#Compiz-Fusion
deb [url]http://download.tuxfamily.org/shames/debian-sid/desktopfx/unstable/[/url] ./
AMD64:/home/cichy# aptitude search sun-java
p ia32-sun-java5-bin - Sun Java(TM) Runtime Environment (JRE) 5.0 (32-bit)
p ia32-sun-java6-bin - Sun Java(TM) Runtime Environment (JRE) 6 (32-bit)
p sun-java5-bin - Sun Java(TM) Runtime Environment (JRE) 5.0 (architecture dependent files)
p sun-java5-demo - Sun Java(TM) Development Kit (JDK) 5.0 demos and examples
p sun-java5-doc - Sun JDK(TM) Documention -- integration installer
p sun-java5-fonts - Lucida TrueType fonts (from the Sun JRE)
p sun-java5-jdk - Sun Java(TM) Development Kit (JDK) 5.0
p sun-java5-jre - Sun Java(TM) Runtime Environment (JRE) 5.0 (architecture independent files)
p sun-java5-source - Sun Java(TM) Development Kit (JDK) 5.0 source files
pi sun-java6-bin - Sun Java(TM) Runtime Environment (JRE) 6 (architecture dependent files)
p sun-java6-demo - Sun Java(TM) Development Kit (JDK) 6 demos and examples
p sun-java6-doc - Sun JDK(TM) Documention -- integration installer
pi sun-java6-fonts - Lucida TrueType fonts (from the Sun JRE)
p sun-java6-jdk - Sun Java(TM) Development Kit (JDK) 6
pi sun-java6-jre - Sun Java(TM) Runtime Environment (JRE) 6 (architecture independent files)
p sun-java6-source - Sun Java(TM) Development Kit (JDK) 6 source files
AMD64:/home/cichy#
sun-java6-plugin
¦ciągnąlem stąd http://www.java.com/en/download/manual.jsp, wybierając pozycję:Bodzio pisze:Koledzy na dugu pisali że jest, no ale drobiazg. Można ściągnąć źródełka ze strony sun'a, zainstalować pakiet java-package i samemu sobie zrobić paczuszkę. http://dug.net.pl/faq/faq...akiecie_deb.php
I postepując według wyżej zacytowanego poradnika, otrzymuję:Linux x64 * filesize: 17.50 MB
$ fakeroot make-jpkg jre-6u5-linux-x64.bin
Creating temporary directory: /tmp/make-jpkg.ETfUVz5000
Loading plugins: blackdown-j2re.sh blackdown-j2sdk.sh common.sh ibm-j2re.sh ibm-j2sdk.sh j2re.sh j2sdk-doc.sh j2sdk.sh j2se.sh sun-j2re.sh sun-j2sdk-doc.sh sun-j2sdk.sh
Detected Debian build architecture: amd64
Detected Debian GNU type: x86_64-linux-gnu
No matching plugin was found.
Removing temporary directory: done
