zawieszanie si
Semerchet
zawieszanie się lennego
Post autor: Semerchet »
Mam Lennego. Zwiesza się i nic nie można zrobić. Wszystko martwe. Mruga tylko "Caps" i "Scroll" na klawiaturze. Zna ktoś może lekarstwo na tą przypadłość?
dmesg - wyrzuca taki log:
loko@debian:~$ dmesg
Linux version 2.6.24.3 (root@debian) (gcc version 4.2.3 (Debian 4.2.3-1)) #1 SMP Sat Mar 8 14:40:25 CET 2008
BIOS-provided physical RAM map:
 BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
 BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
 BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
 BIOS-e820: 0000000000100000 - 000000007fff0000 (usable)
 BIOS-e820: 000000007fff0000 - 000000007fff3000 (ACPI NVS)
 BIOS-e820: 000000007fff3000 - 0000000080000000 (ACPI data)
 BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved)
 BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
1151MB HIGHMEM available.
896MB LOWMEM available.
found SMP MP-table at 000f5080
Entering add_active_range(0, 0, 524272) 0 entries of 256 used
Zone PFN ranges:
  DMA             0 ->     4096
  Normal       4096 ->   229376
  HighMem    229376 ->   524272
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0:        0 ->   524272
On node 0 totalpages: 524272
  DMA zone: 32 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 4064 pages, LIFO batch:0
  Normal zone: 1760 pages used for memmap
  Normal zone: 223520 pages, LIFO batch:31
  HighMem zone: 2303 pages used for memmap
  HighMem zone: 292593 pages, LIFO batch:31
  Movable zone: 0 pages used for memmap
DMI 2.3 present.
ACPI: RSDP 000F69F0, 0014 (r0 GBT   )
ACPI: RSDT 7FFF3040, 0030 (r1 GBT    AWRDACPI 42302E31 AWRD  1010101)
ACPI: FACP 7FFF30C0, 0074 (r1 GBT    AWRDACPI 42302E31 AWRD  1010101)
ACPI: DSDT 7FFF3180, 3914 (r1 GBT    AWRDACPI     1000 MSFT  100000C)
ACPI: FACS 7FFF0000, 0040
ACPI: MCFG 7FFF6BC0, 003C (r1 GBT    AWRDACPI 42302E31 AWRD  1010101)
ACPI: APIC 7FFF6B00, 0068 (r1 GBT    AWRDACPI 42302E31 AWRD  1010101)
ACPI: PM-Timer IO Port: 0x408
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 15:4 APIC version 20
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode:  Flat.  Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 88000000 (gap: 80000000:70000000)
swsusp: Registered nosave memory region: 000000000009f000 - 00000000000a0000
swsusp: Registered nosave memory region: 00000000000a0000 - 00000000000f0000
swsusp: Registered nosave memory region: 00000000000f0000 - 0000000000100000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520177
Kernel command line: root=/dev/sda3 ro
mapped APIC to ffffb000 (fee00000)
mapped IOAPIC to ffffa000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Detected 2813.755 MHz processor.
Console: colour VGA+ 80x25
console [tty0] enabled
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 2070024k/2097088k available (1719k kernel code, 25800k reserved, 698k data, 220k init, 1179584k highmem)
virtual kernel memory layout:
    fixmap  : 0xfff4d000 - 0xfffff000   ( 712 kB)
    pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
    vmalloc : 0xf8800000 - 0xff7fe000   ( 111 MB)
    lowmem  : 0xc0000000 - 0xf8000000   ( 896 MB)
      .init : 0xc0363000 - 0xc039a000   ( 220 kB)
      .data : 0xc02add58 - 0xc035c588   ( 698 kB)
      .text : 0xc0100000 - 0xc02add58   (1719 kB)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 5633.48 BogoMIPS (lpj=9384780)
Security Framework initialized
SELinux:  Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 20100000 00000000 00000000 0000651d 00000000 00000000 00000000
monitor/mwait feature present.
using mwait in idle threads.
CPU: Trace cache: 12K uops, L1 D cache: 16K
CPU: L2 cache: 1024K
CPU: Hyper-Threading is disabled
CPU: After all inits, caps: bfebfbff 20100000 00000000 0000b180 0000651d 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (24) available
CPU0: Thermal monitoring enabled
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 11k freed
ACPI: Core revision 20070126
CPU0: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 01
Total of 1 processors activated (5633.48 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
net_namespace: 64 bytes
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Found Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub without MMCONFIG support.
PCI: PCI BIOS revision 3.00 entry at 0xfb120, last bus=4
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: EC: Look up EC in DSDT
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
Force enabled HPET at base address 0xfed00000
PCI quirk: region 0400-047f claimed by ICH6 ACPI/GPIO/TCO
PCI quirk: region 0480-04bf claimed by ICH6 GPIO
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 *12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnpacpi: exceeded the max number of mem resources: 12
pnp: PnP ACPI: found 15 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
NET: Registered protocol family 8
NET: Registered protocol family 20
hpet clockevent registered
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
hpet0: 3 64-bit timers, 14318180 Hz
ACPI: RTC can wake from S4
Time: tsc clocksource has been installed.
system 00:01: ioport range 0x4d0-0x4d1 has been reserved
system 00:01: ioport range 0x290-0x29f has been reserved
system 00:01: ioport range 0x800-0x87f has been reserved
system 00:01: ioport range 0x880-0x88f has been reserved
system 00:0b: ioport range 0x400-0x4bf could not be reserved
system 00:0c: iomem range 0xf0000000-0xf3ffffff could not be reserved
system 00:0d: iomem range 0xcf600-0xcffff has been reserved
system 00:0d: iomem range 0xf0000-0xf7fff could not be reserved
system 00:0d: iomem range 0xf8000-0xfbfff could not be reserved
system 00:0d: iomem range 0xfc000-0xfffff could not be reserved
system 00:0d: iomem range 0x7fff0000-0x7fffffff could not be reserved
system 00:0d: iomem range 0x0-0x9ffff could not be reserved
system 00:0d: iomem range 0x100000-0x7ffeffff could not be reserved
system 00:0d: iomem range 0xfec00000-0xfec00fff could not be reserved
system 00:0d: iomem range 0xfed13000-0xfed1dfff could not be reserved
system 00:0d: iomem range 0xfed20000-0xfed8ffff could not be reserved
system 00:0d: iomem range 0xfee00000-0xfee00fff could not be reserved
system 00:0d: iomem range 0xffb00000-0xffb7ffff could not be reserved
PCI: Bridge: 0000:00:01.0
  IO window: 8000-8fff
  MEM window: e0000000-e1ffffff
  PREFETCH window: d0000000-dfffffff
PCI: Bridge: 0000:00:1c.0
  IO window: 7000-7fff
  MEM window: disabled.
  PREFETCH window: disabled.
PCI: Bridge: 0000:00:1c.2
  IO window: disabled.
  MEM window: e4000000-e40fffff
PCI: Bridge: 0000:00:1e.0
  IO window: 9000-afff
  MEM window: e2000000-e3ffffff
ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:01.0 to 64
ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1c.0 to 64
ACPI: PCI Interrupt 0000:00:1c.2[C] -> GSI 18 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:00:1c.2 to 64
PCI: Setting latency timer of device 0000:00:1e.0 to 64
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
checking if image is initramfs... it is
Switched to high resolution mode on CPU 0
Freeing initrd memory: 5498k freed
audit: initializing netlink socket (disabled)
audit(1205089803.786:1): initialized
highmem bounce pool size: 64 pages
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Boot video device is 0000:01:00.0
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:01.:p cie00]
Allocate Port Service[0000:00:1c.:p cie00]
Allocate Port Service[0000:00:1c.:p cie02]
Allocate Port Service[0000:00:1c.2 :p cie00]
Allocate Port Service[0000:00:1c.2 :p cie02]
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
Using IPI No-Shortcut mode
registered taskstats version 1
Freeing unused kernel memory: 220k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Processor [CPU0] (supports 2 throttling states)
ACPI Exception (processor_core-0816): AE_NOT_FOUND, Processor Device is not present [20070126]
tg3.c:v3.86 (November 9, 2007)
ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 18 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:03:00.0 to 64
eth0: Tigon3 [partno(BCM95789) rev 4101 PHY(5750)] (PCI Express) 10/100/1000Base-T Ethernet 00:14:85:3a:9b:ab
eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] WireSpeed[1] TSOcap[1]
eth0: dma_rwctrl[76180000] dma_mask[64-bit]
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 18, io base 0x0000bc00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
udev: renamed network interface eth0 to eth1
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 17, io base 0x0000b400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1d.3 to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000b800
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
PCI: cache line size of 128 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 18, io mem 0xe4104000
SCSI subsystem initialized
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
libata version 3.00 loaded.
IT8212: IDE controller (0x1283:0x8212 rev 0x13) at  PCI slot 0000:04:06.0
ACPI: PCI Interrupt 0000:04:06.0[A] -> GSI 22 (level, low) -> IRQ 20
it821x: controller in pass through mode.
IT8212: 100% native mode on irq 20
    ide0: BM-DMA at 0xa400-0xa407, BIOS settings: hda :p io, hdb :p io
    ide1: BM-DMA at 0xa408-0xa40f, BIOS settings: hdc :p io, hdd :p io
Probing IDE interface ide0...
usb 3-1: new low speed USB device using uhci_hcd and address 2
Probing IDE interface ide1...
usb 3-1: configuration #1 chosen from 1 choice
usbcore: registered new interface driver hiddev
input: A4Tech PS/2+USB Mouse as /class/input/input1
input: USB HID v1.10 Mouse [A4Tech PS/2+USB Mouse] on usb-0000:00:1d.2-1
usbcore: registered new interface driver usbhid
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
ata_piix 0000:00:1f.2: version 2.12
ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:1f.2 to 64
scsi0 : ata_piix
scsi1 : ata_piix
ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
ata1.00: HPA detected: current 156299375, native 156301488
ata1.00: ATA-6: ST380817AS, 3.42, max UDMA/133
ata1.00: 156299375 sectors, multi 16: LBA48 NCQ (not used)
ata1.00: configured for UDMA/133
ata2.00: ATAPI: HL-DT-ST DVDRAM GSA-4163B, A102, max UDMA/33
ata2.00: configured for UDMA/33
scsi 0:0:0:0: Direct-Access     ATA      ST380817AS       3.42 PQ: 0 ANSI: 5
scsi 1:0:0:0: CD-ROM            HL-DT-ST DVDRAM GSA-4163B A102 PQ: 0 ANSI: 5
Driver 'sd' needs updating - please use bus_type methods
sd 0:0:0:0: [sda] 156299375 512-byte hardware sectors (80025 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
 sda:<4>Driver 'sr' needs updating - please use bus_type methods
 sda1 sda2 < sda5 sda6 sda7 sda8 > sda3
sd 0:0:0:0: [sda] Attached SCSI disk
sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 1:0:0:0: Attached scsi CD-ROM sr0
sd 0:0:0:0: Attached scsi generic sg0 type 0
sr 1:0:0:0: Attached scsi generic sg1 type 5
Attempting manual resume
swsusp: Marking nosave pages: 000000000009f000 - 0000000000100000
swsusp: Basic memory bitmaps created
swsusp: Basic memory bitmaps freed
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting.  Commit interval 5 seconds
EXT3-fs: sda3: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 81087
ext3_orphan_cleanup: deleting unreferenced inode 33629
ext3_orphan_cleanup: deleting unreferenced inode 64511
ext3_orphan_cleanup: deleting unreferenced inode 64275
ext3_orphan_cleanup: deleting unreferenced inode 64274
ext3_orphan_cleanup: deleting unreferenced inode 64273
EXT3-fs: sda3: 6 orphan inodes deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
intel_rng: FWH not detected
Linux agpgart interface v0.102
input: PC Speaker as /class/input/input2
ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 19 (level, low) -> IRQ 19
input: Power Button (FF) as /class/input/input3
ACPI: Power Button (FF) [PWRF]
input: Power Button (CM) as /class/input/input4
ACPI: Power Button (CM) [PWRB]
Real Time Clock Driver v1.12ac
ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1b.0 to 64
parport_pc 00:09: reported by Plug and Play ACPI
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
hda_codec: Unknown model for ALC882, trying auto-probe from BIOS...
Adding 682720k swap on /dev/sda7.  Priority:-1 extents:1 across:682720k
EXT3 FS on sda3, internal journal
loop: module loaded
fuse init (API version 7.9)
device-mapper: ioctl: 4.12.0-ioctl (2007-10-02) initialised: [email]dm-devel@redhat.com[/email]
EXT3 FS on sda8, internal journal
tg3: eth1: Link is up at 100 Mbps, full duplex.
tg3: eth1: Flow control is off for TX and off for RX.
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[fglrx] Maximum main memory to use for locked dma buffers: 1899 MBytes.
[fglrx] ASYNCIO init succeed!
[fglrx] PAT is enabled successfully!
[fglrx] module loaded - fglrx 8.47.3 [Feb 25 2008] on minor 0
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[fglrx] Reserve Block - 0 offset =  0X7ffb000 length = 0X5000
[fglrx] Reserve Block - 1 offset =  0X0 length = 0X1000000
[fglrx] Reserve Block - 2 offset =  0X1ffff000 length = 0X1000
[fglrx] Reserve Block - 3 offset =  0Xffc0000 length = 0X40000
[fglrx] interrupt source 20008000 successfully enabled
[fglrx] enable ID = 0x00000008
[fglrx] Receive enable interrupt message with irqEnableMask: 20008000
[fglrx] interrupt source 10000000 successfully enabled
[fglrx] enable ID = 0x00000009
[fglrx] Receive enable interrupt message with irqEnableMask: 10000000
eth1: no IPv6 routers present
[fglrx:firegl_lock] *ERROR* Process 2806 is using illegal context 0x00000006
loko@debian:~$
Czyżby przyczyna był error fglrx??
Zajrzyj do /var/log/Xorg.0.log tam powinny być ewentualne błędy (EE), odnośnie twojego problemu.
