wreszcie udało mi się zrekonstruować logi
(nie widzi dysku, przez co się na nim nie zapisywały, więc musiałem cyknąc kilka fotek, a że aparcik kiszka jakość, więc wychodziło około 12 na jeden ekran). Oto co wypociłem:
15) *11
ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
ACPI: Embedded Controller [ECO] (gpe 23) interrupt mode.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 9 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
PCI: Bus 2, cardbus bridge: 0000:01:02.0
IO window: 0000c400-0000c4ff
IO window: 0000c800-0000c8ff
PREFETCH window: 9c000000-9dffffff
MEM window: ce000000-cfffffff
PCI: Bridge: 0000:00:1e.0
IO window: c000-dfff
MEM window: cc000000-cfffffff
PREFETCH window: 9c000000-9fffffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
ACPI: PCI Interrupt 0000:01:02.0[A] -> GSI 17 (level, low) -> IRQ 169
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1170204501.784:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 1
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Processor [CPU0] (supports 8 throttling states)
ACPI Exception (acpi_processor-0681): AE_NOT_FOUND, Processor Device is not pres
ent [20060707]
ACPI: Getting cpuindex for acpiid 0x1
ACPI: Thermal Zone [THRM] (56 C)
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 177, io base 0x00001200
usb sub1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ieee1394: Initialized config rom entry 'ip1394'
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 185, io base 0x00001220
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Uniform Multi-Platfor E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 193
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 193, io base 0x00001240
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
Time: acpi_pm clocksource has been installed.
PCI: Enabling device 0000:00:1d.7 (0000 -> 0002)
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 177, io mem 0x20000000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosesn from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
8139cp 0000:01:04.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
8139cp 0000:01:04.0: Try the "8139too" driver instead.
ACPI: PCI Interrupt 0000:01:02.[C] -> GSI 19 (level, low) -> IRQ 185
ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[185] MMIO=[fedff800-fedfffff] Ma
x Packet=[2048] IR/IT contexts=[4/8]
8139too Fast Ethernet driver 0.9.27
ACPI: PCI Interrupt 0000:01:04.0[A] -> GSI 20 (level, low) -> IRQ 201
eth0: RealTek RTL8139 at 0xc000, 00:40:d0:90:96:41, IRQ 201
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
SCSI subsystem initialized
libata version 2.00 loaded.
ahci 0000:00:1f.2: version 2.0
ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 185
ACPI: PCI Interrupt for device 0000:00:1f.2 disabled
ahci: probe of 0000:00:1f.2 failedwith error-12
ata_piix 0000:00:1f.2: version 2.00
ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
PCI: Enabling device 0000:00:1f.2 (0000 -> 0001)
PCI: Setting latency timer of device 0000:00:1f.2 to 64
ata1: SATA max UDMA/133 cmd 0x1F0 ctl 0x3F6 bmdma 0x1100 irq 14
scsi0 : ata_piix
ata1.00: ATA-7, max UDMA/100, 117210240 sectors: LBA
ata1.00: ata1: dev 0 multi count 16
ata1.00: aplying bridge limits
ata1.00: configured for UDMA/100
Vendor: ATA Model: FUJITSU MHV2060A Rev: 0000
Type: Direct-Access ANSI SCSI revision: 05
ata2:PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1108 irq 15
scsi1 : ata_piix
ata2.00: ATAPI, max UDMA/33
ata2.01: qc timeout (cmd 0xa1)
ata2.01: failed to IDENTIFY (I/O error, err_mask=0x4)
ata2: failed to recover some devices, retrying in 5 secs
ata2.00: configured for UDMA/33
Vendor: QSI Model: DVD+-RW SDW-082K Rev: PX45
Type: CD-ROM ANSI SCSI revision: 05
SCSI device sda: 117210240 512-byte hdwr sectors (60012 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda Write Protect is off
sda: sda1 sda2 sda3 <sda5> sda4
sd 0:0:0:0 Attached sci disk sda
Done.
Begin: Mounting root file system...
Begin: Running /scripts/local-top...
ide0: I/O resource 0x1F0-0x1F7 not free
ide0: ports already in use, skipping probe
ide1: I/O resource 0x1F0-0x177 not free
ide1: ports already in use, skipping probe
Done.
Begin: Waiting for root file system... ...
Done.
check root= bootarg cat /proc/cmdline
or missing modules, devices: cat /proc/modules ls/dev
ALERT! /dev/hda1 does not exist. Dropping to a shell!
BusyBox v1.1.3 (Debian 1:1.1.3-3) Built-in shell (ash)
Enter 'help' for a list of built-in commands
/bin/sh: can't access tty; tab control turned off
nie bardzo wiem, czego się czepić ...
//edit:
sprawa rozwiązana, jakby ktoś miał podobny problem i nie mógł sobie poradzić, to odsyłam
do tego tematu.
Wparwdzie muszę jeszcze troszkę powalczyć z moim debiankiem, ale to gwarantuje, że system wstaje
