Ostanio zaktualizwalem system do wersji Lenny i mam problem z compiz-fusion. Bezposrednio po updacie wykonalem:
apt-get install compiz-fusion-kde
apt-get install fusion-iconKod: Zaznacz cały
http://download.tuxfamily.org/shames/debian-lenny/desktopfx/unstable//Oto moj xorg.conf
# package.
Section "Files"
# path to defoma fonts
EndSection
Section "Module"
Load "dbe"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
EndSection
Identifier "Configured Mouse"
#Identifier "Mouse[1]"
Driver "evdev"
Option "CorePointer"
Option "Name" "Logitech USB Receiver" #this should be the name of the device which I made bold here.
Option "ZAxisMapping" "4 5"
Option "Resolution" "800"
Option "Buttons" "9"
EndSection
Section "Device"
Identifier "Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
Driver "i810"
BusID "PCI:0:2:0"
Option "XAANoOffscreenPixmaps" "true"
Option "AllowGLXWithComposite" "true"
Option "RenderAccel" "true"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x800"
EndSubSection
Depth 4
Modes "1280x800"
EndSubSection
Depth 8
Modes "1280x800"
EndSubSection
Depth 15
Modes "1280x800"
EndSubSection
Depth 16
Modes "1280x800"
EndSubSection
Depth 24
Modes "1280x800"
EndSubSection
Option "TripleBuffer" "true"
Option "no GLXFBConfig for depth 32"
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "DisableGLXRootClipping" "true"
Option "AddARGBGLXVisuals" "true"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Synaptics Touchpad"
Option "AIGLX" "on"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSectionKod: Zaznacz cały
compiz-managerKod: Zaznacz cały
Checking for Xgl: not present.
Detected PCI ID for VGA: 00:02.0 0300: 8086:27a2 (rev 03) (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1280x800) to maximum 3D texture size (2048): Passed.
Checking for nVidia: not present.
Checking for FBConfig: present.
Starting emerald
/usr/bin/compiz.real (core) - Fatal: No GLXFBConfig for default depth, this isn't going to work.
/usr/bin/compiz.real (core) - Error: Failed to manage screen: 0
/usr/bin/compiz.real (core) - Fatal: No manageable screens found on display :0.0A po probie wyboru jakiegos tematu z poziomu emeralda
Reloading...EDIT:
Rozwiazaniem w moim przypadku byla instalacja pakietow mesa-dri. Xorg byl w porzadku.
