dpkg-reconfigure xserver-xorgKod: Zaznacz cały
apt-get update && apt-get install xserver-xorg xbase-clients xfonts-base xtermKod: Zaznacz cały
dpkg -l | grep linux-headersKod: Zaznacz cały
aptitude install linux-headers-`uname -rKod: Zaznacz cały
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Fedora 8 Red Hat, Inc.
Current Operating System: Linux redkad 2.6.23.15-137.fc8 #1 SMP Sun Feb 10 17:48:34 EST 2008 i686
Build Date: 12 February 2008
Build ID: xorg-x11-server 1.3.0.0-42.fc8
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Mar 6 13:03:24 2008
(==) ServerLayout "Default Layout"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "<default monitor>"
(**) | |-->Device "Videocard0"
(WW) No monitor specified for screen "Screen0".
Using a default monitor configuration.
(**) |-->Input Device "Keyboard0"
(==) |-->Input Device "<default pointer>"
(WW) The core pointer device wasn't specified explicitly in the layout.
Using the default mouse configuration.
(==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
(==) RgbPath set to "/usr/share/X11/rgb"
(**) ModulePath set to "/usr/lib/xorg/modules/extensions/nvidia,/usr/lib/xorg/modules"
(**) Option "AIGLX" "on"
(**) Extension "Composite" is enabled
(II) Loader magic: 0x820cce0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: 00:00:0: chip 1002,5958 card 1002,5958 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 1002,5978 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:06:0: chip 1002,597c card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:12:0: chip 1002,4380 card 1462,7388 rev 00 class 01,06,01 hdr 00
(II) PCI: 00:13:0: chip 1002,4387 card 1462,7388 rev 00 class 0c,03,10 hdr 80
(II) PCI: 00:13:1: chip 1002,4388 card 1462,7388 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:2: chip 1002,4389 card 1462,7388 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:3: chip 1002,438a card 1462,7388 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:4: chip 1002,438b card 1462,7388 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:5: chip 1002,4386 card 1462,7388 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:14:0: chip 1002,4385 card 1462,7388 rev 14 class 0c,05,00 hdr 80
(II) PCI: 00:14:1: chip 1002,438c card 1462,7388 rev 00 class 01,01,8a hdr 00
(II) PCI: 00:14:2: chip 1002,4383 card 1462,7388 rev 00 class 04,03,00 hdr 00
(II) PCI: 00:14:3: chip 1002,438d card 1462,7388 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:14:4: chip 1002,4384 card 0000,0000 rev 00 class 06,04,01 hdr 81
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,0421 card 1458,3445 rev a1 class 03,00,00 hdr 00
(II) PCI: 02:00:0: chip 10ec,8168 card 1462,388c rev 01 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,3), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:2:0), (0,1,1), BCTRL: 0x001b (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfa000000 - 0xfeafffff (0x4b00000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:6:0), (0,2,2), BCTRL: 0x0003 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfeb00000 - 0xfebfffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:20:3), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 3: bridge is at (0:20:4), (0,3,3), BCTRL: 0x0003 (VGA_EN is cleared)
(--) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0421) rev 161, Mem @ 0xfd000000/24, 0xd0000000/28, 0xfa000000/25, I/O @ 0xd800/7, BIOS @ 0xfeae0000/17
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe0000000 to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xfebff000 - 0xfebfffff (0x1000) MX[B]
[1] -1 0 0xf9ff4000 - 0xf9ff7fff (0x4000) MX[B]
[2] -1 0 0xf9fff000 - 0xf9fff0ff (0x100) MX[B]
[3] -1 0 0xf9ffa000 - 0xf9ffafff (0x1000) MX[B]
[4] -1 0 0xf9ffb000 - 0xf9ffbfff (0x1000) MX[B]
[5] -1 0 0xf9ffc000 - 0xf9ffcfff (0x1000) MX[B]
[6] -1 0 0xf9ffd000 - 0xf9ffdfff (0x1000) MX[B]
[7] -1 0 0xf9ffe000 - 0xf9ffefff (0x1000) MX[B]
[8] -1 0 0xf9fff800 - 0xf9fffbff (0x400) MX[B]
[9] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[10] -1 0 0xfeae0000 - 0xfeafffff (0x20000) MX[B](B)
[11] -1 0 0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
[12] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[13] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
[14] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[15] -1 0 0x0000ff00 - 0x0000ff0f (0x10) IX[B]
[16] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[17] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[18] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[19] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[20] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[21] -1 0 0x00008000 - 0x0000800f (0x10) IX[B]
[22] -1 0 0x00009000 - 0x00009003 (0x4) IX[B]
[23] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B]
[24] -1 0 0x0000b000 - 0x0000b003 (0x4) IX[B]
[25] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
[26] -1 0 0x0000d800 - 0x0000d87f (0x80) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfebff000 - 0xfebfffff (0x1000) MX[B]
[5] -1 0 0xf9ff4000 - 0xf9ff7fff (0x4000) MX[B]
[6] -1 0 0xf9fff000 - 0xf9fff0ff (0x100) MX[B]
[7] -1 0 0xf9ffa000 - 0xf9ffafff (0x1000) MX[B]
[8] -1 0 0xf9ffb000 - 0xf9ffbfff (0x1000) MX[B]
[9] -1 0 0xf9ffc000 - 0xf9ffcfff (0x1000) MX[B]
[10] -1 0 0xf9ffd000 - 0xf9ffdfff (0x1000) MX[B]
[11] -1 0 0xf9ffe000 - 0xf9ffefff (0x1000) MX[B]
[12] -1 0 0xf9fff800 - 0xf9fffbff (0x400) MX[B]
[13] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[14] -1 0 0xfeae0000 - 0xfeafffff (0x20000) MX[B](B)
[15] -1 0 0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
[16] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[17] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[21] -1 0 0x0000ff00 - 0x0000ff0f (0x10) IX[B]
[22] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[23] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[24] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[25] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[26] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[27] -1 0 0x00008000 - 0x0000800f (0x10) IX[B]
[28] -1 0 0x00009000 - 0x00009003 (0x4) IX[B]
[29] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B]
[30] -1 0 0x0000b000 - 0x0000b003 (0x4) IX[B]
[31] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
[32] -1 0 0x0000d800 - 0x0000d87f (0x80) IX[B](B)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/nvidia//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
ABI class: X.Org Server Extension, version 0.1
(II) NVIDIA GLX Module 169.09 Fri Jan 11 15:31:25 PST 2008
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so
compiled for 1.3.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules/fonts//libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 1.3.0, module version = 1.2.2
ABI class: X.Org XInput driver, version 0.7
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
compiled for 1.3.0, module version = 1.2.3
(II) NVIDIA dlloader X Driver 169.09 Fri Jan 11 14:41:00 PST 2008
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules/extensions/nvidia//libwfb.so
(II) Module wfb: vendor="NVIDIA Corporation"
compiled for 7.1.99.2, module version = 1.0.0
(II) LoadModule: "ramdac"(II) Module already built-in
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[18] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[19] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[20] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[23] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[24] -1 0 0x0000ff00 - 0x0000ff0f (0x10) IX[B]
[25] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[26] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[27] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[28] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[29] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[30] -1 0 0x00008000 - 0x0000800f (0x10) IX[B]
[31] -1 0 0x00009000 - 0x00009003 (0x4) IX[B]
[32] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B]
[33] -1 0 0x0000b000 - 0x0000b003 (0x4) IX[B]
[34] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
[35] -1 0 0x0000d800 - 0x0000d87f (0x80) IX[B](B)
[36] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[37] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Enabling PCI device
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "AddARGBGLXVisuals" "True"
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0): enabled.
(II) NVIDIA(0): NVIDIA GPU GeForce 8500 GT (G86) at PCI:1:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 524288 kBytes
(--) NVIDIA(0): VideoBIOS: 60.86.50.00.00
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 8500 GT at PCI:1:0:0:
(--) NVIDIA(0): LG FLATRON 775FT Plus (CRT-1)
(--) NVIDIA(0): LG FLATRON 775FT Plus (CRT-1): 400.0 MHz maximum pixel clock
(II) NVIDIA(0): Assigned Display Device: CRT-1
(==) NVIDIA(0):
(==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
(==) NVIDIA(0): will be used as the requested mode.
(==) NVIDIA(0):
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): "nvidia-auto-select"
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
(--) NVIDIA(0): DPI set to (104, 113); computed from "UseEdidDpi" X config
(--) NVIDIA(0): option
(**) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
(II) NVIDIA(0): Initialized GPU GART.
(II) NVIDIA(0): Setting mode "nvidia-auto-select"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(**) Option "CoreKeyboard"
(**) Keyboard0: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Keyboard0: XkbLayout: "pl"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(WW) <default pointer>: No Device specified, looking for one...
(II) <default pointer>: Setting Device option to "/dev/input/mice"
(--) <default pointer>: Device: "/dev/input/mice"
(==) <default pointer>: Protocol: "Auto"
(**) Option "CorePointer"
(**) <default pointer>: Core Pointer
(==) <default pointer>: Emulate3Buttons, Emulate3Timeout: 50
(**) <default pointer>: ZAxisMapping: buttons 4 and 5
(**) <default pointer>: Buttons: 9
(**) <default pointer>: Sensitivity: 1
(II) XINPUT: Adding extended input device "<default pointer>" (type: MOUSE)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) <default pointer>: Setting mouse protocol to "ExplorerPS/2"
(II) <default pointer>: ps2EnableDataReporting: succeeded
(II) NVIDIA(0): Setting mode "1152x864"
