[+] putty drukowanie
- mesiu84
- Beginner
postawiłem sobie serwer bazodanowy pod solarisem i spod Debiana/Ubuntu łączę się z nim za pośrednictwem putty. Na serwerze mam generować wydruki i drukować je u siebie na komputerze lokalnym do urządzenia /dev/lp0. Wszystko działa fajnie jak drukuję sobie lokalnie, ale jak tylko spróbuję wydrukować za pośrednictwem putty (w ustawieniach mam /dev/lp0) to nic mi nie drukuje, nawet nie dodają się zadania do kolejki drukowania, co może być nie tak?
http://www.jtz.org.pl/Html/Printing-HOWTO.pl.html
http://www.chiark.greenend.org.uk/~sgta ... y/faq.html
4.3.10 Remote-controlled printing
A lot of VT100-compatible terminals support printing under control
of the remote server. PuTTY supports this feature as well, but it is
turned off by default.
To enable remote-controlled printing, choose a printer from
the `Printer to send ANSI printer output to' drop-down list
box. This should allow you to select from all the printers you
have installed drivers for on your computer. Alternatively, you
can type the network name of a networked printer (for example,
`\\printserver\printer1') even if you haven't already installed a
driver for it on your own machine.
When the remote server attempts to print some data, PuTTY will send
that data to the printer _raw_ - without translating it, attempting
to format it, or doing anything else to it. It is up to you to
ensure your remote server knows what type of printer it is talking
to.
Since PuTTY sends data to the printer raw, it cannot offer options
such as portrait versus landscape, print quality, or paper tray
selection. All these things would be done by your PC printer driver
(which PuTTY bypasses); if you need them done, you will have to find
a way to configure your remote server to do them.
To disable remote printing again, choose `None (printing disabled)'
from the printer selection list. This is the default state.
- mesiu84
- Beginner
no dobra wszystko fajnie, pisze że powinno drukować, ale gdy w Putty wybieram urządzenie /dev/lp0 nic mi nie drukuje, a zgodnie z tym powinno mi drukować, gdzie jest problem??? zaznaczam, że jak drukuję z localhost wszystko idzie bez problemów, nie posiadam drukarek sieciowych i chciałbym to rozwiązać bez korzystania z nich, skorzystam z nich ewentualnie podczas gdy nie będzie już innego rozwiązania
[ Dodano: 2008-03-07, 17:57 ]
informacje dodatkowe
dzisiaj ponownie stoczyłem batalię z tym małym czymś i przegrałem
ale z tego co mi putty wyrzuca na konsolę to że nie ma praw dla /dev/lp0, dziwne troszeczkę bo dałem mu prawa 777 a i tak nic z tego, gdzie może być problem?
[ Dodano: 2008-03-11, 13:57 ]
jak to ostatnio dosc czesto bywa na tym forum jestem zmuszony sam sobie udzielic odpowiedzi.
tak na przyszlosc, jak ktos bedzie mial podobno sytuacje to w linii gdzie sie wpisuje sciezke do drukarki nalezy wpisac: lp -d nazwa_drukarki, chodzi o ta nazwe co jest w cups'ie, dodatkowo jeszcze polecam odblokowac na firewallu port 631, pozdrawiam i dziekuje sobie za odpowiedz :-)
