Konfiguracja xorg.conf dla karty intel gma 950
menteith
Post autor: menteith »
Witam!
Wiem ze temat wielokrotnie walkowany, ale ja wciaz nie znalazlem rozwiazania dla swojej karty - nie mam nvidii do ktorej konfigi sa latwo dostepne, ani nawet ati.Moja karta to intel gma 950 - posiadam laptopa. Mimo modyfikacji xorg.conf wciaz nie mam obramowan w oknach. Uzywam Etch'a. Oto moj xorg:
# package.
Section "Files"
	FontPath	"/usr/share/fonts/X11/misc"
	FontPath	"/usr/X11R6/lib/X11/fonts/misc"
	FontPath	"/usr/share/fonts/X11/cyrillic"
	FontPath	"/usr/X11R6/lib/X11/fonts/cyrillic"
	FontPath	"/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/Type1"
	FontPath	"/usr/X11R6/lib/X11/fonts/Type1"
	FontPath	"/usr/share/fonts/X11/100dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi"
	FontPath	"/usr/share/fonts/X11/75dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi"
	# path to defoma fonts
	FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load "dbe"
	Load "glx"
	Load	"i2c"
	Load	"bitmap"
	Load	"ddc"
	Load	"dri"
	Load	"extmod"
	Load	"freetype"
	Load	"glx"
	Load	"int10"
	Load	"vbe"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"pl"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"		"/dev/input/mice"
	Option		"Protocol"		"ImPS/2"
	Option		"Emulate3Buttons"	"true"
EndSection
	Identifier	"Synaptics Touchpad"
	Driver		"synaptics"
	Option		"SendCoreEvents"	"true"
	Option		"Device"		"/dev/psaux"
	Option		"Protocol"		"auto-dev"
	Option		"HorizScrollDelta"	"0"
EndSection
Section "Device"
	Identifier	"Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
	Driver		"i810"
	BusID		"PCI:0:2:0"
Option "AddARGBGLXVisuals" "On"
Option "XAANoOffscreenPixmaps" "true"
Option "RenderAccel" "true"
EndSection
Section "Monitor"
	Identifier	"Generic Monitor"
	Option		"DPMS"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
	Monitor		"Generic Monitor"
	DefaultDepth	24
	SubSection "Display"
		Depth		1
		Modes		"1280x800"
	EndSubSection
		Depth		4
		Modes		"1280x800"
	EndSubSection
		Depth		8
		Modes		"1280x800"
	EndSubSection
		Depth		15
		Modes		"1280x800"
	EndSubSection
		Depth		16
		Modes		"1280x800"
	EndSubSection
		Depth		24
		Modes		"1280x800"
	EndSubSection
Option         "TripleBuffer" "true"
Option         "no GLXFBConfig for depth 32"
Option         "AddARGBVisuals" "True"
Option         "AddARGBGLXVisuals" "True"
Option         "DisableGLXRootClipping" "true"
EndSection
Section "ServerLayout"
	Identifier	"Default Layout"
	Screen		"Default Screen"
	InputDevice	"Generic Keyboard"
	InputDevice	"Configured Mouse"
	InputDevice	"Synaptics Touchpad"
	Option "AIGLX" "true"
EndSection
Section "DRI"
	Mode	0666
EndSection
Section "Extensions"
    Option         "Composite" "Enable"
	Option "RENDER" "Enable"
EndSection
po wykonaiu $beryl otrzymuje:
ibGL warning: 3D driver claims to not support visual 0x5b
(beryl-manager:3771): Gtk-CRITICAL **: gtk_check_menu_item_set_active: assertion `GTK_IS_CHECK_MENU_ITEM (check_menu_item)' failed
* Beryl system compatiblity check                            *
Detected xserver                                : AIGLX
Checking Display :0.0 ...
Checking for XComposite extension               : passed (v0.3)
Checking for XDamage extension                  : passed
Checking for RandR extension                    : passed
Checking for XSync extension                    : passed
Checking Screen 0 ...
libGL warning: 3D driver claims to not support visual 0x5b
Checking for GLX_SGIX_fbconfig                  : passed
Checking for GLX_EXT_texture_from_pixmap        : passed
Checking for non power of two texture support   : passed
Checking maximum texture size                   : passed (2048x2048)
Reloading options
beryl: decoration: property ignored because version is 20070319 and decoration plugin version is 20061011
Beryla instalowalem w nastpeujacy sposob:
#apt-get install beryl-manager emerald-themes
z repozytoriow:
deb [url]http://debian.beryl-project.org/[/url] etch main
deb-src [url]http://debian.beryl-project.org/[/url] etch main
Dodam ze w emeraldzie nie moge zmienic tematu na inny - wydaje mi sie ze beryl wskazuje na to wypluwajac:
nehalem
Post autor: nehalem »
Kartę Masz dobrze skonfigurowaną, problemem jest niezgodność beryla z emeraldem. Proponuję jako menedżera okien użyć aquamarine, beryl wskoczy bez problemu. Jeśli koniecznie Chcesz używać pulpitu 3D, radzę skorzystać z compiz fusion, sam jestem zdziwiony jak świetnie karty intelowskie sobie z tym radzą. Wcześniej używałem karty ATI i nie ma porównania.
