Zmienilem karte specjalnie zeby moc bez problemu odpalic fuzjona... zaplacilem 200zl a efekt jest gorszy niz byl.
po wlaczeniu compiza wydajnosc w spoczynku ok 75fps, gdy tylko rusze jakies okno spada ponizej 10fps! Mierzone benchamrkiem compiza. Uaktywnione mam 6 pluginow wiec niema mowy o tym ze karta jest za salaba. Blagam o pomoc gdyz persektywa zmarnowania 200zl troche mnie przeraza...
Karta jaka posiadam to Asus 7600GT Silent. Moj konfig wyglada nastepujaco:
xorg.conf
Section "Module"
Load "glx"
EndSection
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
EndSection
Section "Device"
Identifier "nVidia Corporation G70 [GeForce 7600 GT]"
Driver "nvidia"
BusID "PCI:5:0:0"
Option "XAANoOffscreenPixmaps" "true"
Option "AllowGLXWithComposite" "true"
EndSection
Section "Monitor"
Identifier "BenQ FP91GP"
Option "DPMS"
HorizSync 31-81
VertRefresh 56-76
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation G70 [GeForce 7600 GT]"
Monitor "BenQ FP91GP"
DefaultDepth 24
SubSection "Display"
Modes "1280x1024" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
Option "TripleBuffer" "true"
Option "no GLXFBConfig for depth 32"
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "DisableGLXRootClipping" "True"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSectionstery jakie instalowalem to 169.09 i 100.14.06, efekt na obu identyczny.
$ glxinfo |grep dir
direct rendering: Yes
$ glxgears #przy wlaczonym compizie
11604 frames in 6.8 seconds = 1709.847 FPS
4671 frames in 5.2 seconds = 905.318 FPS
10712 frames in 7.6 seconds = 1408.839 FPS
5760 frames in 5.7 seconds = 1005.941 FPS
5540 frames in 5.0 seconds = 1107.993 FPS
7239 frames in 5.1 seconds = 1426.571 FPS
$ glxgears #bez compiza
23557 frames in 5.0 seconds = 4711.383 FPS
50052 frames in 5.0 seconds = 10010.372 FPS
50134 frames in 5.0 seconds = 10026.666 FPS
50009 frames in 5.0 seconds = 10001.670 FPS
49940 frames in 5.0 seconds = 9987.984 FPS
50203 frames in 5.0 seconds = 10038.895 FPS
deb [url]http://download.tuxfamily.org/shames/debian-sid/desktopfx/unstable/[/url] ./Kod: Zaznacz cały
fusion-icon
* Detected Session: gnome
* Searching for installed applications...
* NVIDIA on Xorg detected, exporting: __GL_YIELD=NOTHING
* Using the GTK Interface
* Metacity is already running
* Setting window manager to Compiz
... executing: compiz.real --replace --sm-disable --ignore-desktop-hints ccp
compiz.real (core) - Warn: pixmap 0x10000e2 can't be bound to texture # to pokazalo
compiz.real (core) - Warn: pixmap 0x10000e2 can't be bound to texture # sie tylko raz
Nalezy tez dodac ze owe 75fps ktore sa przez czaly czas nie daja plynnosci obrazu... troche sie szarpie wszystko, czasem sie zatnie na np sekunde.
Z tego co wiem to podczas przeladowania x'ow powinno byc logo nvidii ale jedyne co mi mruga to jakis pokrzaczony ekran (podejrzewam ze tam powinien byc ten obrazek). No i ostatnie to wynik glxgears w 2d (ok 10k fps) wydaje m i sie troche dziwny... na radeonie x800gto2 wynik mialem wyzszy (nie pamietam czy bylo to 12k czy 20k) w kazdym razie owy radeon jest generalnie leciutko gorsza karta niz ten 7600GT ktorego mam, cos jest chyba nie tak... mysle ze swiadczy tez o tym fakt iz przegladanie nietorych stron jest delikatnie mowiac koszmarne (ale to tylko kilka takich znalazlem). Gdy wlacze compiza strony chodza gladko (w miare bo idealnie nie jest). Jedna z takich stron jest np ta:
http://shame.tuxfamily.org/repo/?cat=11
jeszcze pakiety jakie mam zainstalowane:
$ aptitude search compiz emerald mesa-dri
i A compiz
i A compiz-core
p compiz-dev
v compiz-extra
v compiz-extra-plugins
p compiz-fusion-all
i A compiz-fusion-bcop
p compiz-fusion-extras
i compiz-fusion-gnome
p compiz-fusion-kde
i A compiz-fusion-plugins-extra
i A compiz-fusion-plugins-main
p compiz-fusion-plugins-unstable
i A compiz-fusion-plugins-unsupport
i A compiz-gnome
p compiz-gtk
p compiz-kde
i A compiz-manager
i A compiz-plugins
i A compizconfig-backend-gconf
p compizconfig-backend-kconfig
i A compizconfig-settings-manager
i A emerald
i A emerald-themes
p libcompizconfig-dev
i A libcompizconfig0
p libemeraldengine-dev
i A libemeraldengine0
i libgl1-mesa-dri
p libgl1-mesa-dri-dbg
v libgl1-mesa-dri-dev
i A python-compizconfig
