Mam taką grafikę.00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Exp ress Graphics Controller (rev 03)
I po rekonfiguracji Xów takiego loga i zwiechę (z góry przepraszam za dużego loga)
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux dhcppc1888 2.6.18-5-686 #1 SMP Mon Dec 24 16:41:07 UTC 2007 i686
Build Date: 24 January 2008
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb 22 13:51:43 2008
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Synaptics Touchpad"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 8086,2590 card 1025,006a rev 03 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 8086,2592 card 1025,006a rev 03 class 03,00,00 hdr 80
(II) PCI: 00:02:1: chip 8086,2792 card 1025,006a rev 03 class 03,80,00 hdr 80
(II) PCI: 00:1d:0: chip 8086,2658 card 1025,006a rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2659 card 1025,006a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,265a card 1025,006a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,265b card 1025,006a rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,265c card 1025,006a rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev d3 class 06,04,01 hdr 81
(II) PCI: 00:1e:2: chip 8086,266e card 1025,006a rev 03 class 04,01,00 hdr 00
(II) PCI: 00:1e:3: chip 8086,266d card 1025,006a rev 03 class 07,03,00 hdr 00
(II) PCI: 00:1f:0: chip 8086,2641 card 1025,006a rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,266f card 1025,006a rev 03 class 01,01,8a hdr 00
(II) PCI: 00:1f:3: chip 8086,266a card 1025,006a rev 03 class 0c,05,00 hdr 00
(II) PCI: 06:07:0: chip 10ec,8139 card 1025,006a rev 10 class 02,00,00 hdr 00
(II) PCI: 06:09:0: chip 1524,1410 card 3400,0000 rev 01 class 06,07,00 hdr 02
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,7), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 6: bridge is at (0:30:0), (0,6,10), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 6 I/O range:
[0] -1 0 0x00003000 - 0x000030ff (0x100) IX
[1] -1 0 0x00003400 - 0x000034ff (0x100) IX
[2] -1 0 0x00003800 - 0x000038ff (0x100) IX
[3] -1 0 0x00003c00 - 0x00003cff (0x100) IX
(II) Bus 6 non-prefetchable memory range:
[0] -1 0 0xb0100000 - 0xb01fffff (0x100000) MX
(II) Bus 6 prefetchable memory range:
[0] -1 0 0x30000000 - 0x31ffffff (0x2000000) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-CardBus bridge:
(II) Bus 7: bridge is at (6:9:0), (6,7,10), BCTRL: 0x05c0 (VGA_EN is cleared)
(II) Bus 7 I/O range:
[0] -1 0 0x00003400 - 0x000034ff (0x100) IX
[1] -1 0 0x00003800 - 0x000038ff (0x100) IX[B]
(II) Bus 7 prefetchable memory range:
[0] -1 0 0x30000000 - 0x31ffffff (0x2000000) MX[B]
(--) PCI:*(0:2:0) Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller rev 3, Mem @ 0xb0080000/19, 0xc0000000/28, 0xb0000000/18, I/O @ 0x1800/3
(--) PCI: (0:2:1) Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller rev 3, Mem @ 0x32000000/19
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xb0100000 - 0xb01000ff (0x100) MX[B]
[1] -1 0 0xb0040400 - 0xb00404ff (0x100) MX[B]
[2] -1 0 0xb0040800 - 0xb00409ff (0x200) MX[B]
[3] -1 0 0xb0040000 - 0xb00403ff (0x400) MX[B]
[4] -1 0 0xb0000000 - 0xb003ffff (0x40000) MX[B](B)
[5] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[6] -1 0 0xb0080000 - 0xb00fffff (0x80000) MX[B](B)
[7] -1 0 0x00003000 - 0x000030ff (0x100) IX[B]
[8] -1 0 0x000020a0 - 0x000020bf (0x20) IX[B]
[9] -1 0 0x00001810 - 0x0000181f (0x10) IX[B]
[10] -1 0 0x00002000 - 0x0000207f (0x80) IX[B]
[11] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
[12] -1 0 0x000018c0 - 0x000018ff (0x40) IX[B]
[13] -1 0 0x00001c00 - 0x00001cff (0x100) IX[B]
[14] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[15] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[16] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[17] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[18] -1 0 0x00001800 - 0x00001807 (0x8) IX[B](B)
(II) Inactive PCI resource ranges:
[0] -1 0 0x32000000 - 0x3207ffff (0x80000) MX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xb0100000 - 0xb01000ff (0x100) MX[B]
[5] -1 0 0xb0040400 - 0xb00404ff (0x100) MX[B]
[6] -1 0 0xb0040800 - 0xb00409ff (0x200) MX[B]
[7] -1 0 0xb0040000 - 0xb00403ff (0x400) MX[B]
[8] -1 0 0xb0000000 - 0xb003ffff (0x40000) MX[B](B)
[9] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
[10] -1 0 0xb0080000 - 0xb00fffff (0x80000) MX[B](B)
[11] -1 0 0x32000000 - 0x3207ffff (0x80000) MX[B](B)
[12] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[13] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[14] -1 0 0x00003000 - 0x000030ff (0x100) IX[B]
[15] -1 0 0x000020a0 - 0x000020bf (0x20) IX[B]
[16] -1 0 0x00001810 - 0x0000181f (0x10) IX[B]
[17] -1 0 0x00002000 - 0x0000207f (0x80) IX[B]
[18] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
[19] -1 0 0x000018c0 - 0x000018ff (0x40) IX[B]
[20] -1 0 0x00001c00 - 0x00001cff (0x100) IX[B]
[21] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[22] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[23] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[24] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[25] -1 0 0x00001800 - 0x00001807 (0x8) IX[B](B)
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: "i810"
(II) Loading /usr/lib/xorg/modules/drivers/i810_drv.so
(II) Module i810: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.7.2
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
compiled for 7.1.1, module version = 1.1.1
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.0
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) I810: Driver for Intel Integrated Graphics Chipsets: i810, i810-dc100,
i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G, E7221 (i915),
915GM, 945G, 945GM, 965G, 965G, 965Q, 946GZ
(II) Primary Device is: PCI 00:02:0
(WW) I810: No matching Device section for instance (BusID PCI:0:2:1) found
(--) Chipset 915GM found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[12] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[13] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[14] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x00003000 - 0x000030ff (0x100) IX[B]
[18] -1 0 0x000020a0 - 0x000020bf (0x20) IX[B]
[19] -1 0 0x00001810 - 0x0000181f (0x10) IX[B]
[20] -1 0 0x00002000 - 0x0000207f (0x80) IX[B]
[21] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
[22] -1 0 0x000018c0 - 0x000018ff (0x40) IX[B]
[23] -1 0 0x00001c00 - 0x00001cff (0x100) IX[B]
[24] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[25] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[26] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[27] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[28] -1 0 0x00001800 - 0x00001807 (0x8) IX[B](B)
[29] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[30] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) Loading sub module "vbe"
(II) Reloading /usr/lib/xorg/modules/libvbe.so
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(**) I810(0): Depth 24, (--) framebuffer bpp 32
(==) I810(0): RGB weight 888
(==) I810(0): Default visual is TrueColor
(II) I810(0): initializing int10
(II) Loading sub module "vm86"
(II) LoadModule: "vm86"
(II) Loading /usr/lib/xorg/modules/libvm86.so
(II) Module vm86: vendor="X.Org Foundation"
(WW) I810(0): Bad V_BIOS checksum
(II) I810(0): Primary V_BIOS segment is: 0xc000
(II) I810(0): VESA BIOS detected
(II) I810(0): VESA VBE Version 3.0
(II) I810(0): VESA VBE Total Mem: 7872 kB
(II) I810(0): VESA VBE OEM: Intel(r)915GM/910ML/915MS Graphics Chip Accelerated VGA BIOS
(II) I810(0): VESA VBE OEM Software Rev: 1.0
(II) I810(0): VESA VBE OEM Vendor: Intel Corporation
(II) I810(0): VESA VBE OEM Product: Intel(r)915GM/910ML/915MS Graphics Controller
(II) I810(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(II) I810(0): Integrated Graphics Chipset: Intel(R) 915GM
(--) I810(0): Chipset: "915GM"
(--) I810(0): Linear framebuffer at 0xC0000000
(--) I810(0): IO registers at addr 0xB0080000
(II) I810(0): 2 display pipes available.
(II) I810(0): detected 7932 kB stolen memory.
(II) I810(0): Kernel reported 110080 total, 1 used
(II) I810(0): I830CheckAvailableMemory: 440316 kB available
(II) I810(0): Monitoring connected displays enabled
(WW) I810(0): VideoRAM reduced to 0 kByte (page aligned - was 64)
(--) I810(0): Pre-allocated VideoRAM: 7932 kByte
(**) I810(0): VideoRAM: 0 kByte
(==) I810(0): video overlay key set to 0x101fe
(**) I810(0): page flipping disabled
(==) I810(0): Using gamma correction (1.0, 1.0, 1.0)
(II) I810(0): BIOS Build: 1227
(==) I810(0): Device Presence: disabled.
(==) I810(0): Display Info: enabled.
(II) I810(0): Broken BIOSes cause the system to hang here.
If you encounter this problem please add
Option "DisplayInfo" "FALSE"
to the Device section of your XF86Config file.
(II) I810(0): Display Info: CRT: attached: FALSE, present: TRUE, size: (720,400)
(II) I810(0): Display Info: TV: attached: FALSE, present: TRUE, size: (1024,768)
(II) I810(0): Display Info: DFP (digital flat panel): attached: FALSE, present: FALSE, size: (0,2059)
(II) I810(0): Display Info: LFP (local flat panel): attached: TRUE, present: TRUE, size: (1024,768)
(II) I810(0): Display Info: Second (second CRT): attached: FALSE, present: FALSE, size: (0,2059)
(II) I810(0): Display Info: TV2 (second TV): attached: FALSE, present: FALSE, size: (0,2059)
(II) I810(0): Display Info: DFP2 (second digital flat panel): attached: FALSE, present: FALSE, size: (0,2059)
(II) I810(0): Display Info: LFP2 (second local flat panel): attached: FALSE, present: FALSE, size: (0,2059)
(II) I810(0): Size of device LFP (local flat panel) is 1024 x 768
(II) I810(0): No active displays on Pipe A.
(II) I810(0): Currently active displays on Pipe B:
(II) I810(0): LFP (local flat panel)
(II) I810(0): Lowest common panel size for pipe B is 1024 x 768
(==) I810(0): Display is using Pipe B
(--) I810(0): Maximum frambuffer space: -168 kByte
(II) I810(0): VESA VBE PanelID read successfully
(II) I810(0): PanelID returned panel resolution : 1024x768
(II) Loading sub module "ddc"
(II) Reloading /usr/lib/xorg/modules/libddc.so
(II) I810(0): VESA VBE DDC supported
(II) I810(0): VESA VBE DDC Level 2
(II) I810(0): VESA VBE DDC transfer in appr. 1 sec.
(II) I810(0): VESA VBE DDC read successfully
(II) I810(0): Manufacturer: CMO Model: 1506 Serial#: 0
(II) I810(0): Year: 2002 Week: 40
(II) I810(0): EDID Version: 1.3
(II) I810(0): Digital Display Input
(II) I810(0): Max H-Image Size [cm]: horiz.: 30 vert.: 23
(II) I810(0): Gamma: 2.20
(II) I810(0): No DPMS capabilities specified; RGB/Color Display
(II) I810(0): First detailed timing is preferred mode
(II) I810(0): redX: 0.626 redY: 0.354 greenX: 0.294 greenY: 0.589
(II) I810(0): blueX: 0.144 blueY: 0.097 whiteX: 0.309 whiteY: 0.329
(II) I810(0): Supported VESA Video Modes:
(II) I810(0): 1024x768@60Hz
(II) I810(0): Manufacturer's mask: 0
(II) I810(0): Supported additional Video Mode:
(II) I810(0): clock: 65.0 MHz Image Size: 304 x 228 mm
(II) I810(0): h_active: 1024 h_sync: 1048 h_sync_end 1184 h_blank_end 1344 h_border: 0
(II) I810(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 806 v_border: 0
(II) I810(0): N150X3-L07
(II) I810(0): CMO
(--) I810(0): A non-CRT device is attached to pipe B.
No refresh rate overrides will be attempted.
(--) I810(0): Maximum space available for video modes: -168 kByte
Mode: 30 (640x480)
ModeAttributes: 0x9b
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
WinFuncPtr: 0xc000727f
BytesPerScanline: 640
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 23
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
GreenFieldPosition: 0
BlueMaskSize: 0
BlueFieldPosition: 0
RsvdMaskSize: 0
RsvdFieldPosition: 0
DirectColorModeInfo: 0
PhysBasePtr: 0xc0000000
LinBytesPerScanLine: 640
BnkNumberOfImagePages: 23
LinNumberOfImagePages: 23
LinRedMaskSize: 0
LinRedFieldPosition: 0
LinGreenMaskSize: 0
LinGreenFieldPosition: 0
LinBlueMaskSize: 0
LinBlueFieldPosition: 0
LinRsvdMaskSize: 0
LinRsvdFieldPosition: 0
MaxPixelClock: 230000000
Mode: 32 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 832
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 14
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
LinBytesPerScanLine: 832
BnkNumberOfImagePages: 14
LinNumberOfImagePages: 14
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
Mode: 34 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 1024
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 9
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
LinBytesPerScanLine: 1024
BnkNumberOfImagePages: 9
LinNumberOfImagePages: 9
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
Mode: 38 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinBytesPerScanLine: 0
BnkNumberOfImagePages: 0
LinNumberOfImagePages: 0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 3a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 3c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 41 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 1280
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 12
RedMaskSize: 5
RedFieldPosition: 11
GreenMaskSize: 6
GreenFieldPosition: 5
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 1280
BnkNumberOfImagePages: 12
LinNumberOfImagePages: 12
LinRedMaskSize: 5
LinRedFieldPosition: 11
LinGreenMaskSize: 6
LinGreenFieldPosition: 5
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
Mode: 43 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 1600
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 7
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 1600
BnkNumberOfImagePages: 7
LinNumberOfImagePages: 7
LinRedMaskSize: 5
LinGreenMaskSize: 6
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
Mode: 45 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 2048
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 4
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 2048
BnkNumberOfImagePages: 4
LinNumberOfImagePages: 4
LinRedMaskSize: 5
LinGreenMaskSize: 6
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
Mode: 49 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 4b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 4d (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
*Mode: 50 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 2560
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 5
RedMaskSize: 8
RedFieldPosition: 16
GreenMaskSize: 8
GreenFieldPosition: 8
BlueMaskSize: 8
RsvdMaskSize: 8
RsvdFieldPosition: 24
LinBytesPerScanLine: 2560
BnkNumberOfImagePages: 5
LinNumberOfImagePages: 5
LinRedMaskSize: 8
LinRedFieldPosition: 16
LinGreenMaskSize: 8
LinGreenFieldPosition: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
LinRsvdFieldPosition: 24
*Mode: 52 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 3200
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 3
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 8
LinBytesPerScanLine: 3200
BnkNumberOfImagePages: 3
LinNumberOfImagePages: 3
LinRedMaskSize: 8
LinGreenMaskSize: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
*Mode: 54 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 4096
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 1
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 8
LinBytesPerScanLine: 4096
LinRedMaskSize: 8
LinGreenMaskSize: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
Mode: 58 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 5a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 5c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 60 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 61 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 62 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 63 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 64 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 65 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 66 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 67 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 68 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 69 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 6a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 6b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 6c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 6d (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 6e (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 6f (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 70 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 71 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
(WW) I810(0): config file hsync range 28-50kHz not within DDC hsync ranges.
(WW) I810(0): config file vrefresh range 43-75Hz not within DDC vrefresh ranges.
(II) I810(0): Generic Monitor: Using hsync range of 28.00-50.00 kHz
(II) I810(0): Generic Monitor: Using vrefresh range of 43.00-75.00 Hz
(II) I810(0): Not using built-in mode "1024x768" (insufficient memory given virtual size)
(II) I810(0): Not using built-in mode "800x600" (insufficient memory given virtual size)
(II) I810(0): Not using built-in mode "640x480" (insufficient memory given virtual size)
(EE) I810(0): No valid modes.
(II) UnloadModule: "i810"
(II) UnloadModule: "ddc"
(II) UnloadModule: "vm86"
(II) Unloading /usr/lib/xorg/modules/libvm86.so
(II) UnloadModule: "int10"
(II) UnloadModule: "vgahw"
(II) Unloading /usr/lib/xorg/modules/libvgahw.so
(II) UnloadModule: "vbe"
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Wydaje mi się, że to problem z grafiką zintegrowaną i chipsetem.
