Mam problem podczas skanowania i uruchamiania programu xawtv, uruchamiam program i komp mi się zawiesza. Karta jest rozpoznawana tylko nie wiem czy dobrą wpisałem w pliku /etc/modprobe.d/aliases, mam coś takiego:
alias char-major-81 videodev
alias char-major-81-0 saa7134
alias char-major-81-64 saa7134
options saa7134 card=12
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.18-5-686)
looking for available devices
port 73-73
type : Xvideo, image scaler
name : ATI Radeon Video Overlay
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
flags: overlay capture tuner
saa7134[0]: found at 0000:03:00.0, rev: 1, irq: 177, latency: 0, mmio: 0x66000000
saa7134[0]: subsystem: 1461:b7e9, board: Medion 7134 [card=12,insmod option]
saa7134[0]: board init: gpio is 0
saa7134[0]: i2c eeprom 00: 61 14 e9 b7 ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 20: ff d1 fb ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0] unexpected config structure
saa7134[0] Tuner type is 63
tuner 1-0060: chip found @ 0xc0 (saa7134[0])
saa7134[0]: registered device video0 [v4l2]
saa7134[0]: registered device vbi0
saa7134[0]: registered device radio0
[ Dodano: 2008-02-25, 00:03 ]
Czy ktoś mógłby polecić jakiś inny jeszcze program do tego tunera TV?
