Przygotowalem sobie swieze jadro 2.6.24 w nastepujacy sposob:
make-kpkg --config menuconfig
make-kpkg clean
make-kpkg --revision kernel2.6.24 kernel_image
kernel-image-2.6.24_kernel2.6.24_i386.deb
debian:/usr/src# dpkg -i kernel-image-2.6.24_kernel2.6.24_i386.deb
(Reading database ... 29952 files and directories currently installed.)
Preparing to replace kernel-image-2.6.24 2.6.24 (using kernel-image-2.6.24_kernel2.6.24_i386.deb) ...
You are attempting to install a kernel image (version 2.6.24)
However, the directory /lib/modules/2.6.24 still exists. If this
directory belongs to a previous kernel-image-2.6.24 package, and if
you have deselected some modules, or installed standalone modules
packages, this could be bad. However, if this directory exists because
you are also installing some stand alone modules right now, and they
got unpacked before I did, then this is pretty benign. Unfortunately,
I can not tell the difference.
If /lib/modules/2.6.24 belongs to a old install of
kernel-image-2.6.24, then this is your last chance to abort the
installation of this kernel image (nothing has been changed yet).
If this directory is because of stand alone modules being installed
right now, or if it does belong to an older kernel-image-2.6.24
package but you know what you are doing, and if you feel that this
image should be installed despite this anomaly, Please answer n to the
question.
Otherwise, I suggest you move /lib/modules/2.6.24 out of the way,
perhaps to /lib/modules/2.6.24.old or something, and then try
re-installing this image.
Do you want to stop now? [Y/n]
Ok, Aborting
dpkg: error processing kernel-image-2.6.24_kernel2.6.24_i386.deb (--install):
subprocess pre-installation script returned error exit status 1
Searching for GRUB installation directory ... found: /boot/grub .
Testing for an existing GRUB menu.list file... found: /boot/grub/menu.lst .
Searching for splash image... none found, skipping...
Found kernel: /boot/vmlinuz-2.6.24
Found kernel: /boot/vmlinuz-2.6.8-2-386
Found kernel: /boot/vmlinuz-2.4.27-2-386
Updating /boot/grub/menu.lst ... done
Errors were encountered while processing:
Z gory dzieki
