Problemy z xserverem
laserpl
Post autor: laserpl »
Witam,mam problem z konfiguracja xservera mam laptopa compal fl90: grafika GeForce 8600GT, monitor LG Philips LP154WX4-TLC1 (takie dane podal mi Everest) i nie moge skonfigurowac poprawnie xserver. Wychodzi mi taki bład na samym koncu((EE) No devices detected.):
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.6.18-5-amd64 #1 SMP Sat Dec 22 20:43:59 UTC 2007 x86_64
Build Date: 04 September 2007
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb  8 20:05:06 2008
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "Generic Monitor"
(**) |   |-->Device "nVidia Corporation NVIDIA Default Card"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Synaptics Touchpad"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
	Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(**) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 1.0
	X.Org XInput driver : 0.6
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
	compiled for 7.1.1, module version = 1.0.0
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
	ABI class: X.Org Video Driver, version 1.0
(--) using VT number 7
(II) PCI: 00:00:0: chip 8086,2a00 card 14c0,0025 rev 0c class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2a01 card 0000,0000 rev 0c class 06,04,00 hdr 01
(II) PCI: 00:1a:0: chip 8086,2834 card 14c0,0025 rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2835 card 14c0,0025 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,283a card 14c0,0025 rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,284b card 14c0,0025 rev 03 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,283f card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:1: chip 8086,2841 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:2: chip 8086,2843 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:3: chip 8086,2845 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:4: chip 8086,2847 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:5: chip 8086,2849 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2830 card 14c0,0025 rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2831 card 14c0,0025 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2832 card 14c0,0025 rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,2836 card 14c0,0025 rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev f3 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2815 card 0000,0000 rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,2850 card 14c0,0025 rev 03 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,2828 card 14c0,0025 rev 03 class 01,01,8f hdr 00
(II) PCI: 00:1f:3: chip 8086,283e card 14c0,0025 rev 03 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0407 card 14c0,0025 rev a1 class 03,00,00 hdr 00
(II) PCI: 04:00:0: chip 14e4,1693 card 14c0,0025 rev 02 class 02,00,00 hdr 00
(II) PCI: 0c:00:0: chip 8086,4229 card 8086,1101 rev 61 class 02,80,00 hdr 00
(II) PCI: 0e:06:0: chip 1180,0832 card 14c0,0025 rev 05 class 0c,00,10 hdr 80
(II) PCI: 0e:06:1: chip 1180,0822 card 14c0,0025 rev 22 class 08,05,00 hdr 80
(II) PCI: 0e:06:2: chip 1180,0843 card 14c0,0025 rev 12 class 08,80,00 hdr 80
(II) PCI: 0e:06:3: chip 1180,0592 card 14c0,0025 rev 12 class 08,80,00 hdr 80
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,14), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
	[0] -1	0	0x00000000 - 0xffffffff (0x100000000) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x001a (VGA_EN is set)
(II) Bus 1 I/O range:
	[0] -1	0	0x00002000 - 0x00002fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xc4000000 - 0xc6ffffff (0x3000000) MX[B]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:28:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
	[0] -1	0	0x00003000 - 0x000030ff (0x100) IX[B]
	[1] -1	0	0x00003400 - 0x000034ff (0x100) IX[B]
	[2] -1	0	0x00003800 - 0x000038ff (0x100) IX[B]
	[3] -1	0	0x00003c00 - 0x00003cff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
	[0] -1	0	0xbc000000 - 0xbfffffff (0x4000000) MX[B]
(II) Bus 2 prefetchable memory range:
	[0] -1	0	0xcc000000 - 0xcdffffff (0x2000000) MX[B]
(II) Bus 4: bridge is at (0:28:1), (0,4,4), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 4 I/O range:
	[0] -1	0	0x00004000 - 0x000040ff (0x100) IX[B]
	[1] -1	0	0x00004400 - 0x000044ff (0x100) IX[B]
	[2] -1	0	0x00004800 - 0x000048ff (0x100) IX[B]
	[3] -1	0	0x00004c00 - 0x00004cff (0x100) IX[B]
(II) Bus 4 non-prefetchable memory range:
	[0] -1	0	0xf0000000 - 0xf3ffffff (0x4000000) MX[B]
(II) Bus 4 prefetchable memory range:
	[0] -1	0	0xfa000000 - 0xfbffffff (0x2000000) MX[B]
(II) Bus 6: bridge is at (0:28:2), (0,6,6), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 6 I/O range:
	[0] -1	0	0x00005000 - 0x000050ff (0x100) IX[B]
	[1] -1	0	0x00005400 - 0x000054ff (0x100) IX[B]
	[2] -1	0	0x00005800 - 0x000058ff (0x100) IX[B]
	[3] -1	0	0x00005c00 - 0x00005cff (0x100) IX[B]
(II) Bus 6 non-prefetchable memory range:
	[0] -1	0	0xf4000000 - 0xf7ffffff (0x4000000) MX[B]
(II) Bus 6 prefetchable memory range:
	[0] -1	0	0xfc000000 - 0xfdffffff (0x2000000) MX[B]
(II) Bus 8: bridge is at (0:28:3), (0,8,8), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 8 I/O range:
	[0] -1	0	0x00006000 - 0x000060ff (0x100) IX[B]
	[1] -1	0	0x00006400 - 0x000064ff (0x100) IX[B]
	[2] -1	0	0x00006800 - 0x000068ff (0x100) IX[B]
	[3] -1	0	0x00006c00 - 0x00006cff (0x100) IX[B]
(II) Bus 8 non-prefetchable memory range:
	[0] -1	0	0xb4000000 - 0xb7ffffff (0x4000000) MX[B]
(II) Bus 8 prefetchable memory range:
	[0] -1	0	0xc8000000 - 0xc9ffffff (0x2000000) MX[B]
(II) Bus 10: bridge is at (0:28:4), (0,10,10), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 12: bridge is at (0:28:5), (0,12,12), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 12 non-prefetchable memory range:
	[0] -1	0	0xf8000000 - 0xf80fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 14: bridge is at (0:30:0), (0,14,14), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 14 non-prefetchable memory range:
	[0] -1	0	0xf8100000 - 0xf81fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0407) rev 161, Mem @ 0xc6000000/24, 0xd0000000/28, 0xc4000000/25, I/O @ 0x2000/7
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
	[0] -1	0	0xf8101000 - 0xf81010ff (0x100) MX[B]
	[1] -1	0	0xf8100c00 - 0xf8100cff (0x100) MX[B]
	[2] -1	0	0xf8100800 - 0xf81008ff (0x100) MX[B]
	[3] -1	0	0xf8100000 - 0xf81007ff (0x800) MX[B]
	[4] -1	0	0xf8000000 - 0xf8001fff (0x2000) MX[B]
	[5] -1	0	0xf0000000 - 0xf000ffff (0x10000) MX[B]
	[6] -1	0	0x88000000 - 0x880000ff (0x100) MX[B]
	[7] -1	0	0xf8404400 - 0xf84047ff (0x400) MX[B]
	[8] -1	0	0xf8400000 - 0xf8403fff (0x4000) MX[B]
	[9] -1	0	0xf8404000 - 0xf84043ff (0x400) MX[B]
	[10] -1	0	0xc4000000 - 0xc5ffffff (0x2000000) MX[B](B)
	[11] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
	[12] -1	0	0xc6000000 - 0xc6ffffff (0x1000000) MX[B](B)
	[13] -1	0	0x00001c00 - 0x00001c1f (0x20) IX[B]
	[14] -1	0	0x000018d0 - 0x000018df (0x10) IX[B]
	[15] -1	0	0x000018e0 - 0x000018ef (0x10) IX[B]
	[16] -1	0	0x000018c8 - 0x000018cb (0x4) IX[B]
	[17] -1	0	0x000018f0 - 0x000018f7 (0x8) IX[B]
	[18] -1	0	0x000018cc - 0x000018cf (0x4) IX[B]
	[19] -1	0	0x000018f8 - 0x000018ff (0x8) IX[B]
	[20] -1	0	0x000018a0 - 0x000018af (0x10) IX[B]
	[21] -1	0	0x00001880 - 0x0000189f (0x20) IX[B]
	[22] -1	0	0x00001860 - 0x0000187f (0x20) IX[B]
	[23] -1	0	0x00001840 - 0x0000185f (0x20) IX[B]
	[24] -1	0	0x00001820 - 0x0000183f (0x20) IX[B]
	[25] -1	0	0x00001800 - 0x0000181f (0x20) IX[B]
	[26] -1	0	0x00002000 - 0x0000207f (0x80) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1	0	0xf8101000 - 0xf81010ff (0x100) MX[B]
	[5] -1	0	0xf8100c00 - 0xf8100cff (0x100) MX[B]
	[6] -1	0	0xf8100800 - 0xf81008ff (0x100) MX[B]
	[7] -1	0	0xf8100000 - 0xf81007ff (0x800) MX[B]
	[8] -1	0	0xf8000000 - 0xf8001fff (0x2000) MX[B]
	[9] -1	0	0xf0000000 - 0xf000ffff (0x10000) MX[B]
	[10] -1	0	0x88000000 - 0x880000ff (0x100) MX[B]
	[11] -1	0	0xf8404400 - 0xf84047ff (0x400) MX[B]
	[12] -1	0	0xf8400000 - 0xf8403fff (0x4000) MX[B]
	[13] -1	0	0xf8404000 - 0xf84043ff (0x400) MX[B]
	[14] -1	0	0xc4000000 - 0xc5ffffff (0x2000000) MX[B](B)
	[15] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
	[16] -1	0	0xc6000000 - 0xc6ffffff (0x1000000) MX[B](B)
	[17] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[18] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[19] -1	0	0x00001c00 - 0x00001c1f (0x20) IX[B]
	[20] -1	0	0x000018d0 - 0x000018df (0x10) IX[B]
	[21] -1	0	0x000018e0 - 0x000018ef (0x10) IX[B]
	[22] -1	0	0x000018c8 - 0x000018cb (0x4) IX[B]
	[23] -1	0	0x000018f0 - 0x000018f7 (0x8) IX[B]
	[24] -1	0	0x000018cc - 0x000018cf (0x4) IX[B]
	[25] -1	0	0x000018f8 - 0x000018ff (0x8) IX[B]
	[26] -1	0	0x000018a0 - 0x000018af (0x10) IX[B]
	[27] -1	0	0x00001880 - 0x0000189f (0x20) IX[B]
	[28] -1	0	0x00001860 - 0x0000187f (0x20) IX[B]
	[29] -1	0	0x00001840 - 0x0000185f (0x20) IX[B]
	[30] -1	0	0x00001820 - 0x0000183f (0x20) IX[B]
	[31] -1	0	0x00001800 - 0x0000181f (0x20) IX[B]
	[32] -1	0	0x00002000 - 0x0000207f (0x80) IX[B](B)
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
	compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
	compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules/drivers/nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
	compiled for 7.1.1, module version = 1.2.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
	ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
	compiled for 7.1.1, module version = 1.1.1
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="The XFree86 Project"
	compiled for 4.2.0, module version = 1.0.0
	Module class: XFree86 XInput Driver
	ABI class: XFree86 XInput driver, version 0.3
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
	Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
	Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
	GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
	GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
	Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
	GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
	GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
	GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
	GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
	GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
	GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
	Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
	GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
	GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
	GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
	Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
	GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
	Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
	GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
	GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
	GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
	GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
	GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
	GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
	Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
	GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
	GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
	GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
	GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
	GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
	Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
	GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
	GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
	GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
	GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
	Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
	GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
	GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
	GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
	Quadro FX 540, GeForce 6200, GeForce 6500,
	GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
	GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
	GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
	GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
	GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
	GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
	GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
	GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
	GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
	GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
	GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
	GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
	Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
	GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
	GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
	Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
	Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
	GeForce Go 6150, GeForce Go 6100
(II) Primary Device is: PCI 01:00:0
Fatal server error:
no screens found
Atak wyglada moj xorg.conf
# package.
Section "Files"
	FontPath	"/usr/share/fonts/X11/misc"
	FontPath	"/usr/X11R6/lib/X11/fonts/misc"
	FontPath	"/usr/share/fonts/X11/cyrillic"
	FontPath	"/usr/X11R6/lib/X11/fonts/cyrillic"
	FontPath	"/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/Type1"
	FontPath	"/usr/X11R6/lib/X11/fonts/Type1"
	FontPath	"/usr/share/fonts/X11/100dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi"
	FontPath	"/usr/share/fonts/X11/75dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi"
	# path to defoma fonts
	FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load	"bitmap"
	Load	"ddc"
	Load	"dri"
	Load	"extmod"
	Load	"freetype"
	Load	"glx"
	Load	"int10"
	Load	"vbe"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"pl"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"		"/dev/input/mice"
	Option		"Protocol"		"ImPS/2"
	Option		"Emulate3Buttons"	"true"
EndSection
	Identifier	"Synaptics Touchpad"
	Driver		"synaptics"
	Option		"SendCoreEvents"	"true"
	Option		"Device"		"/dev/psaux"
	Option		"Protocol"		"auto-dev"
	Option		"HorizScrollDelta"	"0"
EndSection
Section "Device"
	Identifier	"nVidia Corporation NVIDIA Default Card"
	Driver		"nv"
	BusID		"PCI:1:0:0"
EndSection
Section "Monitor"
	Identifier	"Generic Monitor"
	Option		"DPMS"
	HorizSync	28-49
	VertRefresh	43-72
EndSection
Section "Screen"
	Identifier	"Default Screen"
	DefaultDepth	24
	SubSection "Display"
		Depth		1
		Modes		"1024x768" "800x600" "640x480"
	EndSubSection
		Depth		4
	EndSubSection
		Depth		8
	EndSubSection
		Depth		15
	EndSubSection
		Depth		16
	EndSubSection
		Depth		24
	EndSubSection
EndSection
Section "ServerLayout"
	Identifier	"Default Layout"
	InputDevice	"Generic Keyboard"
	InputDevice	"Configured Mouse"
	InputDevice	"Synaptics Touchpad"
EndSection
Section "DRI"
	Mode	0666
EndSection
Prosze o pomoc
wstaw zamiast nv -> vesa i sprbuj odpalic X
po czym dpkg-reconfigure xserver-xorg
proponowal bym sprobowac zainstalowac sterowniki nvidii
laserpl
uzylem tego vesa, to sie wlancza poprzez startx ale caly ekran jest czarny i tak trwa caly czas, a instalowanie sterownikow to tez probowalem ale to strasznie skomplikowane jest bo trzeba gcc zainstalowac. Sciaglem pare wersji tego gcc ale nic nie pomoglo po wpisaniu./configure wyskakuja bledy za w $PATH nie moze znalesc cc
wydaje mi sie że błąd jest tutaj w parametrach obrazu
laserpl pisze:Section "Monitor"
Option "DPMS"
HorizSync 28-49
VertRefresh 43-72
EndSection
jeśli masz dane monitora to je wpisz tutaj te odpowiednie
jeśli nie to spróbuj
X -configure
lub
Xorg -config
to utworzy w katalogu /root plik xorg.conf.new , którego musisz skopiowac do /etc/X11
zmienić nazwa na xorg.conf, przeedytować (wstawić modes i defaultdepth) do sekcji screen parametry takie jak w powyższym pliku, który wkleiłeś i spróbowac odpalić X wtedy
Bodzio
Post autor: Bodzio »
a x-window-system zainstalowałeś ?
winnetou
Post autor: winnetou »
Dziękuję.... Bye bye
yantar
Post autor: yantar »
BusID        "PCI:0:2:0"
Prawdopodobnie zly adres.
winnetou
limak41
Post autor: limak41 »
Ja również mam ten sam problem. Nie wiem jak u was ale u mnie wszystko dziala jak wybiore w grubie starszą wersje kernela dokladnie Debian GNU/Linux, kernel 2.6.18-6-686. Czyżby wina tkwiła w kernelu 2.6.22-3-686 ? Jak to wygląda u was ?
mlyczek
Post autor: mlyczek »
limak41 pisze:Ja również mam ten sam problem. Nie wiem jak u was ale u mnie wszystko dziala jak wybiore w grubie starszą wersje kernela dokladnie Debian GNU/Linux, kernel 2.6.18-6-686. Czyżby wina tkwiła w kernelu 2.6.22-3-686 ? Jak to wygląda u was ?
Masz kartę nvidia? Jeśli tak, to nic dziwneg, że po zainstalowaniu nowego kernela x'y Ci nie działaja. ¯eby działały musisz przeinstalować sterowniki do karty graficznej.
