Uruchomienie serwera ssh
Informatyk
Post autor: Informatyk »
Już od dłuższego czasu męczę się z uruchomineniem na swoim komputerze z Debianem 4.0 serwera ssh. Mój sshd_config wygląda tak:
# Package generated configuration file
# See the sshd(8) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
#KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin yes
#StrictModes yes
# AllowUsers maciej
RSAAuthentication yes
PubkeyAuthentication yes
AuthorizedKeysFile	%h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
GSSAPIAuthentication yes
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
UsePAM yes
Serwer zdaje się być uruchomiony, na co wskazuje:
darkstar:~# /etc/init.d/ssh start
Starting OpenBSD Secure Shell server: ssh
oraz udane połączenie poprzez
ssh localhost
Gdy próbuję łączyć się z moim shellem ze zdalnego komputera, nie udaje się to jednak (tzn. wpisuję password, ale nie uznaje go i pojawia się nastepne takie pole..). Nie posiadam IP zewnętrznego, jestem jednak w sieci osiedlowej, a serwer WWW (na Apache) działa poprawnie. nazwa_hosta.adres_strony_sieci_osiedlowej.pl ; )
W czym jest więc problem? Proszę o pomoc w tej sprawie.
E:
Warto jeszcze dodać że wydanie polecenia sshd skutkuje komunikatem:
sshd re-exec requires execution with an absolute path
. Nie mogę więc korzystać z opcji tego polecenia..
Rad
Post autor: Rad »
£ączysz się spoza sieci osiedlowej na swoje ip zewnętrzne (czyli de facto ip rutera w tej sieci)? Jeżeli tak, to masz tam przekierowane porty, tak żeby przekazywało połączenia na port 22 do twojego komputera?
Informatyk
Tak, łączę się spoza sieci osiedlowej, i próbuję robić to wpisując ssh nazwa_użytkownika@nazwa_komputera.domena.pl. Oczywiście przez protokół http, pod adresem nazwa_komputera.domena.pl. znajduje się mój serwer www. Co do przekierowania portów - szczegółow nie znam, mógłbyś mi je przybliżyć? Zmienić np. port w sshd_config?
sprawdz IP serwera na którym masz serwer ssh i pisuj tak
ssh login@IP_serwera
tak jest zawsze bezpieczniej :P
a przekierowanie portów musisz zrobic na routerze
blain19
Post autor: blain19 »
Spróbuj połączyć się na swoje ssh od kogoś z sieci osiedlowej, wtedy dowiemy się czy to wina braku przekierowania, czy błędu w konfiguracji twojego komputera. Bo jeśli napisałeś, że wyskakuje Ci monit o podanie hasła, to raczej się łączysz ze swoim kompem i to nie wina braku przekierowania.
Rad
Post autor: Rad »
blain19 pisze:Bo jeśli napisałeś, że wyskakuje Ci monit o podanie hasła, to raczej się łączysz ze swoim kompem i to nie wina braku przekierowania.
Mi się wydaje, że on łączy się z ruterem, na którym odpalone jest sshd i dlatego nie może się zalogować.
Informatyk
Dostawca internetu oferuje konta pocztowe z dostępem do shella. Rozumiem więc że z udostępnienia usługi ssh nici? Do żadnego routera niestety dostępu nie mam. Jak się na dodatek okazuje, serwer Apache, chociaż u mnie na localhost działa bezproblemowo, z innych komputerów nie można się z nim połączyć (tak jak z ssh), również z maszyn z sieci osiedlowej.
Rad
Post autor: Rad »
Powiedz adminowi, żeby przekierował porty. Tylko pewnie będziesz musiał nasłuchiwać sshd na jakimś innym porcie niż defaultowy.
kayo
Post autor: kayo »
Jego serwer moze sobie chodzic na porcie 22 na ruterze trzeba zrobic przekierowanie np z portu 4567 na 22.
Wowczas tylko trzeba klientowi ssh trzeba podac parametr na jaki port ma sie laczyc.
Informatyk
Ok, dzięki za pomoc. Okazało się że jednym wyjściem jest dopłacenie kilku złotych do abonamentu za IP zewnętrzne, bądź... zmiana dostawcy Internetu.
