i2c - problem
kazzomy
i2c - problem
Post autor: kazzomy »
Witam, te cztery wpisy powinny starczyc bez zadnego komentarza:
z sensor-detect
Pasternaki:/home/pasternaki# sensors-detect
# sensors-detect revision 5016 (2007-11-11 22:20:16 +0100)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
We can start with probing for (PCI) I2C or SMBus adapters.
Do you want to probe now? (YES/no):
Probing for PCI bus adapters...
Use driver `i2c-i801' for device 0000:00:1f.3: Intel 82801FB ICH6
We will now try to load each adapter module in turn.
Module `i2c-i801' already loaded.
If you have undetectable or unsupported adapters, you can have them
scanned by manually loading the modules before running this script.
We are now going to do the I2C/SMBus adapter probings. Some chips may
be double detected; we choose the one with the highest confidence
value in that case.
If you found that the adapter hung after probing a certain address,
you can specify that address to remain unprobed.
Next adapter: SMBus I801 adapter at 1400 (i2c-0)
Do you want to scan it? (YES/no/selectively):
Client found at address 0x44
Probing for `Maxim MAX6633/MAX6634/MAX6635'...              No
Client found at address 0x50
Probing for `Analog Devices ADM1033'...                     No
Probing for `Analog Devices ADM1034'...                     No
Probing for `SPD EEPROM'...                                 Yes
    (confidence 8, not a hardware monitoring chip)
Probing for `EDID EEPROM'...                                No
Some chips are also accessible through the ISA I/O ports. We have to
write to arbitrary I/O ports to probe them. This is usually safe though.
Yes, you do have ISA I/O ports even if you do not have any ISA slots!
Do you want to scan the ISA I/O ports? (YES/no):
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM78-J' at 0x290...     No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Probing for `Silicon Integrated Systems SIS5595'...         No
Probing for `VIA VT82C686 Integrated Sensors'...            No
Probing for `VIA VT8231 Integrated Sensors'...              No
Probing for `IPMI BMC KCS' at 0xca0...                      No
Probing for `IPMI BMC SMIC' at 0xca8...                     No
Some Super I/O chips may also contain sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor'...                   No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Fintek'...                       No
Trying family `ITE'...                                      No
Probing for Super-I/O at 0x4e/0x4f
Some CPUs or memory controllers may also contain embedded sensors.
Do you want to scan for them? (YES/no):
AMD K8 thermal sensors...                                   No
AMD K10 thermal sensors...                                  No
Intel Core family thermal sensor...                         No
Intel AMB FB-DIMM thermal sensor...                         No
Sorry, no sensors were detected.
Either your sensors are not supported, or they are connected to an
I2C or SMBus adapter that is not supported. See doc/FAQ,
doc/lm_sensors-FAQ.html or [url]http://www.lm-sensors.org/wiki/FAQ[/url]
(FAQ #4.24.3) for further information.
If you find out what chips are on your board, check
[url]http://www.lm-sensors.org/wiki/Devices[/url] for driver status.
z sensors
No sensors found!
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to find out which these are.
z lsmod
Pasternaki:/home/pasternaki# lsmod
Module                  Size  Used by
i2c_dev                 7140  0
i915                   22432  2
drm                    76020  3 i915
rfcomm                 36280  0
l2cap                  22432  5 rfcomm
bluetooth              49348  4 rfcomm,l2cap
ipv6                  236996  12
button                  7920  0
ac                      5188  0
battery                 9988  0
cpufreq_userspace       4128  0
cpufreq_conservative     6888  0
cpufreq_ondemand        8300  0
cpufreq_stats           5120  0
freq_table              4512  2 cpufreq_ondemand,cpufreq_stats
cpufreq_powersave       1792  0
fuse                   41908  1
ndiswrapper           174364  0
loop                   16932  0
firewire_sbp2          12100  0
joydev                  9568  0
pcmcia                 37100  0
firmware_class          9504  1 pcmcia
iTCO_wdt                9924  0
rtc                    12856  0
i2c_i801                8656  0
yenta_socket           24844  1
rsrc_nonstatic         11968  1 yenta_socket
pcmcia_core            37108  3 pcmcia,yenta_socket,rsrc_nonstatic
serio_raw               6692  0
psmouse                36016  0
i2c_core               23552  2 i2c_dev,i2c_i801
snd_hda_intel         239160  0
snd_pcm                72324  1 snd_hda_intel
snd_timer              21028  1 snd_pcm
snd                    48324  3 snd_hda_intel,snd_pcm,snd_timer
soundcore               7520  1 snd
snd_page_alloc         10056  2 snd_hda_intel,snd_pcm
intel_agp              23188  1
agpgart                31912  3 drm,intel_agp
tsdev                   7968  0
evdev                   9312  5
ext3                  121288  3
jbd                    55336  1 ext3
mbcache                 8260  1 ext3
sg                     32668  0
sr_mod                 16516  1
cdrom                  32832  1 sr_mod
sd_mod                 27136  5
ata_generic             7556  0
ahci                   21380  0
usbhid                 25792  0
hid                    25248  1 usbhid
8139cp                 22144  0
ata_piix               13348  6
libata                115984  3 ata_generic,ahci,ata_piix
scsi_mod              136620  5 firewire_sbp2,sg,sr_mod,sd_mod,libata
ehci_hcd               30796  0
8139too                25536  0
mii                     5280  2 8139cp,8139too
firewire_ohci          16512  0
firewire_core          39008  2 firewire_sbp2,firewire_ohci
crc_itu_t               2144  1 firewire_core
generic                 4836  0 [permanent]
ide_core              113764  1 generic
uhci_hcd               22960  0
usbcore               125416  5 ndiswrapper,usbhid,ehci_hcd,uhci_hcd
thermal                13416  0
processor              31176  1 thermal
fan                     4836  0
z lspci
Pasternaki:/home/pasternaki# lspci
00:00.0 Host bridge: Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller (rev 04)
00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04)
00:02.1 Display controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04)
00:1b.0 Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 04)
00:1d.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 04)
00:1d.1 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 04)
00:1d.2 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 04)
00:1d.7 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 04)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev d4)
00:1f.0 ISA bridge: Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge (rev 04)
00:1f.2 IDE interface: Intel Corporation 82801FBM (ICH6M) SATA Controller (rev 04)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 04)
01:02.0 CardBus bridge: Texas Instruments PCIxx21/x515 Cardbus Controller
01:02.2 FireWire (IEEE 1394): Texas Instruments OHCI Compliant IEEE 1394 Host Controller
01:04.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
01:05.0 Network controller: RaLink RT2561/RT61 rev B 802.11g
jak zrobic zeby i2c działało??
Podpiąć telewizor, który ma wyjście i2c (każdy ma).
A tak poważnie, masz w kernelu tylko podstawowe moduły.
Zaistaluj:
apt-get install modconf
i sprawdź uruchamiając ten program jako root w konsoli/terminalu, jakie moduły należy jeszcze załadować --- jest ich naprawdę bardzo dużo, jeżeli chodzi o i2c (kernel/drivers/i2c). Niektóre mogą wymagać kompilacji kernela.
