vesa grafika --- laptop Amilo Pro 3515
zaba
Post autor: zaba »
Proszę o pomoc pierwszy problem to to:
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
Drugi to ze:
direct rendering: No
Na Windows jest wszystko dobrze a tu bledy prosze o pomoc.
Grafika Vesa, Laptop Amilo Pro 3515
Bodzio
Post autor: Bodzio »
Mało danych, wklej wynik:
lspci
zaba
Post autor: zaba »
00:00.0 Host bridge: VIA Technologies, Inc. P4M900 Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. P4M900 Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. P4M900 Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. P4M900 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. P4M900 Host Bridge
00:00.5 PIC: VIA Technologies, Inc. P4M900 I/O APIC Interrupt Controller
00:00.6 Host bridge: VIA Technologies, Inc. Unknown device 6364
00:00.7 Host bridge: VIA Technologies, Inc. P4M900 Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI Bridge
00:02.0 PCI bridge: VIA Technologies, Inc. P4M900 PCI to PCI Bridge Controller (rev 80)
00:03.0 PCI bridge: VIA Technologies, Inc. P4M900 PCI to PCI Bridge Controller (rev 80)
00:0f.0 IDE interface: VIA Technologies, Inc. VT8237A SATA 2-Port Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 07)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev a0)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237A PCI to ISA Bridge
00:11.7 Host bridge: VIA Technologies, Inc. VT8251 Ultra VLINK Controller
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 7c)
00:13.0 PCI bridge: VIA Technologies, Inc. VT8237A Host Bridge
00:13.1 PCI bridge: VIA Technologies, Inc. VT8237A PCI to PCI Bridge
01:00.0 VGA compatible controller: VIA Technologies, Inc. Unknown device 3371 (rev 01)
04:01.0 Audio device: VIA Technologies, Inc. VIA High Definition Audio Controller (rev 10)
05:01.0 Ethernet controller: Atheros Communications, Inc. AR5005G 802.11abg NIC (rev 01)
Bodzio
aptitude install xlibmesa-dri mesa-utils
potem
dpkg-reconfigure xserver-xfree86 -> zmień sterownik z vesa na nv
_Toshi_
Post autor: _Toshi_ »
Em w laptopie jest grfika Nvidii czy UnichromePro(zintegrowana)?
pavbaranov
Post autor: pavbaranov »
Na tym laptopie jest VIA Unichrome9 (P4M900). Na dzień dzisiejszy nie znalazłem innego pomysłu jak uruchomienie tej karty jako vesa (obsługiwana jest 1280x800x24(32). Prawdopodobnie też możliwym jest konfiguracja sterowników ze strony VIA Arena, bądź zastosowanie Unichrome. U mnie te ostatnie nie działają. Pierwsze - kurcze, opis ich instalacji jest tak pogmatwany, że chyba tylko autor wiedział, co miał na myśli, nadto praktycznie przygotowany pod Fedora Core, a nie pod inne dystrybucje, w efekcie, należałoby znać dobrze obie, by przez porównanie pozmieniać to, co jest na FC, na Debiana.
Przy okazji - XFree86 jest już chyba zarzucone w obecnych wersjach Debiana (4.0up) na rzecz XOrg. Stosuję te ostatnie i generalnie - jest w miarę. Podejrzewam, że lepiej, po prostu nie będzie.
To się może przydać >>klik<<
pavbaranov
fnmirk - nie wiem, czy się przydaje, choć... powinno. Mi w ten sposób nie udało się skompilować sterowników unichrome działających na 3515. Więcej, jest też tutaj: http://debian.linux.pl/viewtopic.php?t=1310
A przy okazji - zaba - jeśli dalej masz kłopoty, to jak będę na gg, zagadaj - napiszę Ci, jak uruchomić Debiana (Etch/Lenny/Sid) na tym komputerze.
_Toshi_
Nie przeczytałeśdokładnie. Na Etch sie udało i wszystko działało bardzo ładnie. Niestety na Lenny/Sid działa bardzo niestabilnie. Opisałem tam co sie dzieje :/
pavbaranov
_Toshi_ > Przeczytałem dokładnie. Nie wiem, jaki ma system zaba. Na Lennym - jak na razie - mam problem.
