Po zainstalowaniu synaptickiem postgresql 8.1, chwile dobrze pochodził, ale później namieszałem, przy updatowaniu tegoź postgresa, ale już ze źródeł.
Ciezko jest, bo nie mogę tego odkręcić, nie moge odinstalować wszystkiego, ani przeinstalować
np
root:~# apt-get -f install
Reading package lists... Done
Building dependency tree... Done
The following extra packages will be installed:
postgresql-8.1
The following packages will be upgraded:
postgresql-8.1
1 upgraded, 0 newly installed, 0 to remove and 28 not upgraded.
1 not fully installed or removed.
Need to get 4289kB of archives.
After unpacking 2177kB disk space will be freed.
Do you want to continue [Y/n]? y
Get:1 [url]http://security.debian.org[/url] etch/updates/main postgresql-8.1 8.1.11-0etch1 [4289kB]
Fetched 4289kB in 0s (5165kB/s)
(Reading database ... 84189 files and directories currently installed.)
Preparing to replace postgresql-8.1 8.1.9-0etch1 (using .../postgresql-8.1_8.1.11-0etch1_i386.deb) ...
Stopping PostgreSQL 8.1 database server: main* Error: The cluster is owned by user id 108 which does not exist any more
failed!
invoke-rc.d: initscript postgresql-8.1, action "stop" failed.
dpkg: warning - old pre-removal script returned error exit status 1
dpkg - trying script from the new package instead ...
failed!
dpkg: error processing /var/cache/apt/archives/postgresql-8.1_8.1.11-0etch1_i386.deb (--unpack):
subprocess new pre-removal script returned error exit status 1
Starting PostgreSQL 8.1 database server: main* Error: The cluster is owned by user id 108 which does not exist any more
failed!
invoke-rc.d: initscript postgresql-8.1, action "start" failed.
dpkg: error while cleaning up:
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
Starting PostgreSQL 8.1 database server: main* Error: The cluster is owned by user id 108 which does not exist any moreKod: Zaznacz cały
E: Sub-process /usr/bin/dpkg returned an error code (1)pozdrawiam
Tomek
