NET Registered protocol family 1
NET Registered protocol family 17
NET Registered protocol family 8
NET Registered protocol family 20
ACPI : (supports S0 S3 S4 S5)
Freeing used kernel memory 176 freed
input : AT Translated Set 2 kyboard as /class/input/input0
Ohci_hcd : 2005 Aprill 22 USB 1.1 : Open Host Controller (OHCI) Driver (PCI)
ACPI : PCI Interrupt Link [APCF] Enabled at IRQ 23
GSI 16 sharing vector 0xD9 and IRQ 16
ACPI : PCI Iterrupt 000:00:02.0 [AJ]->Link [APCF]->GSI 23(level ,low -> IRQ 217
PCI : Setting letency timer of device 00:00:02.0 to 64
ohci_hcd 0000:00:02.0 : OHCI Host Controller
ohci_hcd 0000:00:02.0 : new USBO bus registered assigned bus number 1
ohci_hcd 0000:00:02.0 : irq 217 io mem 0cfe02f000
SCSI subsystem initialized
libata version 2.00 loaded
ieee1394 Initialized config ram entery "ip1394"
Floppy driver(s) : fd0 is 1.44
pnp : the driver :p arport_pc has been registered
pnp match found with the PnP device "00:00" and the driver partport _pc
parport PnPBios parport_pc detected
parport : 0 PC-style at 0x378, irq7 [PCSPP,TRISTATE]
AMD Athlon 3600+ brishbone
DFI Infinity Ultra II-M 2
OCZ platinum 800Mhz
Palit geaforce 8600GT
Seagate barracuda 250 Gb sata2
prosze o pomoc z dziękuje
