niedawno pojawily sie sterowniki do mojej karty radeon xpress 300, zaisntalowalem fglx. Niby wszystko ok ale sa dwea paseczki w rogu, ok nimi sie nie przejmuje
glxgears:
2030 frames in 5.0 seconds = 405.995 FPS
2598 frames in 5.0 seconds = 519.529 FPS
2766 frames in 5.0 seconds = 553.091 FPS
2718 frames in 5.0 seconds = 543.497 FPS
2693 frames in 5.0 seconds = 538.435 FPS
2864 frames in 5.0 seconds = 572.331 FPS
2876 frames in 5.0 seconds = 574.870 FPS
2860 frames in 5.0 seconds = 571.963 FPS
2808 frames in 5.0 seconds = 561.537 FPS
2567 frames in 5.0 seconds = 513.219 FPSKod: Zaznacz cały
fglrxinfo
display: :0.0 screen: 0
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: ATI Radeon Xpress Series
OpenGL version string: 2.1.7170 Release
fgl_glxgears
Using GLX_SGIX_pbuffer
240 frames in 5.0 seconds = 48.000 FPS
225 frames in 5.0 seconds = 45.000 FPS
241 frames in 5.0 seconds = 48.200 FPS
glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
OpenGL extensions:
GL_AMD_performance_monitor, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects,
GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_shadow_ambient,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_float,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_ATI_draw_buffers, GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader,
GL_ATI_meminfo, GL_ATI_separate_stencil, GL_ATI_texture_env_combine3,
GL_ATI_texture_float, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object,
GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texgen_reflection, GL_EXT_texture3D,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_vertex_array,
GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_texgen_reflection,
GL_SGIS_generate_mipmap, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod,
GL_WIN_swap_hint, WGL_EXT_swap_control
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x2b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x2c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x2d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x2e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x2f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x30 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x31 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x32 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x33 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x34 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x35 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x36 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x37 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x38 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x39 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x3a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x3b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x3c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x3d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x3e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x3f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x40 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x41 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x42 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x43 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x44 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x45 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x46 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x47 24 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x48 24 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x49 24 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x4a 24 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x4b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x4c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x4d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x4e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x4f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x50 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x51 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x52 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x53 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x54 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x55 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x56 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x57 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x58 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x59 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x5a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x5b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x5c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x5d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x5e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x5f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x60 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x61 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x62 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x63 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x64 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x65 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x66 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x67 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x68 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x69 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x6a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x6b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x6c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x6d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x6e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None
0x6f 24 dc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x70 24 dc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x71 24 dc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x72 24 dc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x84 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
gra supertuxkart itp chodzi ok
ale gry takie jak kingpin oraz hitman i counter strike odpalane przez wine strasznie tna! nie da sie grac, a natomiast kiedy odpalam gry nie wykorzystujace opengl wszystko jest ok.
wyniki przez glxinfo sa tragiczne,ktos moze pomoc? ;/
