Mam karte PCMCIA do laptopa nie umiem jej skonfigurowac ani podlaczyc do zadnej sieci:/ Mam laptopa Toshiba Sattelite karta jest firmy Linksys. Debian Lenny.
wynik komendy dmesg:
mateusz@debian:~$ dmesg
Linux version 2.6.22-3-686 (Debian 2.6.22-6) (maks@debian.org) (gcc version 4.1.3 20071019 (prerelease) (Debian 4.1.2-17)) #1 SMP Mon Nov 12 08:32:57 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 00000000000eee00 (reserved)
BIOS-e820: 00000000000eee00 - 00000000000ef000 (ACPI NVS)
BIOS-e820: 00000000000ef000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001ef40000 (usable)
BIOS-e820: 000000001ef40000 - 000000001ef50000 (ACPI data)
BIOS-e820: 000000001ef50000 - 000000001f000000 (reserved)
BIOS-e820: 00000000fec10000 - 00000000fec20000 (reserved)
BIOS-e820: 00000000feda0000 - 00000000fedc0000 (reserved)
BIOS-e820: 00000000ffb80000 - 00000000ffc00000 (reserved)
BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
495MB LOWMEM available.
Entering add_active_range(0, 0, 126784) 0 entries of 256 used
Zone PFN ranges:
DMA 0 -> 4096
Normal 4096 -> 126784
HighMem 126784 -> 126784
early_node_map[1] active PFN ranges
0: 0 -> 126784
On node 0 totalpages: 126784
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 958 pages used for memmap
Normal zone: 121730 pages, LIFO batch:31
HighMem zone: 0 pages used for memmap
DMI 2.3 present.
ACPI: RSDP 000F0180, 0014 (r0 TOSHIB)
ACPI: RSDT 1EF40000, 0038 (r1 TOSHIB 750 970814 TASM 4010000)
ACPI: FACP 1EF40060, 0084 (r2 TOSHIB 750 20030101 TASM 4010000)
ACPI: DSDT 1EF40118, 44B9 (r1 TOSHIB A0015 20040426 MSFT 100000E)
ACPI: FACS 000EEE00, 0040
ACPI: SSDT 1EF445D1, 0231 (r1 TOSHIB LNK10SS 20040226 MSFT 100000E)
ACPI: DBGP 1EF400E4, 0034 (r1 TOSHIB 750 970814 TASM 4010000)
ACPI: BOOT 1EF40038, 0028 (r1 TOSHIB 750 970814 TASM 4010000)
ACPI: SSDT 1EF44802, 06C4 (r1 TOSHIB A0015 20040226 MSFT 100000E)
ACPI: PM-Timer IO Port: 0xd808
Allocating PCI resources starting at 20000000 (gap: 1f000000:dfc10000)
Built 1 zonelists. Total pages: 125794
Kernel command line: root=/dev/hda5 ro
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffd000 (013ec000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Detected 1496.292 MHz processor.
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 493456k/507136k available (1687k kernel code, 13064k reserved, 646k data, 244k init, 0k highmem)
virtual kernel memory layout:
fixmap : 0xfff4e000 - 0xfffff000 ( 708 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xdf800000 - 0xff7fe000 ( 511 MB)
lowmem : 0xc0000000 - 0xdef40000 ( 495 MB)
.init : 0xc034d000 - 0xc038a000 ( 244 kB)
.data : 0xc02a5f17 - 0xc03477e4 ( 646 kB)
.text : 0xc0100000 - 0xc02a5f17 (1687 kB)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 2994.53 BogoMIPS (lpj=5989071)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: a7e9f9bf 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 512K
CPU: After all inits, caps: a7e9f9bf 00000000 00000000 00002040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 11k freed
ACPI: Core revision 20070126
ACPI: setting ELCR to 0200 (from 0e00)
CPU0: Intel(R) Celeron(R) M processor 1500MHz stepping 05
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
Booting paravirtualized kernel on bare hardware
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfd480, last bus=3
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: (supports S0 S3 S4 S5)
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI quirk: region d800-d87f claimed by ICH4 ACPI/GPIO/TCO
PCI quirk: region eec0-eeff claimed by ICH4 GPIO
PCI: Firmware left 0000:01:08.0 e100 interrupts enabled, disabling
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs *10)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *11)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *11)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *11)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *11)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *11)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *11)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *11)
ACPI: Power Resource [PFAN] (off)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp: PnP ACPI: found 9 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Cannot allocate resource region 4 of device 0000:00:1d.0
PCI: Cannot allocate resource region 4 of device 0000:00:1d.1
PCI: Cannot allocate resource region 4 of device 0000:00:1d.2
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: RTC can wake from S4
pnp: 00:00: iomem range 0x0-0x9ffff could not be reserved
pnp: 00:00: iomem range 0xe0000-0xeffff could not be reserved
pnp: 00:00: iomem range 0xf0000-0xfffff could not be reserved
pnp: 00:00: iomem range 0x100000-0x1ef3ffff could not be reserved
Time: tsc clocksource has been installed.
PCI: Bus 2, cardbus bridge: 0000:01:0b.0
IO window: 0000c000-0000c0ff
IO window: 0000c400-0000c4ff
PREFETCH window: 28000000-2bffffff
MEM window: 30000000-33ffffff
PCI: Bridge: 0000:00:1e.0
IO window: c000-cfff
MEM window: cff00000-cfffffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
PCI: Enabling device 0000:01:0b.0 (0000 -> 0003)
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:01:0b.0[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 196608 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
checking if image is initramfs... it is
Switched to high resolution mode on CPU 0
Freeing initrd memory: 5718k freed
Simple Boot Flag at 0x7c set to 0x1
audit: initializing netlink socket (disabled)
audit(1198405797.632:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Boot video device is 0000:00:02.0
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
PCI: Enabling device 0000:00:1f.6 (0000 -> 0001)
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1f.6[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI interrupt for device 0000:00:1f.6 disabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
Using IPI No-Shortcut mode
Freeing unused kernel memory: 244k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Transitioning device [FAN] to D3
ACPI: Fan [FAN] (off)
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Thermal Zone [THRM] (24 C)
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
PCI: setting IRQ 10 as level-triggered
ACPI: PCI Interrupt 0000:00:1d.0[A] -> Link [LNKA] -> GSI 10 (level, low) -> IRQ 10
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 10, io base 0x000018c0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1d.1[B] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 11, io base 0x000018e0
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
SCSI subsystem initialized
libata version 2.21 loaded.
e100: Intel(R) PRO/100 Network Driver, 3.5.17-k4-NAPI
e100: Copyright(c) 1999-2006 Intel Corporation
ACPI: PCI Interrupt 0000:00:1d.2[C] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 11, io base 0x00001c00
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
PCI: Enabling device 0000:00:1d.7 (0000 -> 0002)
ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1d.7[D] -> Link [LNKH] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 11, io mem 0x2c080000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
usb 1-1: new low speed USB device using uhci_hcd and address 2
ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11
ACPI: PCI Interrupt 0000:01:08.0[A] -> Link [LNKE] -> GSI 11 (level, low) -> IRQ 11
e100: eth0: e100_probe: addr 0xcffff000, irq 11, MAC addr 00:0E:7B:2D:07:21
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH4: IDE controller at PCI slot 0000:00:1f.1
ACPI: PCI Interrupt 0000:00:1f.1[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
ICH4: chipset revision 3
ICH4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xbfa0-0xbfa7, BIOS settings: hda :D MA, hdb :p io
ide1: BM-DMA at 0xbfa8-0xbfaf, BIOS settings: hdc :D MA, hdd :p io
Probing IDE interface ide0...
Marking TSC unstable due to: possible TSC halt in C2.
Time: acpi_pm clocksource has been installed.
hda: IC25N040ATMR04-0, ATA DISK drive
usb 1-1: new low speed USB device using uhci_hcd and address 3
usb 1-1: configuration #1 chosen from 1 choice
usbcore: registered new interface driver hiddev
input: USB Optical Mouse as /class/input/input1
input: USB HID v1.10 Mouse [USB Optical Mouse] on usb-0000:00:1d.0-1
usbcore: registered new interface driver usbhid
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
hda: selected mode 0x45
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: TOSHIBA DVD-ROM SD-R2512, ATAPI CD/DVD-ROM drive
hdc: selected mode 0x42
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 512KiB
hda: 78140160 sectors (40007 MB) w/1740KiB Cache, CHS=16383/255/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 >
hdc: ATAPI 24X DVD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Attempting manual resume
swsusp: Basic memory bitmaps created
swsusp: Basic memory bitmaps freed
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Linux agpgart interface v0.102 (c) Dave Jones
agpgart: Detected an Intel 855GM Chipset.
agpgart: Detected 16252K stolen memory.
agpgart: AGP aperture is 128M @ 0xd8000000
intel_rng: FWH not detected
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker as /class/input/input2
iTCO_wdt: Intel TCO WatchDog Timer Driver v1.01 (21-Jan-2007)
Real Time Clock Driver v1.12ac
Yenta: CardBus bridge found at 0000:01:0b.0 [1179:0001]
Yenta: ISA IRQ mask 0x00b8, PCI irq 11
Socket status: 30000007
pcmcia: parent PCI bridge I/O window: 0xc000 - 0xcfff
cs: IO port probe 0xc000-0xcfff: clean.
pcmcia: parent PCI bridge Memory window: 0xcff00000 - 0xcfffffff
pcmcia: parent PCI bridge Memory window: 0x28000000 - 0x2bffffff
PCI: Setting latency timer of device 0000:00:1f.6 to 64
input: PS/2 Mouse as /class/input/input3
PCI: Enabling device 0000:00:1f.5 (0000 -> 0003)
ACPI: PCI Interrupt 0000:00:1f.5[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1f.5 to 64
input: AlpsPS/2 ALPS GlidePoint as /class/input/input4
iTCO_wdt: Found a ICH4-M TCO device (Version=1, TCOBASE=0xd860)
iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
cs: IO port probe 0x100-0x3af: excluding 0x1e0-0x1e7
cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
cs: IO port probe 0x820-0x8ff: clean.
cs: IO port probe 0xc00-0xcf7: clean.
cs: IO port probe 0xa00-0xaff: clean.
intel8x0_measure_ac97_clock: measured 55467 usecs
intel8x0: clocking to 48000
Adding 835340k swap on /dev/hda6. Priority:-1 extents:1 across:835340k
EXT3 FS on hda5, internal journal
loop: module loaded
device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: [email]dm-devel@redhat.com[/email]
NTFS driver 2.1.28 [Flags: R/W MODULE].
NTFS volume version 3.1.
pcmcia: Detected deprecated PCMCIA ioctl usage from process: discover.
pcmcia: This interface will soon be removed from the kernel; please expect breakage unless you upgrade to new tools.
pcmcia: see [url]http://www.kernel.org/pub/linux/utils/kernel/pcmcia/pcmcia.html[/url] for details.
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
ACPI: Battery Slot [BAT1] (battery present)
ACPI: AC Adapter [ADP1] (on-line)
input: Power Button (FF) as /class/input/input5
ACPI: Power Button (FF) [PWRF]
input: Lid Switch as /class/input/input6
ACPI: Lid Switch [LID]
input: Power Button (CM) as /class/input/input7
ACPI: Power Button (CM) [PWRB]
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Bluetooth: Core ver 2.11
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
[drm] Initialized drm 1.1.0 20060810
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LNKA] -> GSI 10 (level, low) -> IRQ 10
[drm] Initialized i915 1.6.0 20060119 on minor 0
PCI: Enabling device 0000:00:02.1 (0000 -> 0002)
[drm] Initialized i915 1.6.0 20060119 on minor 1
eth0: no IPv6 routers present
