Debian leny gdy próbuje otworzyć system -> urządzenia do przechwytywania danych -.> 2.1removable media ( na karte pamięci telefonu.) wypluwa okno.
proszę o pomoc?
Nigdy - tzn? na tym systemie w tej samej konfiguracji?miras_w pisze:Nie miałem nigdy z tym problemu.
cat preferences.fdi
<?xml version="1.0" encoding="UTF-8"?>
Some examples how to use hal fdi files for system preferences
You can either uncomment the examples here or put them in a seperate .fdi
file.
<deviceinfo version="0.2">
The following shows how to hint gnome-volume-manager and other programs
that honor the storage.automount_enabled_hint to not mount non-removable
media.
<device>
<match key="storage.hotpluggable" bool="false">
<match key="storage.removable" bool="false">
<merge key="storage.automount_enabled_hint" type="bool">false</merge>
</match>
</match>
</device>
The following shows how to put sync and noatime on for devices smaller then
1Gb and off for device larger then that. Note that the sync option can wear
out device faster then you'd like too. See
[url]http://readlist.com/lists/vger.kernel.org/linux-kernel/22/111748.html[/url] for
more info.
<device>
<match key="block.is_volume" bool="true">
<match key="volume.size" compare_lt="1000000000">
<match key="@block.storage_device:storage.hotpluggable" bool="true">
<merge key="volume.policy.mount_option.sync" type="bool">true</merge>
<merge key="volume.policy.mount_option.noatime" type="bool">true</merge>
</match>
<match key="@block.storage_device:storage.removable" bool="true">
</match>
</match>
<match key="volume.size" compare_ge="1000000000">
<merge key="volume.policy.mount_option.sync" type="bool">false</merge>
<merge key="volume.policy.mount_option.noatime" type="bool">false</merge>
</match>
</match>
</match>
</match>
</device>
</deviceinfo>
cat //etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/hda2 / ext3 defaults,errors=remount-ro 0 1
/dev/hda1 /home ext3 defaults 0 2
/dev/hda6 /home/ftp ext3 defaults 0 2
/dev/hdb1 /home/hdb ext3 defaults 0 2
/dev/hda3 /usr ext3 defaults 0 2
/dev/hda7 /var ext3 defaults 0 2
/dev/hda8 /var/spool/squid ext3 defaults 0 2
/dev/hda5 none swap sw 0 0
/dev/hdc /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/hdd /media/cdrom1 udf,iso9660 user,noauto 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
mount -t vfat /dev/sda1 /media
Dodać do /etc/fstab wpis umożliwiający montowanie urządzenia /dev/sda1:miras_w pisze:co zrobic montowac jako zwykły user?
/dev/sda1 /media vfat user,noauto,iocharset=iso8859-2,codepage=852,umask=0,exec 0 0
Dec 18 11:40:19 wozio kernel: FAT: Directory bread(block 538) failed
Dec 18 11:40:19 wozio kernel: scsi 0:0:0:0: rejecting I/O to dead device
Dec 18 11:40:19 wozio kernel: FAT: Directory bread(block 539) failed
Dec 18 11:40:19 wozio kernel: FAT: Directory bread(block 540) failed
Dec 18 11:40:19 wozio kernel: FAT: Directory bread(block 541) failed
W tym momencie przestałam Cię rozumieć: wcześniej pisałeś, że bez problemu montujesz jako root sda1, a to co wyżej zamieszczasz jest (jak rozumiem, bo nie byłeś łaskaw napisać) logiem kernela, który ma problem z obsługą urządzenia. Także to, pod jakim urządzeniem system widzi Twój telefon jest sprawą jądra a nie użytkownika (notabene: jeśli podłączyłeś już jakiś inny nośnik, to nic dziwnego, że telefon jest wykrywany jako inne urządzenie).miras_w pisze:chyba coś nie takza każdym razem widzi karte telefonu jako inne urzadzenie sda, sdb, sdcKod: Zaznacz cały
Dec 18 11:40:19 wozio kernel: FAT: Directory bread(block 538) failed Dec 18 11:40:19 wozio kernel: scsi 0:0:0:0: rejecting I/O to dead device (...)
mkdir ~/komunikaty
dmesg > ~/komunikaty/dmesg_po_podlaczeniu
dmesg > ~/komunikaty/dmesg_root
cat /etc/mtab > ~/komunikaty/mtab_mount_root
cp /etc/fstab ~/komunikaty/
dmesg > ~/komunikaty/dmesg_user
cat /etc/mtab > ~/komunikaty/mtab_mount_user
dmesg > ~/komunikaty/dmesg_po_podlaczeniu2
dmesg > ~/komunikaty/dmesg_autouser
cat /etc/mtab > ~/komunikaty/mtab_automount
