Proftpd DefaultRoot
qbsiu
Proftpd DefaultRoot
Post autor: qbsiu »
Mam małe pytanie, mam kilku userów na kompie, którym udostępniam FTP, plik konfiguracyjny definiujący DefaultRoot wygląda tak:
DefaultRoot                     ~
Co oznacza, że po zalogowaniu userzy znajdują się w ~.
Ja potrzebuję jednemu userowi ustawić ~/katalog
Da się coś takiego zrobić?
Dziękuję!
Pozdrawiam!
tomii
Post autor: tomii »
spróbuj podac pelna ścieżke np /home/user1/katalog
qbsiu
Post autor: qbsiu »
czytaj dokładnie....
tomii
Post autor: tomii »
to pokarz swój konfig proftpd.
qbsiu
Post autor: qbsiu »
tomii pisze:to pokarz swój konfig proftpd.
# Includes required DSO modules. This is mandatory in proftpd 1.3
Include /etc/proftpd/modules.conf
# /etc/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes reload proftpd after modifications.
UseIPv6                         off
UseReverseDNS off
IdentLookups off
DefaultRoot                     ~
ServerName                      "vgratix"
ServerType                      standalone
DeferWelcome                    off
MultilineRFC2228                on
DefaultServer                   on
ShowSymlinks                    on
TimeoutNoTransfer               600
TimeoutStalled                  600
TimeoutIdle                     1200
DisplayLogin                    welcome.msg
DisplayFirstChdir               .message
ListOptions                     "-l"
DenyFilter                      \*.*/
# Uncomment this if you are using NIS or LDAP to retrieve passwords:
#PersistentPasswd               off
# Uncomment this if you would use TLS module:
#TLSEngine                      on
# Uncomment this if you would use quota module:
#Quotas                         on
# Uncomment this if you would use ratio module:
#Ratios                         on
# Port 21 is the standard FTP port.
Port                            21
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances                    30
# Set the user and group that the server normally runs at.
User                            nobody
Group                           nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask                           022  022
# Normally, we want files to be overwriteable.
AllowOverwrite                  on
# Delay engine reduces impact of the so-called Timing Attack described in
# [url]http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02[/url]
# It is on by default.
#DelayEngine                    off
# A basic anonymous configuration, no upload directories.
 #<Anonymous ~ftp>
 #  User                                ftp
 #  Group                               nogroup
   # We want clients to be able to login with "anonymous" as well as "ftp"
 #  UserAlias                   anonymous ftp
   # Cosmetic changes, all files belongs to ftp user
 #  DirFakeUser on ftp
 #  DirFakeGroup on ftp
  # RequireValidShell           off
   # Limit the maximum number of anonymous logins
#   MaxClients                  3
   # We want 'welcome.msg' displayed at login, and '.message' displayed
   # in each newly chdired directory.
 #  DisplayLogin                        welcome.msg
#   DisplayFirstChdir           .message
   # Limit WRITE everywhere in the anonymous chroot
 #  <Directory *>
 #    <Limit WRITE>
#       DenyAll
#     </Limit>
#   </Directory>
   # Uncomment this if you're brave.
   # <Directory incoming>#
   #   # (second parm) from being group and world writable.
   #   Umask                            022  022
   #            <Limit READ WRITE>
   #            DenyAll
   #            </Limit>
   #            <Limit STOR>
   #            AllowAll
   #            </Limit>
   # </Directory>
# </Anonymous>
tomii
Post autor: tomii »
czy mi się wydaje czy wszyscy jada na jednym userze? jesli tak to stworz kilku
http://forum.freesco.pl/viewtopic.php?t ... sc&start=0
qbsiu
Post autor: qbsiu »
Nie, z tym wszystko jest okej.
Mar 17, 2006
zmieniło się trochę przez ten czas :D
tomii
Post autor: tomii »
masz userów systemowych czy w bazie?
qbsiu
Post autor: qbsiu »
systemowych
tomii
Post autor: tomii »
to jak ich masz dodanych do proftpd?
