vps87-230-80-238:~# apt-get install bind9
Reading package lists... Done
Building dependency tree... Done
E: The package mc needs to be reinstalled, but I can't find an archive for it.Kod: Zaznacz cały
apt-get -f installKod: Zaznacz cały
dpkg --configure -aKod: Zaznacz cały
apt-get -f install bind9Kod: Zaznacz cały
dpkg: dependency problems prevent configuration of bind9:
bind9 depends on libbind9-30; however:
Package libbind9-30 is not installed.
bind9 depends on libc6 (>= 2.6.1-1); however:
Version of libc6 on system is 2.3.6.ds1-13etch2.
bind9 depends on libdns32; however:
Package libdns32 is not installed.
bind9 depends on libisc32; however:
Package libisc32 is not installed.
bind9 depends on libisccc30; however:
Package libisccc30 is not installed.
bind9 depends on libisccfg30; however:
Package libisccfg30 is not installed.
bind9 depends on liblwres30; however:
Package liblwres30 is not installed.
bind9 depends on libssl0.9.8 (>= 0.9.8f-1); however:
Version of libssl0.9.8 on system is 0.9.8c-4etch1.
bind9 depends on libdns32 (= 1:9.4.2~rc2-1); however:
bind9 depends on libisccfg30 (= 1:9.4.2~rc2-1); however:
bind9 depends on libisc32 (= 1:9.4.2~rc2-1); however:
bind9 depends on libisccc30 (= 1:9.4.2~rc2-1); however:
dpkg: error processing bind9 (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
bind9
dpkg -i ./bind9_9.4.2~rc2-1_i386.debKod: Zaznacz cały
lvps87-230-80-238:/home# dpkg -i ./bind9_9.4.2~rc2-1_i386.deb
(Reading database ... 27012 files and directories currently installed.)
Preparing to replace bind9 1:9.4.2~rc2-1 (using ./bind9_9.4.2~rc2-1_i386.deb) ...
Unpacking replacement bind9 ...
dpkg: error processing bind9 (--install):
bind9
lvps87-230-80-238:/home# su
lvps87-230-80-238:/home# apt-get -f install
lvps87-230-80-238:/home# dpkg --configure -a
bind9
apt-get remove bind9Kod: Zaznacz cały
lvps87-230-80-238:/home# apt-get remove bind9
bind9
