xy nie startuja na sterowniku ati (czarny ekran)
amoureux
Post autor: amoureux »
jesli w sekcji device daje Vesa to sie uruchamia ok ... jesli ati, radeon, to mam ciemny ekran zamiast ekranu logowania ... w debian lenny karta graficzna ruszyla mi od kopa , tutaj nie ..
Radeon 9200
probowalem dpkg reconfigure !
# package.
Section "Files"
	FontPath	"/usr/share/fonts/X11/misc"
	FontPath	"/usr/X11R6/lib/X11/fonts/misc"
	FontPath	"/usr/share/fonts/X11/cyrillic"
	FontPath	"/usr/X11R6/lib/X11/fonts/cyrillic"
	FontPath	"/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
	FontPath	"/usr/share/fonts/X11/Type1"
	FontPath	"/usr/X11R6/lib/X11/fonts/Type1"
	FontPath	"/usr/share/fonts/X11/100dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/100dpi"
	FontPath	"/usr/share/fonts/X11/75dpi"
	FontPath	"/usr/X11R6/lib/X11/fonts/75dpi"
	# path to defoma fonts
	FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load	"i2c"
	Load	"bitmap"
	Load	"ddc"
	Load	"dri"
	Load	"extmod"
	Load	"freetype"
	Load	"glx"
	Load	"int10"
	Load	"vbe"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"pl"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"		"/dev/input/mice"
	Option		"Protocol"		"ImPS/2"
	Option		"Emulate3Buttons"	"true"
EndSection
Section "Device"
	Identifier	"ATI Technologies Inc RV280 [Radeon 9200]"
	Driver		"vesa"
	BusID		"PCI:1:0:0"
EndSection
Section "Monitor"
	Identifier	"101725"
	Option		"DPMS"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"ATI Technologies Inc RV280 [Radeon 9200]"
	Monitor		"101725"
	DefaultDepth	24
	SubSection "Display"
		Depth		1
		Modes		"1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
	EndSubSection
		Depth		4
	EndSubSection
		Depth		8
	EndSubSection
		Depth		15
	EndSubSection
		Depth		16
	EndSubSection
		Depth		24
	EndSubSection
EndSection
Section "ServerLayout"
	Identifier	"Default Layout"
	Screen		"Default Screen"
	InputDevice	"Generic Keyboard"
	InputDevice	"Configured Mouse"
EndSection
Section "DRI"
	Mode	0666
EndSection
ms-trex
Post autor: ms-trex »
A zainstalowałeś chociaż drivery?
libgl1-mesa-dri libglu1-mesa mesa-common-dev mesa-utils xlibmesa-dri xlibmesa-glu freeglut3
amoureux
tak
ms-trex
Chłopie a szukarki użyłeś chociaż, przecież praktycznie co tydzień ludzie piszą o tym samym problemie.
Do sekcji Monitor dopisz zakresy częstotliowści dla twojego monitora, ja mam np. takie:
Section "Monitor"
	HorizSync	30-85
	VertRefresh	50-160
EndSection
amoureux
chłopie, a czego ty uzyles piszac tego posta ... dopisanie tych zakresow niczego nie zmienia, nawiasem mowiac:
a co za tym idzie probowalem roznych czestotliwosci - nie dziala i tyle. Kto pomoze??
ms-trex
Co z tego że dałeś dpkg reconfigure, wcale z tego nie wynika że wpisałeś częstotliwości i poustawiałeś inne rzeczy, poza tym wkleiłeś "pusty" xorg.conf z vesą czyli taki jaki twierdzisz że ci działa, wklej taki jaki ci nie paca i po zrekonfigurowaniu i po rzekomym dodaniu zakresów.
amoureux
po dodaniu
Option "BusType" "PCI"
do sekcji device system dziala z ati, ale glxgears pokazuje mi do 800 fps przy czym na debian lenny mialem dwa razy tyle z uruchomionym compizem
[ Dodano: 2007-11-26, 13:19 ]
tyle wyczytalem ze ta opcja spowalnia grafike... ale to niech mi ktos powie jak ta grafike uruchomic bez tej opcji?
M
Post autor: M »
A jakie masz drivery? Otwarte czy zamknięte?
